APG/UPG/IPG
APG/UPG/IPG Series
“Existing Designs Only”
APG/UPG/IPG Series
Hydraulic Magnetic Circuit Protectors
INTRODUCTION
IMPORTANT NOTICE: The APG/UPG is a legacy
product and no new design-in orders are being
accepted. If the specifications for this product are
necessary for your system, Sensata Technologies
recommends utilizing the Airpax™ IAG series.
The APG/UPG magnetic circuit protector provides low-cost
power switching, reliable circuit protection and accurate circuit
control in one complete package. It is intended for use in data
processing and broadcast equipment, vending and amusement
machines, military and marine applications, and wherever
precision operation is required.
Designed using a current sensitive hydraulic magnetic
principle, the APG/UPG adapts itself to many applications and
environments. Temperature compensations which affect fuses
and other thermal devices are not a concern. Nuisance tripping
is minimized.
The APG/UPG is available in a wide variety of configurations with
a choice of delays and ratings. In addition, it is available in either
DC, 50/60Hz or 400Hz versions.
Available in single or multi-pole variations, the APG/UPG comes
with a variety of actuators. To enhance front-panel aesthetics,
toggle or rocker actuated handles and caps are available in a
variety of attractive colors.
Multi-pole circuit protectors can be furnished with either single
or multiple actuators. In addition, a unique sealed, single handle
toggle version for harsh or military environments is available in
single or multi-pole configurations.
The UPG circuit protector is recognized under UL Standard 1077,
file numbers E66410 and E33504 as a supplementary protector.
It is also certified by CSA under CSA STD. C22.2–No. 235, file
number LR26229 as a supplementary protector. The APG is
qualified to MIL-PRF-55629.
APG/UPG circuit protectors are available in one through four
pole assemblies with a variety of pole arrangements, terminal
styles, and accessories to meet your specifications, including
APG/UPG adapter plate option to allow mounting in APL/UPL
cutout.
APG/UPG/IPG
APG/UPG SINGLE POLE CIRCUIT PROTECTORS
Single Pole, Toggle
1.640
[41.66]
.69
[17.53]
MAIN TERMINAL TYPES
.13
[3.30]
Single Pole
Amp
Rating
Push-On
8-32
Screw
M4
Screw
.1 to 30
X
X
X
30.1 to 50
10-32
Screw
M5
Screw
X
X
APG 6-1*
.187 [4.75] DEEP (TYP.)
M3 1S0. THD. OPTIONAL
.590 DIA.
MAX.
[15.00]
2.00
[50.80]
OFF
1.66
[42.16]
1.22
[31.00]
.75
[19.05]
.23
[5.84]
1.53
[38.86]
.168
[4.27]
Single Pole, Mounting Detail
2X
+.010
-.000
.625
+.25
-.00
15.87
1.660
[42.16]
1.050
[26.67]
2X
.156
[3.96]
Notes: Tolerance ±.015 [.38]
unless noted.
Dimensions in Brackets
[ ] are millimeters.
* * Allows mounting in
APL/UPL cutout.
TWO POLE PROTECTORS
An assembly consisting of two single pole units, having their trip
mechanisms internally coupled, and with a single toggle handle,
forms the APG/UPG-11. It is also possible to provide a handle per
pole, which is referred to as UPGH11. Individual poles may differ
in ratings, delays and internal connections. An auxiliary switch
may be included in either or both poles if they are of the series
trip type. Screw-type terminals can be provided, in which case
the designation would be APG/UPG-66.
Two Pole
1.640
[41.66]
UPG11
UPGH11
.590 DIA.
MAX.
[15.00]
.69
[17.53]
2.00
[50.80]
OFF
OFF
OFF
1.66
[42.16]
1.22
[31.00]
.13
[3.30]
.75
[19.05]
1.515 MAX.
[38.48]
1.515
MAX.
[38.48]
(Optional, handle
may be in pole 1
instead of pole 2)
UPG11
.168
[4.27]
UPGH11
.156
[3.96]
(2 PER POLE)
1.660
[42.16]
+.010
-.000
1.050
[26.67]
.625
+.25
-.00
15.88
.750
[19.05]
Two Pole*
.750
[19.05]
Two Pole
Panel Mounting Detail: Tolerance ±.005 [.13] unless noted.
Note: Tolerance ± .015 [.38] unless noted. Dimensions in Brackets [ ] are millimeters.
* See single pole mounting detail for hole sizes and locations.
( 1 PER POLE)
APG/UPG/IPG
THREE POLE AND FOUR POLE PROTECTORS
The three pole structure consists of three single pole units
assembled with an internal mechanical interlock which
actuates all units simultaneously. A single toggle handle
operates all three poles, or a handle per pole is available.
The four pole structure consists of four single pole units
actuates all units simultaneously. A double toggle handle
operates all four poles, or a handle per pole is available. The
individual poles need not have identical characteristics and
any series trip pole may have an auxiliary switch. If screwtype terminals are required, the breaker designation will be
APG/UPG-666 for a three pole version and APG/UPG-6666 for
a four pole version.
1.640
[41.66]
Protector poles are numbered consecutively when viewed
from the terminal side, with the ON position up, starting with
Pole #1 on the left side and proceeding to the right.
1.640
[41.66]
.69
[17.53]
.13
[3.30]
2.
[5
1.640 1.640
.69 .69
[41.66] [41.66] [17.53][17.53]
.69
[17.53]
1.640
[41.66]
Three Pole
1.640
[41.66]
.69
[17.53]
.69
[17.53]
1.640
[41.66]
1.640
[41.66]
OFF
.750
[19.0
Three Pole
.69
[17.53]
.69
[17.53]
OFF
OFF
OFF
OFF
OFF
OFF
OFFOFF
OFFOFF
OFF
OFF
OFF
OFF
OFF
OFF
.13
.13 [3.30]
.13
[3.30]
[3.30]
.13
[3.30]
.13
[3.30]
UPG 111
.750
[19.05]
Mounting
Detail
.13
[3.30]
.13
[3.30]
[57.53]
.750
[19.05]
.750
[19.05]
[19.05]
[19.05]
.750
[19.05]
.750
[19.05]
.750
.750
[19.05]
.750
[19.05]
.750
OFF
OFF
.750
.750
[19.05] [19.05]
.750
.750
2.265 MAX.
[19.05]
[19.05]
2.265[57.53
MAX. ]
.750
UPGH[.750
111 ]
57.53
[19.05] [19.05]
[57.53
2.265] MAX.
[57.53]
2.265 MAX.
.750
[57.53.750
[19.05] [19.05]
.750
.750
.750[19.05]
.750 [19.05]
.750
.750
Mounting
[19.05] [19.05]
Detail
OFF
OFF
[19.05]
2.265
MAX. [19.05]
.750
[57.532.265
] .750 MAX.
[19.05]
[19.05]
[57.53
2.265] MAX.
[57.53]
.750
.750
[19.05] [19.05]
.750
.750
.750
[19.05] [19.05] [19.05]
.750
[19.05]
OFF
OFF
OFF
.750
.750
[19.05] .750
[19.05] .750
2.265 MAX.
[57.53]2.265 MAX.
2.265 MAX.
[57.53]
2.265 MAX.
[57.53]
OFF
.750
.750
[19.05] [19.05]
2.265 MAX.
2.265
[57.53]MAX.
2.265 MAX.
[57.53]
OFF
OFF
[19.05]
locations.
[19.05]
.750
.750
for hole
sizes and
[19.05]
[19.05]
.750
.750
[19.05] [19.05]
.750
[19.05]
OFF
Three Pole*
Three Pole*
OFF
Four Pole
OFF
OFF
OFF
OFF
OFF
.750
[19.05]
OFF
OFF
OFF
Four
Pole
OFF
OFF
OFF
OFF
OFF
OFF
OFF
OFF
OFF
.750
[19.05]
OFF
OFF
OFF OFF
OFF
OFF
OFF
OFF
OFF
OFF
OFF
3.015.750
.750
.750
MAX.
[19.05]
[19.05] [19.05]
.750
3.015
[76.58
.750
[19.05]
.750 ] .750
.750
.750
.750
.750
MAX.
3.015
.750
.750 3.015 .750
[19.05] [76.58]
.750
.750
[19.05]
[19.05]
[19.05]
[19.05]
[19.05]
3.015
[19.05]
[19.05]MAX.[19.05] [19.05] [19.05]
MAX. [19.05]
3.015MAX.
3.015
[76.58
[76.58]
3.015
3.015
MAX.
MAX.
3.015
[76.58]
MAX.
MAX.
[76.58]
.750 [76.58]
.750
.750
.750 MAX.
.750
.750
APG/UPG
only [19.05] [19.05]
[76.58]
[19.05]
[19.05]
[19.05]
[19.05]
[76.58
] [76.58
.750
[19.05]
.750
.750
Mounting
[19.05]
[19.05]
Detail
.750
[19.05]
.750
[19.05]
.750
[19.05]
.750.750 .750.750 .750 .750
.750
[19.05]
[19.05]
[19.05]
[19.05]
[19.05]
[19.05] [19.05]
Four Pole*
OFF
OFF
OFF
OFF
OFF
OFF
OFF
OFF
.750
.750
.750
3.015
.750
.750
.750
.750
.750
.750 [19.05] [19.05] [19.05]
.750
.750 .750
.750 .750
.750
.750
.750
.750
.750
Mounting
[19.05] .750
[19.05] [19.05]
[19.05]
[19.05]
[19.05] [19.05]
[19.05] [19.05]
[19.05]
[19.05]
Detail
3.015
MAX.
[76.58]
OFF
OFF
.750 MAX.
[19.05] [76.58]
3.015
MAX.
[76.58]
.750
[19.05]
OFF
OFF
OFF
OFF
.750
.750
.750
.750
.750
.750
[19.05] [19.05]
3.015[19.05]
MAX.
3.015
[76.58
MAX.
[76.58]
APGH/UPGH only
.750
.750
.750
.750
.750
.750
Four Pole*
.750
[19.05]
.750
[19.05]
.750
[19.05]
APGHX / UPGHX
DIMENSION “A”
Rocker actuated APGHX/UPGHX provides one rocker handle for
each pole of a multi-pole circuit protector.
Number of Poles
Dimensions “A”
2
1.510 ± .005 [38.35 ± .13]
3
2.265 ± .005 [57.53 ± .13]
Two Pole
Three Pole
1.515
MAX.
[38.48]
.23
[5.84]
2.00
[50.80]
1.22
[31.00]
1.66
[42.16]
1.53
[38.86]
2.481
[63.02]
2.265
MAX.
[57.53]
ON
ON
ON
ON
ON
OFF
OFF
OFF
OFF
OFF
2.59
[65.79]
.340
[8.64]
.540
[13.72]
1.640
[41.66]
.440
[11.18]
.75
[19.05]
HANDLE WIDTH
.75
[19.05]
Two Pole
±.005 [.13]
unless noted.
Three Pole
2.265
[57.53]
1.510
[38.35]
1.260
[32.00]
1.660
[42.16]
4X .156
[3.96]
.750
[19.05]
.75
[19.05]
.200
[5.08]
1.660
[42.16]
6X .156
[3.96]
1.260
[32.00]
.750
[19.05]
.750
[19.05]
.200
[5.08]
APG/UPG/IPG
APGX / UPGX
Rocker actuated APGX / UPGX provides one rocker handle per circuit
protector.
Single Pole
.23
[5.84]
Two Pole
1.515
MAX.
[38.48]
.75
[19.05]
2.00
[50.80]
1.22
[31.00]
1.53
[38.86]
2.59
[65.79]
ON
2.481
[63.02]
OFF
ON
1.66
[42.16]
OFF
.540
[13.72]
1.640
[41.66]
.440
[11.18]
HANDLE WIDTH
Three Pole
(Optional, handle may be in
pole 2 instead of pole 1)
One, Two & Three Pole
.750
[19.05]
2.265
MAX.
[57.53]
ON
OFF
1.660
[42.16]
2X
.156
[3.96]
1.260
[32.00]
.200
[5.08]
±.005 [.13]
unless noted.
BAT HANDLE / PANEL SEAL (APGN / UPGN)
The APGN is designated to provide circuit protection in harsh and
military environments. Waterproof panel integrity is provided by an
“O” ring bushing seal and silicon rubber gland within the bushing/
handle assembly. Single, two or three pole versions are available
with two and three pole versions featuring a single operating
handle and mounting bushing.
.625
[15.88]
.750
.130
[3.30]
19.05
.230
[5.84]
ON
1.530
[38.86]
OFF
LOCKWASHER
Two Pole
Single Pole
1.220
[31.00].656
[16.66]
Three Pole
2.000
[50.80]
1.515
MAX.
[38.48]
.750
[19.05]
2.265
MAX.
[57.53]
(Optional handle may
be in pole 2 instead
of pole 1)
Two Pole*
Single Pole
.750
[19.05]
.156
[3.96]
.515
[13.08]
Three Pole*
.750
.750
[19.05] [19.05]
.656
[16.66]
Panel Mounting Detail: Mounting
detail tolerance
*See single pole mounting detail for hole
Optional Handle
APG/UPG/IPG
TOGGLE HANDLES (APG/UPG)
Standard Handle Location
(Applies to 2 Pole Only)
The APG/UPG circuit protector is available with toggle handles in six different colors. For attractive panel appearance, color caps are also available. Handles may
be specified in black, white, yellow, red, blue and green. For multi-pole units,
specify handle per unit or handle per pole.
Toggle Handles
OFF
APG/UPG
Color Caps
For attractive panel appearance the following
color caps are available for use on APG/UPG
protectors.
Bat Handle/
Panel Seal
APGN/UPGN
COLOR CAPS
Rocker
ON
OFF
APGX/UPGX
Color
Order Separately
Red
762 - 300 - 8046
Green
762 - 300 - 8043
White
762 - 300 - 8040
Gray
762 - 300 - 8041
Blue
762 - 300 - 8042
Yellow
762 - 300 - 8044
Orange
762 - 300 - 8045
Brown
762 - 300 - 8047
Black
762 - 300 - 8048
IPG MAGNETIC CIRCUIT PROTECTORS
1.640
[41.66]
.690
[17.53]
The IPG circuit protectors provide the
advantages of magnetic “stand alone”
protection and compliance with UL, CSA,
SEV, VDE and IEC standards.
They are UL Recognized per UL STD. 1077 as
supplementary protectors, CSA Certified per
CSA C22.2–No. 235 as supplementary
protectors, VDE approved and CE compliant
to VDE 0642 (EN60934). Additionally, they
conform to the spacing requirements of VDE
0730, 0804, 0805 and 0806, and IEC 950 for
use in office machines and data processing
equipment.
IPG circuit protectors have current ratings
from .020 to 50 amperes, 250Vac, 65Vdc,
and an auxiliary switch is available with
either gold or silver contacts. They feature
one through four pole configurations, with
one handle per pole. A choice of handle
actuation colors, terminals and hardware are
available and international markings are
standard. And, with an adapter plate, they
will fit in panels cut for Airpax APL and UPL
type protectors.
32∫
32∫
.250
[6.35]
2.032
[51.61]
MAX.
Two Pole
Single Pole
.590 MAX.
[15.00]
2.000
[50.80]
1.660
[42.16]
1.220
[30.99]
.750
[19.05]
Three Pole
Note:
Main terminals are stationary male push-on type .250 [6.35]
wide x .031 [.787] thick x .312 [7.92] long or 8-32 x .187 [4.75]
screw type (≤30A). 10-32 x .187 [4.75] screw type (>30A).
.168
[4.27]
.750
[19.05]
1.515
[38.48]
MAX.
Four Pole
.750
.750
[19.05] [19.05]
2.265
[57.53]
MAX.
.750
.750
.750
3.015
[76.58]
MAX.
Panel mounting detail:
Tolerance ± .005 [.13] unless noted.
1.660
[42.16]
1.050
[26.67]
.750
[19.05]
APG/UPG/IPG
APG/UPG/IPG CONFIGURATIONS
Series and Switch Only
.23
[5.84]
.23
[5.84]
1.53
[38.86]
1.53
[38.86]
Series
Series Trip
The most popular configuration for magnetic protectors is
the series trip where the sensing coil and contacts are in
series with the load being protected. The handle position
conveniently indicates circuit status. In addition to providing conventional overcurrent protection, it’s
simultaneously used as an on-off switch.
Switch Only
Shunt and Dual Coil
.23
[5.84]
1.53
[38.86]
1.38
[35.05]
Shunt
Dual Coil
Tapped Coil
.23
[5.84]
1.53
[38.86]
1.38
[35.05]
Tapped Coil
Shunt Trip
The shunt trip is designed for controlling two separate
loads with one assembly. The control is established by
providing overload protection for the critical load. When
the current through this load becomes excessive and
reaches the trip point, the protector will open and remove
power from both loads simultaneously. The total current
rating of both loads must not exceed the maximum contact rating.
Relay Trip
This permits the overload sensing coil to be placed in a
circuit which is electrically isolated from the trip contacts.
The coil may be actuated by sensors monitoring pressure,
flow, temperature, speed, etc. Other typical applications
include crowbar, interlock and emergency/rapid shutdown
circuitry. Trip may be accomplished by voltage or current,
which must be removed after trip.
Relay and Dual Coil
.23
[5.84]
.61
[15.50]
1.38
[35.05]
1.53
[38.86]
Dual Coil
Relay
Auxiliary Switch
This is furnished as an integral part of a series pole in
single or multi-pole assemblies. Isolated electrically from
the protector’s circuit, the switch works in unison with the
power contacts and provides indication at a remote location
of the protector’s on-off status.
Voltage Trip
Sometimes called “dump circuits” or “panic trip circuits,”
these units make it possible to open main power contacts
with lower power inputs from one or more sources. This
configuration is becoming increasingly more important for
sensitive circuitry and denser packaging in automation
systems. Available in series, shunt, or relay configurations.
.23
[5.84]
.61
[15.50]
1.38
[35.05]
Relay and Four Terminal
Dual Coil with Screw Terminal
1.53
[38.86]
Auxiliary Switch
.295
[7.49]
.110
[2.79]
-1 REC 4
-1 REG 4
Quick Connect
Terminals
Series with Auxiliary Switch
All auxiliary switch terminals
.020[.51] thick
Standard auxiliary switch is REC 4.
.312
[7.92]
.187
[4.75]
-1 REC 5
-1 REG 5
Quick Connect
Terminals
C
NO
NC
C
NO
NC
Breaker in OFF position
Note:
Main terminals are stationary male push-on type .250 [6.35] wide, x .031 [.787] thick, x
.312 [7.92] long or 8-32 x [4.75] screw type (≤30A), 10-32 x .187 [4.75] screw type (>30A).
Note:
Tolerance ± .015 [.38] unless noted.Dimensions in Brackets [ ] are millimeters.
APG/UPG/IPG
APG/UPG/IPG OPERATING CHARACTERISTICS
NOMINAL DCR / IMPEDANCE
Current
Ratings
(Amps)
Resistance (ohms)
Impedance (ohms)
Impedance (ohms)
DC Delays
AC, 50/60Hz Delays
AC, 400Hz Delays
50
59
51, 52, 53
Dual Coil
51, 52, 53
60
69
600, 61, 62
71, 72, 73
64, 65, 66
Dual Coil 61, 62
40, 49
41, 42, 43
0.05
162
540
460
640
174
419
582
691
1975
1195
0.10
35.4
105
155
150
42.5
103.4
119.0
160
495
284
0.50
1.2
4.2
4.5
5.6
1.9
4
4.1
6.2
22
12
1.0
.236
1.02
1.2
1.41
.41
.955
1.08
1.56
5.01
2.72
5.0
.021
.048
.059
.070
.030
.045
.048
.068
.240
.140
10.0
.0060
.0121
.0140
.0160
.0075
.0105
.0134
.0174
.0520
.0283
15.0
.0040
.0067
.0092
.0100
.0038
.0068
.0070
.0120
.0260
.0140
20.0
.0032
.0047
.0052
.0070
.0024
.0049
.0050
.0069
.0140
.0088
30.0
.0021
.0036
.0036
.0040
.0022
.0032
.0035
.0037
.0079
.0043
50.0
.0020
.0024
.0026
.0023
.0020
.0020
.0025
.0030
.0036
.0028
Notes: DCR and impedance based on 100% rated current applied and stablized a minimum of one hour.
Tolerance: .02 amperes to 2.5 amperes, ± 20%; 2.6 amperes to 20 amperes, ± 25%; 21 amperes to 50 amperes, ± 50%. Consult factory for special values and for coil
impedance of delays not shown
PERCENTAGE OF RATED CURRENT VS TRIP TIME IN SECONDS AT +25°C
Delay
100%
125% (Note A)
150%
200%
400%
600%
800%
1000%
40
No Trip
May Trip
.040 Max.
.035 Max.
.030 Max.
.025 Max.
.020 Max.
.018 Max.
41
No Trip
May Trip
.5 to 8
.15 to 1.9
.02 to .4
.006 to .25
.004 to .1
.004 to .05
42
No Trip
May Trip
5 to 70
2.2 to 25
.40 to 5
.012 to 2
.006 to .2
.006 to .15
49
No Trip
.150 Max.
.100 Max.
.032 Max.
.020 Max.
.020 Max.
.020 Max.
.020 Max.
43 & 400
No Trip
May Trip
35 to 350
12 to 120
1.5 to 20
.1 to 4
.01 to .250
.009 to .100
50
No Trip
May Trip
.032 Max.
.024 Max.
.020 Max.
.018 Max.
.016 Max.
.015 Max.
51
No Trip
.5 to 6.5
.3 to 3
.1 to 1.2
.031 to 5
.011 to .25
.004 to .1
.004 to .08
52
No Trip
2 to 60
1.8 to 30
1 to 10
.15 to 2
.04 to 1
.008 to .5
.006 to .1
59
No Trip
.100 Max.
.070 Max
.032 Max.
.020 Max.
.020 Max.
.020 Max.
.020 Max.
53 & 500
No Trip
80 to 700
40 to 400
15 to 150
2 to 20
.7 to 10
.1 to 3
.010 to .100
60
No Trip
May Trip
.040 Max.
.035 Max.
.030 Max.
.025 Max.
.020 Max.
.018 Max.
61
No Trip
.7 to 12
.35 to 7
130 to 3
.030 to 1
.015 to .3
.01 to .15
.008 to .1
62
No Trip
10 to 120
6 to 60
2 to 20
.2 to 3
.02 to 2
.015 to .8
.01 to .25
64
No Trip
.7 to 10
.35 to 6
.15 to 3
.05 to .6
.025 to .3
.020 to .22
.015 to .15
65
No Trip
7 to 90
3 to 40
1 to 12
.2 to 3
.08 to 1
.03 to .7
.016 to .3
66
No Trip
50 to 700
30 to 400
10 to 150
1.5 to 20
.4 to 10
.05 to 3
.02 to 2
69
No Trip
.120 Max.
.100 Max.
.050 Max.
.022 Max.
.017 Max.
.017 Max.
.017 Max.
600
No Trip
80 to 700
45 to 400
15 to 150
2 to 20
.2 to 4
.025 to 1
.01 to .2
Notes: All trip curves and trip currents are specified with the protector mounted in the normal vertical position at ambient temperature of +25° C. Protectors do not
carry current prior to application of overload. A: Ratings above 30 amps may deviate from the above limits by approximately 10% (130% for delay 49).
DUAL FREQUENCY (50/60HZ) PERCENTAGE OF RATED CURRENT VS TRIP TIME IN SECONDS AT +25°C
Delay
100%
135%
150%
200%
400%
600%
800%
1000%
71
No Trip
.4 to 14
.2 to 7
.1 to 3
.027 to 1
.015 to .3
.01 to .15
.008 to .1
72
No Trip
7 to 130
3 to 60
1.3 to 20
.085 to 3
.02 to 2
.015 to .8
.01 to .26
73
No Trip
50 to 700
30 to 400
10 to 150
.8 to 20
.14 to 4
.025 to 1
.01 to .26
INRUSH PULSE TOLERANCE
Inrush Pulse Tolerance
It can be seen that the 64, 65 and 66 delays have a high inrush
capability and for most applications an inertia wheel would not
be required. Pulse tolerance is defined as a single pulse of half
sine wave peak current amplitude of 8 milliseconds duration that
will not trip the circuit breaker.
Delay
Pulse Tolerance
61, 62
10 times rated current (approx)
61F, 62F
20 times rated current (approx)
64, 65, 66
64F, 65F, 66F
35 times rated current (approx)
Note: These limits do not apply to dual coil and tapped coil units
DELAY CURVES (TYP)
50/60Hz Delay Curves (typ)
A choice of delays is offered for DC, 50/60Hz, and 400 Hz
applications. Delays 40, 50, 60, 49, 59 and 69 provide fast-acting,
instantaneous trip and are often used to protect sensitive
electronic equipment (not recommended where known inrush
exists). Delays 41, 51, 61 and 71 have a short delay for general
purpose applications. Delays 42, 52 and 62 are long enough to
start certain types of motors and most transformer and capacitor
loads. Delays 43, 53 and 63 are long delays for special motor
applications at 400Hz DC and 50/60Hz.
10000
10000
DELAY 60
1000
100
10
MAY TRIP
10
TIME IN SECONDS
TIME IN SECONDS
100
1
1
.1
.1
.01
.01
.001
125
DELAY 61
MAY TRIP
1000
300
400
500
600
700
PERCENT OF RATED CURRENT
800
900
1000
.001
125
300
400
500
600
700
800
900
1000
APG/UPG/IPG
10000
100
TIME IN SECONDS
DELAY 65
MAY TRIP
1000
10
1
.1
.01
.001
1000
1
500
600
700
800
900
1000
900
1000
900
1000
DELAY 66
1
.1
.1
.01
.01
125
300
400
500
600
700
800
900
1000
.001
10000
100 150 200
125
300
400
500
600
700
800
10000
DELAY 64
1000
100
TIME IN SECONDS
10
1
.1
MAY TRIP
10
DELAY 69
1000
MAY TRIP
100
TIME IN SECONDS
400
10
10
1
.1
.01
.001
300
100
TIME IN SECONDS
100
TIME IN SECONDS
DELAY 62
MAY TRIP
1000
100 150 200
135
MAY TRIP
10000
10000
.001
125
300
400
500
600
700
800
900
1000
.001
125
300
400
500
600
700
800
DC Delay Curves (typ)
10000
DELAY 52
MAY TRIP
1000
TIME IN SECONDS
100
10
1
.1
.01
.001
1000
500
600
700
800
900
1000
900
1000
900
1000
DELAY 53
10
MAY TRIP
10
TIME IN SECONDS
1
1
.1
.1
.01
.01
125
300
400
500
600
700
800
900
1000
.001
10000
100 150 200
125
300
400
500
600
700
800
10000
DELAY 51
1000
DELAY 59
1000
100
10
MAY TRIP
10
TIME IN SECONDS
100
1
.1
1
MAY TRIP
TIME IN SECONDS
400
100
100
TIME IN SECONDS
300
MAY TRIP
DELAY 50
1000
.1
.01
.001
100 150 200
125
10000
10000
.001
125
300
400
500
600
700
800
900
1000
.001
125
300
400
500
600
700
800
APG/UPG/IPG
400Hz Delay Curves (typ)
10000
100
TIME IN SECONDS
DELAY 42
MAY TRIP
1000
10
1
.1
.01
.001
1000
500
600
700
800
900
1000
900
1000
900
1000
DELAY 43
10
MAY TRIP
10
TIME IN SECONDS
1
1
.1
.1
.01
.01
125
300
400
500
600
700
800
900
1000
.001
10000
100 150 200
125
300
400
500
600
700
800
10000
DELAY 41
1000
DELAY 49
1000
100
10
TIME IN SECONDS
MAY TRIP
100
MAY TRIP
TIME IN SECONDS
400
100
100
TIME IN SECONDS
300
MAY TRIP
DELAY 40
1000
10
1
.1
1
.1
.01
.001
100 150 200
125
10000
10000
.001
125
300
400
500
600
700
800
900
1000
.001
130
300
400
500
600
700
800
Trip Free
Will trip open on overload, even when forcibly held in
the ON position.
Insulation Resistance
Not less than 100 megohms at 500Vdc.
Trip Indication
The operating handle moves positively to the OFF
position on overload.
Dielectric Strength
APG/UPG/IPG protectors withstand 1500 volts, 60Hz for 60
seconds between all electrically isolated terminals. Except
auxiliary switch terminals shall withstand 600 Volts at 60Hz.
Ambient Operation
APG/UPG protectors operate normally in temperatures
between –40°C and +85°C.
Endurance
Withstands 10,000 operations at rated voltage and current or
withstands 50 operations of 600% AC or 1000% DC rated
current at rated voltage followed by 6000 operations at rated
voltage and current, in accordance with UL 1077.
AUXILIARY SWITCH RATINGS (SILVER)
3.0 amps
120VAC
1.5 amps
32VDC
32VAC
32VDC
AUXILIARY SWITCH RATINGS (GOLD)
.100 amps
AGENCY APPROVALS
Voltage (Volts)
Rated Current (Amps)
Interrupting Capacity, Amps
Max Voltage
Frequency (Hz)
Phase
Min Poles
UL/CSA
UL1077 & CSA
Max Series Fuse
32
DC
1
.05 to 50
2500
none
65
DC
1
.05 to 30
2000
none
130
DC
2
.05 to 15
1000
none
120
50/60
1
1
.05 to 50
3600
200
120 / 240
50/60
1
2
.05 to 50
1000
none
240
50/60
1&3
1
.05 to 10
5000
40
250
50/60
1&3
1
.05 to 50
1000
none
250
50/60
1&3
1
.05 to 50
3650
80
277
50/60
1
1
.05 to 30
1000
120
277
50/60
1
1
.05 to 10
5000
40
125
400
1
1
.05 to 30
2000
none
240
400
1&3
1
.05 to 20
2100
80
250
400
1&3
1
.05 to 30
1000
none
250
400
1&3
1
.05 to 30
3500
125
277
400
1
1
.05 to 20
1000
80
Notes: Series fuse to be a branch-circuit UL approved type K-5 back-up fuse rated at not more than four times the rating of the highest-rated type UPG
(15 amps minimum)
APG/UPG/IPG
Moisture Resistance
Meets all the requirements of MIL-PRF-55629 when tested in
accordance with Method 106 of MIL-Std. 202.
APPROXIMATE WEIGHT PER POLE
APG/UPG/IPG
2.2
60.5
Salt Spray (Corrosion)
Meets requirements of MIL-PRF-55629 when tested in
accordance with Method 101 of MIL-Std. 202. All APG/UPG
protectors are constructed with stainless steel springs and
plated parts. In addition to meeting normal requirements for
moisture and salt spray resistance, the protector meets the
fungus resistance requirements of MIL-PRF-55629.
APGN/UPGN
3.0
76.2
Poles
One through four poles with the UPGH, one through three
poles with all other types.
MIL-PRF-55629 (APG)
Single, two and three pole versions, with and without the
auxiliary switch option, have been qualified to MIL-PRF-55629.
Construction
Series, shunt, relay, dual coil, tapped coil, voltage trip,
no-voltage trip, auxiliary switch, switch only. Various delays
and combinations.
Shock
Withstands 100G or more without tripping while carrying full
rated current per MIL-Std. 202, Method 213, Test Condition I.
Instant trip protectors are tested at 80% of rated current.
Vibration
Withstands 10G without tripping while carrying full rated
current per MIL-Std. 202, Method 204, Test Condition A. Instant
Series
Ounces
Grams
RECOMMENDED TORQUE SPECIFICATIONS
Component
Torque (in-lbs)
6-32 Mounting Inserts
6 to 8
M3 Mounting Screws
4 to 5
8-32 Screw Terminals
10 to 12
M4 Terminal Screws
10 to 12
10-32 Screw Terminals
14 to 15
M5 Screw Terminals
14 to 15
1/2 - 32 Mounting Bushing
30 to 35
Where applicable, mechanical support must be provide to the terminals when
applying torque
1
APG / UPG Decision Table - How to Order
The ordering code for APG/UPG circuit protectors may be
determined by following the steps in the decision tables
shown here.
Type
The coding given permits a self-assigning part number but
with certain limitations. Units with mixed ratings,
combinations of styles, or constructions not listed in the
third decision table, require a factory-assigned part
number. With these, it is suggested that order entry be by
description and/or drawings, and a part number will be
established. Additionally, it is standard policy to establish a
factory-assigned part number whenever a descriptive
drawing exists to provide cross reference, traceability and
manufacturing control.
When specifying a circuit protector for AC motor start or
high inrush applications, the peak amplitude and surge
duration should be specified for factory assistance in
rating selection.
For example, the following is the code for a single pole
UPG, quick-connect type terminal series unit with auxiliary
switch, designed for operation in a 50/60Hz circuit. It has a
short time delay and a rating of 20 amperes. A white
handle is specified by the seventh decision table.
To determine the ordering number for your particular APG/
UPG unit, simply follow the steps shown. You may use this
number to place an order or as a reference for further
questions you may have.
Notes:
A It is recommended that power leads be soldered to protectors
having quick-connect terminals for current trip ratings above 10
amperes.
B The standard current values for 100% of rated current are listed.
Please consult an Airpax office or sales representative for other
values.
C UL recognized and CSA certified applications above 30 amperes
are restricted to loads having a power factor of 75 minimum
and limited to 32Vdc only. Standard terminals on ratings over 30
amperes are 10-32 screw type.
D Four pole protectors are available only in the APGH/UPGH and
APG/UPG types. The APGH/UPGH four pole provides one handle
per pole, while the APG/UPG four pole has handles in the center
two poles only, for simplified mounting.
E Sub panel mount available in APGX/UPGX configuration only.
F When “A” is specified in the sixth decision in conjunction with
APG/UPG-6 type, metric screw terminals are supplied.
G If a circuit breaker is marked in this manner, it means 277V per
pole – single phase source. Thus, if a two or three pole unit is
marked 277V, all line terminals must be connected to the same
phase, assuming the 277V is taken from line to neutral of 3 phase
277/480V system.
First Decision
Type
Description
APG
One handle per unit
UPG
One handle per unit
UL Recognized and
CSA Certified
APGX
One rocker handle per unit
UPGX
unit UL Recognized and
CSA Certified
APGN
Panel seal
(one bat handle per unit)
UPGN
Panel seal (one bat handle
per unit) UL Recognized and
CSA Certified
APGH
One handle per pole
UPGH
One handle per pole
UL Recognized and
CSA Certified
APGHX
One rocker handle per pole
UPGHX
UL Recognized and
CSA Certified
2
Second Decision
Poles (Note A)
QuickConnect
Terminals
Screw
Terminals
Number
of poles
1
6
Single pole unit
11
66
Two pole unit
111
666
Three pole unit
1111
6666
Four pole unit
(Note D)
4
Third Decision
Fourth Decision
Hz and Delay
Internal Configuration
-40
400Hz 150% instant trip
-41
400Hz short delay
-42
400Hz long delay
-43*
400Hz motor start
-49
400Hz 130% instant trip
-50
DC 150% instant trip
-51
DC short delay
Shunt (up to 30 amperes only)
-52
DC long delay
Relay (up to 30 amperes only)
-53*
DC motor start
-59
DC 125% instant trip
-60
50/60Hz 150% instant trip
-61
50/60Hz short delay
-62
50/60Hz long delay
-600*
50/60Hz motor start delay
-64
50/60Hz, short delay
(high pulse)
-65
50/60Hz, long delay
(high pulse)
-66*
50/60Hz, motor start
(high pulse)
-69
50/60Hz 125% instant trip
-71
DC, 50/60Hz short delay
-72
DC, 50/60Hz long delay
-73*
DC, 50/60Hz motor start delay
-0
Switch only (omit 4th and
5th decisions)
-1
Series
-1REC4
Auxiliary switch*
.110 quick-connect
-1REG4
Auxiliary switch* (Gold
Contacts) .110 quick-connect
-1REC5
Auxiliary switch*
.187 quick-connect
-3
-4
*Only one auxiliary switch is normally supplied on two and three pole units.
Can be used for solder terminals also. Switch is located in the right-hand pole
(viewed from terminal end) unless otherwise specified. Multi-pole units with
mixed construction, poles numbered left to right when viewed from terminal
end.
Example:
UPG 1- 1REC4- 61- 203- 09
1
2
3
4
5
7
For addition of inertial delay, add an “F” to any delay
number. * Not available above 30 amperes.
5
APG/UPG/IPG
3
7
Seventh Decision
Handle/Actuator Color**
Toggle Handle Color †
-01
Black w/ white markings
-11
Yellow w/ black markings
-21
Red w/ white markings
-31
Blue w/ white warkings
-41
Green w/ white markings
-91
White w/ black markings
Rocker/Actuator Color
-00
Black w/o markings
-01
Fifth Decision
-02
Red w/o markings
Rated Current (Note B)
-05
Opaque white w/o markings
-08
Gray w/o markings
-09
Translucent white w/o markings
-21
-51
Opaque white w/ black markings
-81
Gray w/ black markings
-91
Translucent white w/ black markings
Current
Code
Ratings
(Amps)
Current
Code
Ratings
(Amps)
-101
.100
-103
10.0
-251
.250
-153
15.0
-501
.500
-203
20.0
-751
.750
-303
30.0
-102
1.0
-353
35.0*
-252
2.5
-403
40.0*
-502
5.0
-503
50.0*
-752
7.5
See page 122 for maximum voltage ratings. (*Note C)
Standard current ratings listed. For other ratings,
please consult factory.
6
Sixth Decision
Optional
-A
Metric thread mounting (Not
available on APGN/UPGN) (Note F)
-B
Sub panel mount (Note E)
-C
277Vac 50/60Hz (Note G)
-H
International handle markings
One or more descriptions may be used as required. If
this table is not used, go directly to the seventh decision.
**Not available for bat handle.
†Unmarked handles are available. Please consult factory.
IPG Decision Table - How to Order
The ordering code for IPG circuit protectors may be
shown here.
a factory-assigned part number whenever a descriptive
duration should be specified for factory assistance in rating
selection.
IPG, quick-connect type terminal series unit with auxiliary
short time delay and a rating of 20 amperes. Metric
mounting inserts and a white handle are also specified.
To determine the ordering number for your particular IPG
Notes:
A It is recommended that power leads be soldered to protectors having
push-on terminals for current trip ratings above 10 amperes.
B The standard current values for 100% of rated current are listed in the fifth
decision table. Please consult an Airpax office or sales representative for
other values.
C All IPG protectors meet normal requirements for moisture and salt spray
resistance.
D UL recognized and CSA certified applications above 30 amperes are
restricted to loads having a power factor of .75 minimum, and limited to
32Vdc only. VDE approval above 30 amperes is restricted to 32Vdc and
120Vac 50/60Hz. Standard terminals on ratings over 30 amperes are 10-32
screw type.
E When “A” is specified in the sixth decision in conjunction with IPG-6 type,
1
First Decision
Type
Type
Description
Std. Handle Color
IPG
Single pole with one
handle per unit (Not
available in multi-pole
configuration)
Black
IPGH
Multi-pole with
handle per pole
Black
2
Second Decision
Poles
Push-On
Terminals
Screw
Terminals
Number
of poles
1
6
Single pole
11
66
Two pole
111
666
Three pole
1111
6666
Four pole
3
Third Decision
5th decisions)
Series
Auxiliary switch*
.110 quick-connect
Auxiliary switch*
.187 quick-connect
three pole units. Switch is located in the right-hand pole
APG/UPG/IPG
4
5
Fourth Decision
Hz and Delay
Fifth Decision
Nominal Amperage Rating
-40
-41
400Hz short delay
-42
400Hz long delay
-43*
400Hz motor start
-49
-50
DC 150% instant delay
-51
DC short delay
-52
DC long delay
-53*
DC motor start
-59
-60
-61
50/60Hz short delay
-62
50/60Hz long delay
-64
(high pulse)
-65
50/60Hz, long delay
(high pulse)
-66*
(high pulse)
-69
Current
Code
Ratings
(Amps)
Current
Code
Ratings
(Amps)
-101
.100
-103
10.0
-251
.250
-153
15.0
-501
.500
-203
20.0
-751
.750
-303
30.0
-102
1.0
-353
35.0*
-252
2.5
-403
40.0*
-502
5.0
-503
50.0*
-752
7.5
See page 122 for maximum voltage ratings. (*Note D)
6
For addition of inertial delay, add an “F” to any delay number.
Sixth Decision
Optional
-A
Example:
Metric thread mounting (Note E)
When this table is not used, table 7 may be substituted
and U.S. thread will be supplied.
IPG 1 - 1REC4 - 61 - 203 - A - 00 - V
1
2
3
4
5
6
7 V
7
Seventh Decision
IPG and IPGH
Toggle Handle Color
V = VDE Approved
The shaded areas denote VDE approval options.
This approval requires the addition of a V at the end
of the part number. The V will be added to any part
number formed entirely from shaded decisions.
If non-shaded areas are selected, the unit will not
be VDE approved, but other approvals still apply.
-00
Black
-10
Yellow
-20
Red
-30
Blue
-40
Green
-90
White
