M2M SN
M2M SB
M2M SN/SB
Salt Shaker LTE IP67 Antenna
M2M SN/SB is a MIL-STD-810G qualified fully rugged outdoor antenna designed
specifically for M2M applications. This antenna provides best in class performance,
providing high gain cellular/LTE antenna inside a single robust and compact
housing. Two versions of the antenna are available; one with a N-type connection
and one with a bolt mount and a coaxial cable terminating with a SMA connector.
• Covers all cellular/LTE frequencies globally
• Ground plane independent
• Available in black or white
• MIL-STD-810G qualified
Compact and Robust
UV Resistant Housing
Full Outdoor
Installation Ready
Fast custom
turnaround time
Descriptions/Applications
The M2M SN/SB antenna builds on the best in class RF performance, leading
design, features, and extended product life tradition of this highly successful
product line. Ideal for charging stations, kiosks, digital signage, NEMA enclosures,
wireless ATMs, vending machines, industrial metering and other wireless machine
to machine applications. This antenna has been designed to mount externally to a
M2M or IoT enabled asset, and requires no servicing throughout its life time.
Standard Configurations
AP-M2M-SN-BL
Cell/LTE, N bulkhead Connector, Black
AP-M2M-SB-S2-BL-6
Cell/LTE, Threaded bolt mount, SMA, Black, 6ft coax
Also available in color white, customizable cable lengths up to 35 feet, and other connector variations.
ap-sales@airgain.com | www.airgain.com | + 1-855-AIRGAIN
Low loss cable
accessories
M2M SN/SB
Electrical Data
Frequency Range
Element 1
698-960/1700-2700 MHz
Operational Bands
Element 1
LTE/Cellular
Peak Gain: Isotropic
698-960 MHz
3.0 dBi
1710-2700 MHz
6.0 dBi
Element 1
Environmental Data
Hazardous
Substances
RoHS Compliant
Temperature
-40ºC to 65ºC (-40ºF to + 149ºF) Operating and Storage conformance to IEC 60068
Humidity
(Non-Condensing)
5% to 96% Operating and Storage conformance to IEC 60068
Water Ingress
IP67
Military Spec
MIL-STD 810 conformance to vibration
Mounting Data
Height 3.24” (82.2mm)
Diameter 1.64” (42.5mm)
Dimensions
Bolt Diameter 5/8-24UNEF-2A
Bolt Length M2M SN 20.5 mm
Bolt Length M2M SB 24.5 mm
Color
Black (BL) or White (WH)
Cable Data
Type CFD195 Low Loss
Cell/LTE Cables
Diameter 0.195” (4.953 mm)
Length 1 foot (0.3 m)
Termination SMA Male
很抱歉,暂时无法提供与“AP-M2M-SB-S2-BL-6”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+587.416571+76.21682
