AP-MMF-CCWWG-Q-SMA-RP34-BL
    AIRGAIN
    ANTENNA PLUS MULTIMAX FV MIMO AN
AP-MMF-CCWWG-Q-SMA-RP34-BL 数据手册
FLEET SOLUTIONS 5-in-1 Compact External IP65 Antenna MULTIMAX FV is a full outdoor antenna designed specifically to provide high performance connectivity for Fleet and Public Safety vehicles and assets connecting to almost any vehicular router or modem. This antenna offers two high gain cellular/LTE/MIMO antennas which support LTE Band 14 for FirstNet, two high gain dual band Wi-Fi antennas, and a GNSS antenna inside a single robust and compact housing. • 2 x Wideband Cellular/LTE Elements (MIMO) • 2 x 2.4 & 4.9-6GHz Wi-Fi Elements (MIMO) • 1 x GNSS Element • Five or less embedded antenna technologies that operate over multiple bands in one housing • Leading LTE performance while in coexistence with multiple other embedded antenna technologies • Lower profile and smaller footprint than competing solutions • USA factory ensures fast turnaround customizations • High gain provides bigger cellular footprint • Must be mounted on metal • Available in black or white • US Patent 10109918 Optimal MIMO Performance for LTE Compact and Robust UV Resistant Housing Full Outdoor Installation Ready Customizable Cables and Connectors to Connect to Any Modem GNSS Low loss cable accessories Descriptions/Applications The MULTIMAX FV antenna builds on the best in class RF performance, leading design features, and extended operational life of our highly successful Fleet and Public Safety Antenna products. This new product line also offers a rugged low-profile design which gives you greater protection against all the natural hazards a vehicle faces including vibration, hot, cold, ice, salt, dirt, car washes, and tree branch sweeps. Our antennas typically outlast the life of a vehicle. Fast custom turnaround time Bolt Mount with Adhesive Pad Standard Configurations Adhesive Mount Magnetic Mount AP-MMF-CCWWG-Q-S22222-RP34-BL-15 MIMO Cell/LTE x 2, Wi-Fi x 2 & GNSS, Threaded Bolt Mount, SMA on Cell/ LTE & GNSS, RP-SMA on Wi-Fi, Black, 15ft coax AP-MMF-CCWWG-A-S22222-RP34-BL-15 MIMO Cell/LTE x 2, Wi-Fi x 2 & GNSS, Adhesive Mount, SMA on Cell/LTE & GNSS, RP-SMA on Wi-Fi, Black, 15ft coax AP-MMF-CCWWG-M-S22222-RP34-BL-15 MIMO Cell/LTE x 2, Wi-Fi x 2 & GNSS, Magnetic Mount, SMA on Cell/LTE & GNSS, RP-SMA on Wi-Fi, Black, 15ft coax Also available in color white, customizable cable lengths up to 35 feet, and other connector variations. ap-sales@airgain.com | www.airgain.com | + 1-855-AIRGAIN MULTIMAXTM FV Electrical Data Elements 1 & 2 698-960/1700-2700 MHz Frequency Range Elements 3 & 4 2.4/4.9-6.0 GHz Element 5 1550~1610 MHz Elements 1 & 2 LTE/Cellular Operational Bands Elements 3 & 4 Wi-Fi Element 5 GPS L1/GALILEO E1/GLONASS G1/BeiDou B1/ QZSS L1 698-960 MHz Elements 1 & 2 Peak Gain: Isotropic 1710-2700 MHz Elements 3 & 4 2.4 GHz, 5.5 GHz Element 5 30.50 dBi 3 dBi 6.5 dBi 7 dBi, 5 dBi Elements 1 & 2 > 10 dB Isolation Elements 3 & 4 > 30 dB Correlation Co-efficient Elements 1 & 2 < 0.1 Environmental Data Hazardous Substances RoHS Compliant -55ºC to 85ºC (-67ºF to +185ºF) Operating and Storage conformance to MIL-STD-810G Method 501.5 Temperature Humidity (Non-Condensing) 5% to 96% Operating and Storage conformance to IEC 60068 Water Ingress IP65 Military Spec MIL-STD 810 conformance to vibration Mounting Data Height 2.47” (62.6mm) Dimensions Width 2.44” (62.1mm) Length 6.34” (161mm) Color Black (BL) or White (WH) Cable Data- Cell/LTE Type CFD195 Low Loss Diameter 0.195” (4.953 mm) Length 1 feet (0.3 m) Termination SMA Male Cable Data- Wi-Fi Type CFD195 Low Loss Diameter 0.195” (4.953 mm) Length 1 feet (0.3 m) Termination RP-SMA Male GNSS Data - Ceramic Patch Antenna Specification Bandwidth 1561 – 1602 MHz Gain@Zenith 2.5 dBi Polarization R.H.C.P. Axial Ratio 3.0 dB Typ. Cable Data- GNSS Type RG-174U Diameter 0.100” (2.54 mm) Length 1 feet (0.3 m) Termination SMA Male GNSS Data - LNA Specification Noise Figure 1.2 dB Gain 28 dBi Voltage 3.3V~5.6V Current 9.6±1mA@3.3V ap-sales@airgain.com | www.airgain.com | + 1-855-AIRGAIN
AP-MMF-CCWWG-Q-SMA-RP34-BL 价格&库存
很抱歉,暂时无法提供与“AP-MMF-CCWWG-Q-SMA-RP34-BL”相匹配的价格&库存,您可以联系我们找货
