10 INCH-GF-CGRADE-MINI 数据手册
Miniature Pressure Sensors
C-Grade
Pressure Sensors
Features
all sensors
• 0 to 4” H2O to 0 to 100 PSI Pressure Ranges
• 1 % linearity version
• Temperature Compensated
• Calibrated Zero and Span
Applications
• Medical Instrumentation
• Environmental Controls
• HVAC
General Description
e www.allsensors.com
The Miniature series pressure sensors are based upon a proprietary technology to reduce the size of the sensor and
yet maintain a high level of performance. This model provides a calibrated millivolt output with superior output
offset characteristics. Output offset errors due to change in temperature, stability to warm-up, stability to long time
period, and position sensitivity are all significantly reduced when compared to conventional compensation methods. In addition the sensor utilizes a silicon, micromachined, stress concentration enhanced structure to provide a
f 408 225 2079
very linear output to measured pressure.
These calibrated and temperature compensated sensors give an accurate and stable output over a wide temperature
range. This series is intended for use with non-corrosive, non-ionic working fluids such as air, dry gases and the
like. The C-GRADE is a lowest cost version of the millivolt output pressure sensors.
all dimensions in inches
Equivalent Circuit
Single Pressure Port
No Pressure Port
Marking:
right dot: Silver C-Grade
left dot:
L04: white
L10: yellow
0.3: pink
1.0: green
05: blue
15: purple
30: orange
100: brown
Input Resittance
Dual Pressure Port
5.0 k ohm
Output Resistance 3.0 k ohm
Approvals
MKT
As Is
DATE
With Change
MFG
As Is
All Sensors
DATE
With Change
ENG
As Is
DS-0106 Rev B
DATE
With Change
QA
As Is
DATE
With Change
a 16035 Vineyard Blvd. Morgan Hill, CA 95037
Physical Dimensions
p 408 225 4314
The output of the device is ratiometric to the supply voltage and operation from any D.C. supply voltage.
Pressure Sensor Characteristics Maximum Ratings
Environmental Specifications
Supply Supply Voltage VS
16 Vdc
Temperature Ranges
Common-mode pressure
50 psig
Compensated
250°C
Lead Temperature
(soldering 2-4 sec.)
0 to 70° C
Operating
-25 to 85° C
Storage
-40 to 125° C
Humidity Limits
0 to 95% RH
(non condensing)
Standard Pressure Ranges
No Prssure Port
Part Number
Operating Pressure
Dual Pressure Port
Part Number
Part Number
Proof Pressure
4 INCH-G-CGRADE-MINI
0 - 4 “H2O
4 INCH-GF-CGRADE-MINI
4 INCH-D-CGRADE-MINI
3 PSI
0.3 PSI-G-CGRADE-MINI
0 - O.3 PSI
0.3 PSI-GF-CGRADE-MINI
0.3 PSI-D-CGRADE-MINI
3 PSI
10 INCH-D-CGRADE-MINI
5 PSI
10 INCH-G-CGRADE-MINI
0 - 10 “H2O
1 PSI-G-CGRADE-MINI
0 - 1 PSI
1 PSI-GF-CGRADE-MINI
1 PSI-D-CGRADE-MINI
10 PSI
5 PSI-G-CGRADE-MINI
0 - 5 PSI
5 PSI-GF-CGRADE-MINI
5 PSI-D-CGRADE-MINI
20 PSI
15 PSI-A-CGRADE-MINI
0 - 15 PSIA
15 PSI-AF-CGRADE-MINI
15 PSI-G-CGRADE-MINI
0-15 PSI
15 PSI-GF-CGRADE-MINI
30 PSI-A-CGRADE-MINI
0-30 PSIA
30 PSI-AF-CGRADE-MINI
30 PSI-G-CGRADE-MINI
0-30 PSI
30 PSI-GF-CGRADE-MINI
100 PSI-G-CGRADE-MINI
0-100 PSI
100 PSI-GF-CGRADE-MINI
60 PSI
60 PSI
15 PSI-D-CGRADE-MINI
60 PSI
60 PSI
30 PSI-D-CGRADE-MINI
150 PSI
Performance Characteristics for 4 INCH-G-CGRADE-MINI
Minimum
Nominal
Maximum
Units
Operating Range, differential pressure
4.0
“H2O
Output Span, note 5
23
25
27
mV
Offset Voltage @ zero differential pressure
±1.5
mV
Offset Temperature Shift (0°C-50°C), note 2
±1.5
mV
Linearity, hysteresis error, note 4
0.5
1.0
%fs
Span Shift (0°C-50°C), note 2
±2
%fs
Parameter, note 1
Performance Characteristics for 10 INCH-G-CGRADE-MINI
Minimum
Nominal
Maximum
Units
10.0
“H2O
Output Span, note 5
18
mV
±1.5
mV
Offset Temperature Shift (0°C-70°C), note 2
±1.5
mV
0.5
1.0
%fs
Span Shift (0°C-70°C), note 2
±2
%fs
Parameter, note 1
Miniature C-grade Pressure Sensors
0.3
PSI
Output Span, note 5
18
20.0
22
mV
±1
mV
±1
mV
0.5
1
%fs
±2
%fs
Minimum
Nominal
Maximum
Units
1.0
PSI
Output Span, note 5
16
18
mV
±1
mV
±1
mV
0.5
1.0
%fs
±2
%fs
Minimum
Nominal
Maximum
Units
5.0
PSI
Output Span, note 5
57
60
63
mV
±1
mV
±1
mV
0.5
1.0
%fs
±2
%fs
Minimum
Nominal
Maximum
Units
Operating Range, gage pressure
15.0
PSI
Output Span, note 5
85
90.0
95
mV
Offset Voltage @ zero gage pressure
±1
mV
±1
mV
0.5
1.0
%fs
±2
%fs
Performance Characteristics for 1 PSI-G-CGRADE-MINI
Parameter, note 1
Performance Characteristics for 5 PSI-G-CGRADE-MINI
Parameter, note 1
Performance Characteristics for 15 PSI-G-CGRADE-MINI
Parameter, note 1
All Sensors
DS-0106 Rev B
Units
f 408 225 2079
Maximum
p 408 225 4314
Nominal
Minimum
Parameter, note 1
all sensors
Performance Characteristics for 0.3 PSI-G-CGRADE-MINI
Performance Characteristics for 15 PSI-A-CGRADE-MINI
Minimum
Nominal
Maximum
Units
Operating Range, absolute pressure
15.0
PSIA
Output Span, note 5
85
90.0
95
mV
Offset Voltage @ zero absolute pressure
±1
mV
±1
mV
0.5
1.0
%fs
±2
%fs
Minimum
Nominal
Maximum
Units
30.0
PSI
Output Span, note 5
85
90.0
95
mV
Offset Voltage @ zero pressure
±1
mV
±1
mV
0.5
1.0
%fs
±2
%fs
Minimum
Nominal
Maximum
Units
30.0
PSIA
Output Span, note 5
85
90.0
95
mV
±1
mV
±1
mV
0.5
1.0
%fs
±2
%fs
Parameter, note 1
Performance Characteristics for 30 PSI-G-CGRADE-MINI
Parameter, note 1
Performance Characteristics for 30 PSI-A-CGRADE-MINI
Parameter, note 1
Performance Characteristics for 100 PSI-G-CGRADE-MINI
Minimum
Nominal
Maximum
Units
100.0
PSI
Output Span, note 5
95
100.0
105
mV
±1
mV
±1
mV
0.5
1.0
%fs
±2
%fs
Parameter, note 1
Specification Notes
note 1: All parameters are measured at 12.0 volt excitation, for the nominal full scale pressure and room temperature unless
otherwise specified. Pressure measurements are with positive pressure applied to Port B.
note 2: Shift is relative to 25°C.
note 3: Shift is within the first hour of excitation applied to the device.
note 4: Measured at one-half full scale rated pressure using best straight line curve fit.
note 5: The voltage added to the offset voltage at full scale pressure.
Pressure Response: for any pressure applied the response time to get to 90% of pressure applied is typically less
than 100 useconds.
