1 INCH-D1-BASIC
1 INCH-D1-BASIC
    ALLSENSORS
    SIP-4
    SENSOR PRESSURE DIFF 1" H2O 4SIP
1 INCH-D1-BASIC 数据手册
Miniature Basic Pressure Sensors Offset Compensated Pressure Sensors Features all sensors • 0 to 1 “H2O to 0 to 30 “H2O Pressure Ranges • 0.5 % linearity • Offset Compensated Applications • Medical Instrumentation • Environmental Controls • HVAC General Description The Miniature BASIC series pressure sensors are based upon a proprietary technology to reduce the size of the sene www.allsensors.com sor and yet maintain a high level of performance. The technology is currently being patented. Output offset errors due to change in temperature, stability to warm-up, stability to long time period, and position sensitivity are all significantly reduced when compared to conventional compensation methods. In addition the sensor utilizes a silicon, micromachined, stress concentration enhanced structure to provide a very linear output to measured pressure. These offset compensated sensors give an accurate and stable output over a wide temperature range. This series is f 408 225 2079 intended for use with non-corrosive, non-ionic working fluids such as air, dry gases and the like. The output of the device is ratiometric to the supply voltage and operation from any D.C. supply voltage up to +6V is acceptable. Physical Dimensions Input Resittance 1.66 k ohm Output Resistance 1.66 k ohm TCR 2600 ppm/°C TCS -2200 ppm/°C. Approvals MKT As Is DATE With Change MFG As Is All Sensors DATE With Change ENG As Is DS-0105 Rev B DATE With Change QA As Is DATE With Change a 16035 Vineyard Blvd. Morgan Hill, CA 95037 p 408 225 4314 Equivalent Circuit Pressure Sensor Characteristics Maximum Ratings Environmental Specifications Supply Supply Voltage VS 6 Vdc Temperature Ranges Common-mode pressure 5 psig Compensated Lead Temperature (soldering 2-4 sec.) 250°C Operating -25 to 85° C Storage -40 to 125° C Humidity Limits 0 to 95% RH 0 to 70° C (non condensing) Standard Pressure Ranges Single in Line Packages-SIP One Port Two Ports Same Side Two Ports Opposite Side Operating Pressure Part Number Part Number 1 INCH-G-BASIC 0 - 1 “H2O 1 INCH-D1-BASIC 1 INCH-D2-BASIC 5 INCH-G-BASIC 0 - 5 “H2O 5 INCH-D1-BASIC 5 INCH-D2-BASIC 10 INCH-G-BASIC 0 - 10 “H2O 10 INCH-D1-BASIC 10 INCH-D2-BASIC 20 INCH-G-BASIC 0 - 20 “H2O 20 INCH-D1-BASIC 20 INCH-D2-BASIC 30 INCH-G-BASIC 0 - 30 “H2O 30 INCH-D1-BASIC 30 INCH-D2-BASIC Part Number Performance Characteristics for 1 INCH-x-BASIC Minimum Nominal Maximum Units -- 1.0 -- “H2O 4.0 7.0 14.0 mV Offset Voltage @ zero differential pressure -- -- ±10 mV Offset Temperature Shift (0°C-70°C), note 2 -- ±0.1 -- mV Offset Warm-up Shift, note 3 -- ±10 -- uV Offset Position Sensitivity (1g) -- ±15 -- uV Offset Long Term Drift (one year) -- ±80 -- uV Linearity, hysteresis error, note 4 -- 0.1 ±0.5 %fs Minimum Nominal Maximum Units Operating Range, differential pressure -- 5.0 -- “H2O Output Span, @ 5 “H2O, note 5 15 22.5 30 mV Offset Voltage @ zero differential pressure -- -- ±10 mV Offset Temperature Shift (0°C-70°C), note 2 -- ±0.1 -- mV Offset Warm-up Shift, note 3 -- ±10 -- uV Offset Position Sensitivity (1g) -- ±15 -- uV Offset Long Term Drift (one year) -- ±80 -- uV Linearity, hysteresis error, note 4 -- 0.1 ±0.5 %fs Parameter, note 1 Operating Range, differential pressure Output Span, @ 1 “H2O, note 5 Performance Characteristics for 5 INCH-x-BASIC Parameter, note 1 Miniature Basic Pressure Sensors Operating Range, differential pressure -- 10.0 -- “H2O Output Span, @ 10 “H2O, note 5 15 30 45 mV Offset Voltage @ zero differential pressure -- -- ±10 mV Offset Temperature Shift (0°C-70°C), note 2 -- ±0.1 -- mV Offset Warm-up Shift, note 3 -- ±10 -- uV Offset Position Sensitivity (1g) -- ±10 --- uV Offset Long Term Drift (one year) -- ±80 -- uV Linearity, hysteresis error, note 4 -- 0.1 ±0.5 %fs Minimum Nominal Maximum Units Operating Range, differential pressure -- 20.0 -- “H2O Output Span, @ 20 “H2O, note 5 15 30 45 mV Offset Voltage @ zero differential pressure -- -- ±10 mV Offset Temperature Shift (0°C-70°C), note 2 -- ±0.1 -- mV Offset Warm-up Shift, note 3 -- ±10 -- uV Offset Position Sensitivity (1g) -- ±5 -- uV Offset Long Term Drift (one year) -- ±80 -- uV Linearity, hysteresis error, note 4 -- 0.1 ±0.5 %fs Minimum Nominal Maximum Units Operating Range, differential pressure -- 30.0 -- “H2O Output Span, @ 30 “H2O, note 5 15 30 45 mV Offset Voltage @ zero differential pressure -- -- ±10 mV Offset Temperature Shift (0°C-70°C), note 2 -- ±0.1 -- mV Offset Warm-up Shift, note 3 -- ±10 --- uV Offset Position Sensitivity (1g) -- ±5 --- uV Offset Long Term Drift (one year) -- ±80 -- uV Linearity, hysteresis error, note 4 -- 0.05 ±0.5 %fs Performance Characteristics for 20 INCH-x-BASIC Parameter, note 1 Performance Characteristics for 30 INCH-x-BASIC Parameter, note 1 Specification Notes note 1: All parameters are measured at 4.5 volt excitation, for the nominal full scale pressure and room temperature unless otherwise specified. Pressure measurements are with negative pressure applied to the TOP-PORT (the only port for the single port) configuration. note 2: Shift is relative to 25°C. note 3: Shift is within the first hour of excitation applied to the device. note 4: Measured at one-half full scale rated pressure using best straight line curve fit. note 5: The voltage added to the offset voltage at full scale pressure. Pressure Response: for any pressure applied the response time to get to 90% of pressure applied is typically less than 100 useconds. All Sensors reserves the right to make changes to any products herein. All Sensors does not assume any liability arising out of the application or use of any product or circuit described herein, neither does it convey any license under its patent rights nor the rights of others. All Sensors DS-0105 Rev B e www.allsensors.com Units f 408 225 2079 Maximum p 408 225 4314 Nominal a 16035 Vineyard Blvd. Morgan Hill, CA 95037 Minimum Parameter, note 1 all sensors Performance Characteristics for 10 INCH-x-BASIC
1 INCH-D1-BASIC
1. 物料型号:文档中列出了多种型号,例如1 INCH-G-BASIC、5INCH-G-BASIC、10 INCH-G-BASIC、20 INCH-G-BASIC和30 INCH-G-BASIC,分别对应不同的工作压力范围。
2. 器件简介:这些传感器基于专有技术,减小了传感器尺寸同时保持高性能。技术正在申请专利中。与传统补偿方法相比,温度变化引起的输出偏移误差、热稳定性、长期稳定性和位置敏感性都显著降低。
3. 引脚分配:文档提供了等效电路图,但未明确指出具体的引脚分配
4. 参数特性:包括供电电压、共模压力、焊接温度、工作温度范围、存储温度范围、湿度限制等。
5. 功能详解:传感器使用硅微加工技术,提供线性输出,适用于非腐蚀性、非离子工作流体如空气和干燥气体。
6. 应用信息:适用于医疗仪器、环境控制和暖通空调系统。
7. 封装信息:提供了单列直插式封装(SIP)的型号和对应的工作压力范围。
1 INCH-D1-BASIC 价格&库存
很抱歉,暂时无法提供与“1 INCH-D1-BASIC”相匹配的价格&库存,您可以联系我们找货
