VRRAM-04-10-50-03-G
VRRAM-04-10-50-03-G
    AIRBORN
    板对板连接器
VRRAM-04-10-50-03-G 数据手册
VRRAM — Rugged, Right Angle Male VRRAM signal-integrity connectors are ruggedized versions of the standard VSRAM male connectors. These connectors can be used in extreme environmental conditions while maintaining high reliability and performance. Pitch: 1.27 mm. Sample Part Number Format: VRRAM-04-10-50-02-N VRRAM SERIES Rugged Right Angle (Male) 1.27 mm 50 ROWS 04 – 4 Rows 05 – 5 Rows 06 – 6 Rows 08 – 8 Rows 10 – 10 Rows COLUMNS 10 – 10 Columns 20 – 20 Columns 30 – 30 Columns 40 – 40 Columns 50 – 50 Columns CONTACT PLATING 50 – 50 µ″ Au TERMINATION 00 – Press-fit 01 – Paste-in-hole 02 – PTH 0.078″ 03 – PTH 0.109″ 04 – PTH 0.140″ 05 – PTH 0.156″ 06 – PTH 0.172″ OPTIONS Blank – Standard G – Guide pin N – Fixed jacknut J – Turning jackscrew1 L – Locking screw1 E – Standard/EMI gasket GE – Guide pin/EMI gasket NE – Fixed jacknut/EMI gasket JE – Turning jackscrew/EMI gasket1 LE – Locking screw/EMI gasket1 Notes: See AirBorn spec ESL5001 for installation information. 1 Connectors come pre-assembled with shells & hardware. AirBorn can manufacture other configurations to your exact specifications. RoHS Complaint; certificate of conformance available upon request with each shipment. Please view document VRRAM-XX-XX-XX-XX-XX on airborn.com before part configuration for more product specification information. NOTE: Please consult airborn.com to configure your part number and for the latest revision controlled drawing and technical data. 1 Reliable Contact Every Time 4 VerSI connectors feature a low-matingforce, high-reliability contact system with four points-of-contact. 3 The open-pin field design allows flexibility in termination schemes. Single-ended, differential pair, power, and ground are all available in one connector design. 24 3500 AirBorn Circle — Georgetown, TX 78626 2 • p. 5 1 2 . 8 6 3 . 5 5 8 5 • airborn.com
VRRAM-04-10-50-03-G 价格&库存
很抱歉,暂时无法提供与“VRRAM-04-10-50-03-G”相匹配的价格&库存,您可以联系我们找货
