AP-NEXT-M2M-SN-BL
AP-NEXT-M2M-SN-BL
    AIRGAIN
    ANTENNA PLUS M2M NEXT 5G SALT SH
AP-NEXT-M2M-SN-BL 数据手册
M2M SN Next 5G Salt Shaker IP67 Antenna M2M SN Next is a MIL-STD-810G qualified fully rugged outdoor antenna designed specifically for M2M applications. This antenna provides best in class performance, providing high gain cellular/5G antenna inside a single robust and compact housing. • Wideband Cellular 5G (617 MHz-6 GHz) Element • Ground plane independent • Available in black or white Compact and Robust UV Resistant Housing Full Outdoor Installation Ready Descriptions/Applications The M2M SN Next antenna builds on the best in class RF performance, leading design, features, and extended product life tradition of this highly successful product line. Ideal for charging stations, kiosks, digital signage, NEMA enclosures, wireless ATMs, vending machines, industrial metering and other wireless machine to machine applications. This antenna has been designed to mount externally to a M2M or IoT enabled asset, and requires no servicing throughout its life time. Standard Configurations AP-Next-M2M-SN-BL Cell/5G, N bulkhead Connector, Black Also available in color white. ap-sales@airgain.com | www.airgain.com | + 1-855-AIRGAIN Fast custom turnaround time Low loss cable accessories M2M SN Next Electrical Data Frequency Range 617-960/1427-1600/1700-2700/3300-4200/5150-5850 MHz Operational Bands 2G, 3G, 4G/LTE, 5G (Band 71, LTE, CBRS, LAA) Peak Gain: Isotropic 617-690 MHz 3.4 dBi 700-960 MHz 4.0 dBi 1427-1600 MHz 4.1 dBi 1710-2700 MHz 6.0 dBi 3300-4200 MHz 6.1 dBi 5150-5850 MHz 7.0 dBi Peak Gain performance is based on presence of 1ft radius ground plane. Electrical performance with no ground plane may vary. Environmental Data Hazardous Substances RoHS Compliant Temperature -40ºC to 65ºC (-40ºF to + 149ºF) Operating and Storage conformance to IEC 60068 Humidity (Non-Condensing) 5% to 96% Operating and Storage conformance to IEC 60068 Water Ingress IP67 Military Spec MIL-STD 810G conformance to vibration Mounting Data Height Dimensions Diameter 1.64” (42.5mm) Bolt Diameter 5/8-24UNEF-2A Bolt Length Color 3.875” (98.5mm) 20.5 mm Black (BL) or White (WH) Optional Mounting Accessory SKU: AP-Bracket-SB • Anodized Aluminum Platform ap-sales@airgain.com | www.airgain.com | + 1-855-AIRGAIN
AP-NEXT-M2M-SN-BL 价格&库存
很抱歉,暂时无法提供与“AP-NEXT-M2M-SN-BL”相匹配的价格&库存,您可以联系我们找货
