5 PSI-GF-CGRADE-MINI
    ALLSENSORS
    SIP-4
    排气式压力计 压力 压力传感器5PSI(34.47kPa) 公型 - 0.18"(4.57mm)管 0mV ~ 60mV(12V) 4-SIP 模块
5 PSI-GF-CGRADE-MINI 数据手册
Miniature Pressure Sensors C-Grade Pressure Sensors Features all sensors • 0 to 4” H2O to 0 to 100 PSI Pressure Ranges • 1 % linearity version • Temperature Compensated • Calibrated Zero and Span Applications • Medical Instrumentation • Environmental Controls • HVAC General Description e www.allsensors.com The Miniature series pressure sensors are based upon a proprietary technology to reduce the size of the sensor and yet maintain a high level of performance. This model provides a calibrated millivolt output with superior output offset characteristics. Output offset errors due to change in temperature, stability to warm-up, stability to long time period, and position sensitivity are all significantly reduced when compared to conventional compensation methods. In addition the sensor utilizes a silicon, micromachined, stress concentration enhanced structure to provide a f 408 225 2079 very linear output to measured pressure. These calibrated and temperature compensated sensors give an accurate and stable output over a wide temperature range. This series is intended for use with non-corrosive, non-ionic working fluids such as air, dry gases and the like. The C-GRADE is a lowest cost version of the millivolt output pressure sensors. all dimensions in inches Equivalent Circuit Single Pressure Port No Pressure Port Marking: right dot: Silver C-Grade left dot: L04: white L10: yellow 0.3: pink 1.0: green 05: blue 15: purple 30: orange 100: brown Input Resittance Dual Pressure Port 5.0 k ohm Output Resistance 3.0 k ohm Approvals MKT As Is DATE With Change MFG As Is All Sensors DATE With Change ENG As Is DS-0106 Rev B DATE With Change QA As Is DATE With Change a 16035 Vineyard Blvd. Morgan Hill, CA 95037 Physical Dimensions p 408 225 4314 The output of the device is ratiometric to the supply voltage and operation from any D.C. supply voltage. Pressure Sensor Characteristics Maximum Ratings Environmental Specifications Supply Supply Voltage VS 16 Vdc Temperature Ranges Common-mode pressure 50 psig Compensated 250°C Lead Temperature (soldering 2-4 sec.) 0 to 70° C Operating -25 to 85° C Storage -40 to 125° C Humidity Limits 0 to 95% RH (non condensing) Standard Pressure Ranges No Prssure Port Part Number Operating Pressure Single Pressure Port Dual Pressure Port Part Number Part Number Proof Pressure 4 INCH-G-CGRADE-MINI 0 - 4 “H2O 4 INCH-GF-CGRADE-MINI 4 INCH-D-CGRADE-MINI 3 PSI 0.3 PSI-G-CGRADE-MINI 0 - O.3 PSI 0.3 PSI-GF-CGRADE-MINI 0.3 PSI-D-CGRADE-MINI 3 PSI 10 INCH-GF-CGRADE-MINI 10 INCH-D-CGRADE-MINI 5 PSI 10 INCH-G-CGRADE-MINI 0 - 10 “H2O 1 PSI-G-CGRADE-MINI 0 - 1 PSI 1 PSI-GF-CGRADE-MINI 1 PSI-D-CGRADE-MINI 10 PSI 5 PSI-G-CGRADE-MINI 0 - 5 PSI 5 PSI-GF-CGRADE-MINI 5 PSI-D-CGRADE-MINI 20 PSI 15 PSI-A-CGRADE-MINI 0 - 15 PSIA 15 PSI-AF-CGRADE-MINI 15 PSI-G-CGRADE-MINI 0-15 PSI 15 PSI-GF-CGRADE-MINI 30 PSI-A-CGRADE-MINI 0-30 PSIA 30 PSI-AF-CGRADE-MINI 30 PSI-G-CGRADE-MINI 0-30 PSI 30 PSI-GF-CGRADE-MINI 100 PSI-G-CGRADE-MINI 0-100 PSI 100 PSI-GF-CGRADE-MINI 60 PSI 60 PSI 15 PSI-D-CGRADE-MINI 60 PSI 60 PSI 30 PSI-D-CGRADE-MINI 150 PSI Performance Characteristics for 4 INCH-G-CGRADE-MINI Minimum Nominal Maximum Units Operating Range, differential pressure -- 4.0 -- “H2O Output Span, note 5 23 25 27 mV Offset Voltage @ zero differential pressure -- -- ±1.5 mV Offset Temperature Shift (0°C-50°C), note 2 -- -- ±1.5 mV Linearity, hysteresis error, note 4 -- 0.5 1.0 %fs Span Shift (0°C-50°C), note 2 -- -- ±2 %fs Parameter, note 1 Performance Characteristics for 10 INCH-G-CGRADE-MINI Minimum Nominal Maximum Units Operating Range, differential pressure -- 10.0 -- “H2O Output Span, note 5 18 20 22 mV Offset Voltage @ zero differential pressure -- -- ±1.5 mV Offset Temperature Shift (0°C-70°C), note 2 -- -- ±1.5 mV Linearity, hysteresis error, note 4 -- 0.5 1.0 %fs Span Shift (0°C-70°C), note 2 -- -- ±2 %fs Parameter, note 1 Miniature C-grade Pressure Sensors Operating Range, differential pressure -- 0.3 -- PSI Output Span, note 5 18 20.0 22 mV Offset Voltage @ zero differential pressure -- -- ±1 mV Offset Temperature Shift (0°C-70°C), note 2 -- -- ±1 mV Linearity, hysteresis error, note 4 -- 0.5 1 %fs Span Shift (0°C-70°C), note 2 -- -- ±2 %fs Minimum Nominal Maximum Units Operating Range, differential pressure -- 1.0 -- PSI Output Span, note 5 16 18 20 mV Offset Voltage @ zero differential pressure -- -- ±1 mV Offset Temperature Shift (0°C-70°C), note 2 -- -- ±1 mV Linearity, hysteresis error, note 4 -- 0.5 1.0 %fs Span Shift (0°C-70°C), note 2 -- -- ±2 %fs Minimum Nominal Maximum Units Operating Range, differential pressure -- 5.0 -- PSI Output Span, note 5 57 60 63 mV Offset Voltage @ zero differential pressure -- -- ±1 mV Offset Temperature Shift (0°C-70°C), note 2 -- -- ±1 mV Linearity, hysteresis error, note 4 -- 0.5 1.0 %fs Span Shift (0°C-70°C), note 2 -- -- ±2 %fs Minimum Nominal Maximum Units Operating Range, gage pressure -- 15.0 -- PSI Output Span, note 5 85 90.0 95 mV Offset Voltage @ zero gage pressure -- -- ±1 mV Offset Temperature Shift (0°C-70°C), note 2 -- -- ±1 mV Linearity, hysteresis error, note 4 -- 0.5 1.0 %fs Span Shift (0°C-70°C), note 2 -- -- ±2 %fs Performance Characteristics for 1 PSI-G-CGRADE-MINI Parameter, note 1 Performance Characteristics for 5 PSI-G-CGRADE-MINI Parameter, note 1 Performance Characteristics for 15 PSI-G-CGRADE-MINI Parameter, note 1 All Sensors DS-0106 Rev B e www.allsensors.com Units f 408 225 2079 Maximum p 408 225 4314 Nominal a 16035 Vineyard Blvd. Morgan Hill, CA 95037 Minimum Parameter, note 1 all sensors Performance Characteristics for 0.3 PSI-G-CGRADE-MINI Performance Characteristics for 15 PSI-A-CGRADE-MINI Minimum Nominal Maximum Units Operating Range, absolute pressure -- 15.0 -- PSIA Output Span, note 5 85 90.0 95 mV Offset Voltage @ zero absolute pressure -- -- ±1 mV Offset Temperature Shift (0°C-70°C), note 2 -- -- ±1 mV Linearity, hysteresis error, note 4 -- 0.5 1.0 %fs Span Shift (0°C-70°C), note 2 -- -- ±2 %fs Minimum Nominal Maximum Units Operating Range, gage pressure -- 30.0 -- PSI Output Span, note 5 85 90.0 95 mV Offset Voltage @ zero pressure -- -- ±1 mV Offset Temperature Shift (0°C-70°C), note 2 -- -- ±1 mV Linearity, hysteresis error, note 4 -- 0.5 1.0 %fs Span Shift (0°C-70°C), note 2 -- -- ±2 %fs Minimum Nominal Maximum Units Operating Range, absolute pressure -- 30.0 -- PSIA Output Span, note 5 85 90.0 95 mV Offset Voltage @ zero absolute pressure -- -- ±1 mV Offset Temperature Shift (0°C-70°C), note 2 -- -- ±1 mV Linearity, hysteresis error, note 4 -- 0.5 1.0 %fs Span Shift (0°C-70°C), note 2 -- -- ±2 %fs Parameter, note 1 Performance Characteristics for 30 PSI-G-CGRADE-MINI Parameter, note 1 Performance Characteristics for 30 PSI-A-CGRADE-MINI Parameter, note 1 Performance Characteristics for 100 PSI-G-CGRADE-MINI Minimum Nominal Maximum Units Operating Range, gage pressure -- 100.0 -- PSI Output Span, note 5 95 100.0 105 mV Offset Voltage @ zero pressure -- -- ±1 mV Offset Temperature Shift (0°C-70°C), note 2 -- -- ±1 mV Linearity, hysteresis error, note 4 -- 0.5 1.0 %fs Span Shift (0°C-70°C), note 2 -- -- ±2 %fs Parameter, note 1 Specification Notes note 1: All parameters are measured at 12.0 volt excitation, for the nominal full scale pressure and room temperature unless otherwise specified. Pressure measurements are with positive pressure applied to Port B. note 2: Shift is relative to 25°C. note 3: Shift is within the first hour of excitation applied to the device. note 4: Measured at one-half full scale rated pressure using best straight line curve fit. note 5: The voltage added to the offset voltage at full scale pressure. Pressure Response: for any pressure applied the response time to get to 90% of pressure applied is typically less than 100 useconds. Miniature C-grade Pressure Sensors
5 PSI-GF-CGRADE-MINI 价格&库存
很抱歉,暂时无法提供与“5 PSI-GF-CGRADE-MINI”相匹配的价格&库存,您可以联系我们找货
