SW Series • Inductors for National's 50kHz Simple Switcher TM
Compatible with National Semiconductor's Simple SwitcherTM
Part Number's LM2574, LM2475 and LM2576
Features
High energy storage with minimum saturation
High stability from no load to full load
Available in both SMD and TH versions
Manufactured in ISO-9001 approved facility
Operating temperature range: -40°C to +125°C
Electrical Specifications at 25°C ambient
Rated
Current
(IDC)
LN (µH)
Typical *
LO (µH)
± 20%
N o D C L o ad
ETOP
(V-µSec)
Max.
DCR
(Ohms)
Max.
"C"
"S"
" T"
SW_-3.0-47
3.0
47
38
90
0.05
2
5
5
SWC-3.0-68
3.0
68
55
90
0.02
4
SWC-3.0-100
3.0
100
91
90
0.04
4
SW_-2.0-150
2.0
150
130
90
0.10
4
6
3
6
6
Part Number
SW_-1.4-220
1.4
220
230
90
0.38
SW_-1.4-220
1.4
220
176
90
0.14
P ackag e
5
SW_-0.9-330
0.9
330
302
90
0.74
SW_-0.9-330
0.9
330
267
90
0.18
3
5
SWC-0.64-470
0.64
470
426
90
0.16
4
SW_-0.85-680
0.85
680
657
90
1.25
SWC-3.0-150
3.0
150
136
200
0.10
5
" F"
"V"
5
2
2
5
2
2
5
2
2
4
SWC-3.0-220
3.0
220
167
200
0.07
5
SWC-3.0-330
3.0
330
292
200
0.15
5
SWC-2.0-470
2.0
470
369
200
0.17
5
SWC-1.3-680
"B"
1.3
680
562
200
0.20
5
SWC-0.95-1000
0.95
1000
762
200
0.24
5
SWB-0.62-1500
0.62
1500
1150
200
1.00
8
SWB-0.42-2200
0.42
2200
1730
200
1.80
8
Notes:
1)
Inductance will be typical for theDCI and ETOP
values listed above.
2)
No load Inductance will be measured @
20kHz, 10mVrms.
Simple SwitcherTM is a trademark of National
3)
Semiconductor Corporation.
Ordering Key
SW C - 3.0 - 47
Inductance Value in µH
Current Rating (Amps)
Mounting Style - Specify the appropriate suffix
C = Clip Mount
S = Surface Mount (S5 or S6)
T = Low Profile TH Mount
B = Base Mount
F = Flat Encapsulated
V = Vertical Encapsulated
Basic Series Designation
AMGIS, LLC * 10830 Kinghurst Dr. Houston, TX 77099
Phone: 832-775-1319 * Fax: 281-933-9067* email: sales@amgistoroids.com
Toll Free: 877-762-6447 * www.amgistoroids.com
Mounting Styles • SW Series • Low Cost Toroidal Inductors
Type "B" - Vertical Mount
Type "V" - Vertical Mount - Size 2
AMGIS
SWV-XX-XXX
Date Code
Schematic
1.38 Max
(35.0)
0.394
(10.0)
1
0.031
(Ø 0.80)
AMGIS
2
SWB-XX-XXX
Date Code
2.00
(5.1)
Suggested Pad
Layout
1
0.591
(15.0)
0.071
(1.80)
0.80
(20.3)
0.598
(15.2)
0.709
18.0
Type "F" - Flat Mount - Size 2
0.055
(1.40)
1.10
(27.9)
1.45
(36.8)
0.043
(1.10)
0.394
(10.0)
0.598
(15.2)
0.094
(2.40)
2
2
0.512
(13.0)
0.901
(22.9)
1
AMGIS
SWF-XX-XXX
Date Code
Type SWT -Through Hole Mount
Suggested Pad
Layout
(Top Side View)
2
0.600
(15.24)
AMGIS
0.600
(15.24)
0.157±0.039
(4.0 ±1.0)
0.591
(15.0)
0.901
(22.9)
0.157±0.039
(4.0 ±1.0)
0.701
(17.8)
Suggested Pad
Layout
(Top Side View)
0.709
(18.0)
Date Code
SWT-xxx-xx
0.422
(10.71)
0.591
(15.0)
0.071
(1.80)
0.043
(1.10)
0.600
(15.24)
0.138
3.50
0.394
(10.0)
0.138±0.01
(3.5 ±0.3)
0.394
(10.0)
0.400
(10.16)
1
0.400
(10.16)
0.669
(17.0)
0.394
(10.0)
0.67
(17.0)
0.024 x 0.035
(0.60 x 0.88)
Suggested Pad
Layout
(Top Side View)
0.49
(12.5)
0.591 0.69
(15.0) (17.5)
0.059
(1.50)
0.035
(0.90)
Type SWS - Surface Mount
B
D
Type SWC - Clip Mount
D
A
Schematic
Pad Width
S6
S1 - S5
0.079
0.059
(2.00)
(1.50)
AMGIS
1
X
E
Date Code
SWS-xxx-xx
Suggested Pad
Layout
Schematic
1/2
c
1
C
2
Mounting
Style
2
Suggested Pad
Layout
0.071
E
(1.80)
E
D
0.138
(3.50)
0.047
(1.20)
C
Surface Coplanarity will be
很抱歉,暂时无法提供与“SWB-0.42-2200”相匹配的价格&库存,您可以联系我们找货
