PCB-XXR-NT
PCB-XXR-NT
    AK-NORDGMBH
    无线转串口 适配器卡 RS-232,RS-485
PCB-XXR-NT 数据手册
WLAN-MODULE-XXR WLAN – Module to integrate serial terminal equipments in a network Using the WLAN-MODULE-XXR you can now integrate two serial terminal equipments in a network by a wireless connection. This device server offers two RS232 or RS485 interfaces, WLAN and Ethernet10/100 and is equipped with all necessary connections. The integrated Wireless LAN offers all necessary protocols such as IEEE802.11b, IEEE802.11g as well as IEEE802.11n (Draft 3.0) to allow you an easy and simple integration. In addition, all necessary and state-of-the-art security functions such as WEP 64/128 Bit, WPA1 and WPA2 Personal have been integrated and hence offer you the highest security standard. The device is equipped with an external antenna and offer max. 150MBps thus there are no limits with regards to its performance. Its flexibility and diversity is completed by the various additional functions and emulations of the AK-NORD TCP/IP-STACK as well as by the robust metal housing. AK-Nord EDV Vertriebs. GmbH, Stormstrasse 8, 25524 Itzehoe, Phone: +49 (0) 4821/ 8040350, Fax: +49 (0) 4821/ 4083024 Technical modifications are reserved. All mentioned trademarks are registered trademarks of the manufacturers. Internet: www.ak-nord.de , E- MAIL : vertrieb@ak-nord.de Hardware description Supported OS 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. Rear side Microsoft Windows 7 Microsoft Windows Vista Microsoft Windows 2003 Microsoft Windows 2000 Microsoft Windows XP Microsoft Windows NT 4.0 Microsoft Windows ME Microsoft Windows 98 Microsoft W95 Linux UNIX Supported protocols Technical Data • Dimensions: 100 x 28 x 110 mm (WxHxL) • Temperature range: -10°C .. + 65°C • EMC (electromagnetic compatibility): Radio interference and interference immunity • SD-CARD-slot (internal) Up to 4 GBytes FAT16 PC-compatible RS232 Baud rate : DataBits: Parity: Signals : • Power supply: 5 Volt 380 mA Note All voltages are switchable to the Pin 9 of the serial interface by using internal jumpers. • • RS485 Baud rate : DataBits: Parity: Signals : • • up to 230Kbaud 7,8 Odd,Even,None Mark,Space TXD, RXD, RTS, CTS, DSR, DTR, DCD,RI, GND up to 230Kbaud 7,8 Odd,Even,None Mark,Space TXD, RXD, GND Ethernet (MDIX) 10 Half Duplex 10 Full Duplex 100 Half Duplex 100 Full Duplex AutoSensing WLAN 1T1R 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. Management 1. 2. 3. • IEEE802.11b: • IEEE802.11g: • IEEE802.11n: • IEEE 802.11d: • IEEE 802.11e: • IEEE802.11h: • IEEE 802.11i: • IEEE802.11j: ADHOC / INFRA – Mode Fast-Roaming AutoConnection with Wi-Fi Protected Setup (WPS-PBC) Hardware WEP, TKIP, AES Engine WEP 64Bit and 128Bit up to 4 Keys 1, 2, 5.5, 11Mbps 6, 9, 12, 24, 36, 48, 54Mbps (Draft 3.0) up to 150Mbps legacy, mixed and green field modes, supports 20/40 MHz band width MCS0- 7 (150Mbps PHY rate support) World Mode (US, CA, EU, JP) Wi-Fi WMM-QoS “Quality of Service” Wi-Fi WMM-PS "Power Save" DFS (Dynamic Frequency Selection) TPC (Transmission Power Control) WPA1- and WPA2-Personal Operation in Japan Telnet Browser serial Interface Emulations and functions WLAN - Specification • Functions IP TCP UDP FTP TFTP ICMP ARP SNMP LPR DHCP BOOTP DNS TELNET HTML http DYNDNS SMTP POP3 SYSLOG • • • • • • • • • • • • • • • Modem Emulation Connect-On-Data Auto-Connect Tunnel-Mode DYNDNS-Client FTP-Server LPR-Server TTL – IO 2MB Flashdrive Flash-File-System SD- and DF-CARD E-Mail – Client TCP/UDP -Client TCP/UDP –Server SYSLOG-Client AK-Nord EDV Vertriebs. GmbH, Stormstrasse 8, 25524 Itzehoe, Phone: +49 (0) 4821/ 8040350, Fax: +49 (0) 4821/ 4083024 Technical modifications are reserved. All mentioned trademarks are registered trademarks of the manufacturers. Internet: www.ak-nord.de , E- MAIL : vertrieb@ak-nord.de
PCB-XXR-NT 价格&库存
很抱歉,暂时无法提供与“PCB-XXR-NT”相匹配的价格&库存,您可以联系我们找货
PCB-XXR-NT
  • 1+1230.341181+159.37222
