AP-M2M-LP-CCG-Q-S222-BL-6
    AIRGAIN
    ANTENNA PLUS M2M LOW PROFILE ANT
AP-M2M-LP-CCG-Q-S222-BL-6 数据手册
M2M Low Profile Double Cell IP67 Antenna with GNSS M2M Low Profile is a fully rugged outdoor antenna designed specifically for M2M applications. This antenna provides best in class performance with two high gain cellular/LTE, and GNSS antennas inside a single robust and compact housing. • 2 x Wideband Cellular/LTE Elements (MIMO) • 1 x GNSS Antenna • Leading LTE performance while in coexistence with multiple other embedded antenna technologies • Lower profile and smaller footprint than competing solutions • Ground plane independent • Available in black or white • US Patent 10109918 Descriptions/Applications The M2M Low Profile antenna builds on the best in class RF performance, leading design, features, and extended product life tradition of this highly successful product line. Ideal for kiosks, digital signage, wireless ATMs, vending machines, NEMA enclosures, industrial metering and other wireless machine to machine applications. This antenna has been designed to mount externally to an M2M or IoT enabled asset, and requires no servicing through its life time. Optimal MIMO Performance for LTE Compact and Robust UV Resistant Housing Full Outdoor Installation Ready Customizable Cables and Connectors Low loss cable accessories Fast custom turnaround time Standard Configurations GNSS Adhesive Mount AP-M2M-LP-CCG-Q-BL-6 MIMO Cell/LTE x 2 & GNSS, Threaded bolt mount, SMA, Black, 6ft coax AP-M2M-LP-CCG-A-BL-6 MIMO Cell/LTE x 2 & GNSS, Adhesive mount, SMA, Black, 6ft coax ap-sales@airgain.com | www.airgain.com | + 1-855-AIRGAIN Bolt Mount M2M Low Profile Electrical Data Antennas 1 & 2 698-960/1700-2700 MHz Frequency Range Antenna 3 1550~1610 MHz Antennas 1 & 2 LTE/Cellular Operational Bands Antenna 3 Antennas 1 & 2 Peak Gain: Isotropic Antenna 3 Isolation GPS L1/GALILEO E1/GLONASS G1/BeiDou B1/QZSS L1 698-960 MHz 2.0 dBi 1710-2700 MHz 4.0 dBi 30.5 dBi Antennas 1 & 2 > 10 dB Correlation Co-efficient Antennas 1 & 2 < 0.1 Environmental Data Hazardous Substances RoHS Compliant Temperature -40ºC to 65ºC (-40ºF to + 149ºF) Operating and Storage conformance to IEC 60068 Humidity (Non-Condensing) 5% to 96% Operating and Storage conformance to IEC 60068 Water Ingress IP67 Military Spec MIL-STD 810 conformance to vibration Mounting Data Height 1.13” (28.6mm) Dimensions Width 2.66” (67.6mm) Length 6.88” (174.8mm) Color Black (BL) or White (WH) Cable Data- Cell/LTE Type CFD195 Low Loss Diameter 0.195” (4.953 mm) Length 1 feet (0.3 m) Cable Data- GNSS Type RG-174U Diameter 0.100” (2.54 mm) Length 1 feet (0.3 m) Termination SMA Male Termination SMA Male GNSS Data - Ceramic Patch Antenna Specification GNSS Data - LNA Specification Bandwidth 1561 – 1602 MHz Gain@Zenith 2.5 dBi Polarization R.H.C.P. Axial Ratio 3.0 dB Typ. Noise Figure 1.2 dB Gain 28 dBi Voltage 3.3V~5.6V Current 9.6±1mA@3.3V ap-sales@airgain.com | www.airgain.com | + 1-855-AIRGAIN
AP-M2M-LP-CCG-Q-S222-BL-6 价格&库存
很抱歉,暂时无法提供与“AP-M2M-LP-CCG-Q-S222-BL-6”相匹配的价格&库存,您可以联系我们找货
