11876
11876
    ALLIEDVISION
    Module
    CAMERA MONO CSMNT OPN PYTHON480
11876 数据手册
Alvium 1800 U-050 • • • • PYTHON 480 CMOS sensor ALVIUM image processing USB3 Vision Various hardware options Versatile USB camera with PYTHON 480 sensor Alvium USB cameras are designed for use in both machine vision and embedded applications. Offering high image quality and reducing workload for the host, Alvium enables innovation among system designers. The innovative ALVIUM System on Chip (SoC) performs image corrections and preprocessing tasks onboard the camera instead of the host computer. Unlike FPGAs commonly used in machine vision cameras, the ALVIUM SoC is extremely power efficient. With Alvium, integrating hardware and software can be done effortlessly, which ultimately reduces development time. The ON Semi PYTHON 480 CMOS sensor enables imaging at 0.5 megapixel and 115 frames per second. Color models ship with an IR cut filter, monochrome and S-Mount models ship without a filter or protection glass. Benefits and features • • • • • • • • Monochrome (1800 U-050m) and color (1800 U-050c) models ALVIUM® Technology for on-board image processing USB3 Vision interface for GenICam SFNC features Platform concept that enables the operation of different Alvium camera models with a common software Micro-B USB 3.1 Gen 1 connector with screw locks for industrial applications Precise sensor-to-lens mount alignment Standard M3 mounting holes for top and bottom mounting, standard M2 mounting holes for front mounting Industrial performance for both embedded and machine vision applications Hardware options • Housings: Alvium 1800 U cameras are available as bare board, open housing, or closed housing cameras. • Various lens mounts: Select between S-Mount, CS-Mount, or C-Mount. • USB connector position: Select between the back panel or the left side of the camera (seen from the sensor side). For more information on hardware options, including product codes and technical data, such as technical drawings and mass, see the Alvium Cameras Hardware Options document. Available accessories • • • • Tripod adapter USB 3.1 Gen 1 cable with screw connectors in various lengths I/O cables in various lengths Various lenses and Allied Vision S-Mount lenses with focal lengths 2.97 - 12 mm Specifications Alvium Interface Resolution Spectral range Sensor Sensor type Shutter mode Sensor size Pixel size Lens mounts (available) Max. frame rate at full resolution ADC Image buffer (RAM) Non-volatile memory (Flash) 1800 U-050 USB3 Vision 808 (H) × 608 (V) 300 to 1100 nm ON Semi PYTHON 480 CMOS Global shutter Type 1/3.6 4.8 µm × 4.8 µm S-Mount, CS-Mount, C-Mount 115 fps at ≥200 MByte/s, Mono8 10 Bit 256 KB 1024 KB Imaging performance Imaging performance data is based on the evaluation methods in the EMVA 1288 Release 3.1 standard for characterization of image sensors and cameras. Measurements are typical values for monochrome models measured without optical filter. Quantum efficiency at 529 nm Temporal dark noise Saturation capacity Dynamic range Absolute sensitivity threshold Bit depth 53 % 14.5 eˉ 7230 eˉ 54 dB 14.9 eˉ Output Max. 10 Bit Alvium Monochrome pixel formats YUV color pixel formats 1800 U-050 Mono8, Mono10 YCbCr411_8_CbYYCrYY, YCbCr422_8_CbYCrY, YCbCr8_CbYCr RGB color pixel formats BayerGR8, BayerGR10, BayerGR10p, BGR8, RGB8 General purpose inputs/outputs (GPIOs) TTL I/Os 4 programmable GPIOs Operating conditions/dimensions Operating temperature +5 °C to +65 °C housing temperature Power requirements (DC) Power over USB 3.1 Gen 1 | External power 5.0 V Power consumption USB power: 1.5 W (typical) | Ext. power:1.7 W (typical) Mass 15 g (bare board) Body dimensions (L × W × H in mm) 13 × 26 × 26 (bare board, standard), 13 × 30 × 26 (bare board, 90°) Regulations 2011/65/EU, including amendment 2015/863/EU (RoHS) Quantum efficiency Features Image control Auto control • • • • • Auto exposure Auto gain Auto white balance Auto features regions control Auto features algorithms control  Other image controls • • • • • • • • • • Black level Contrast De-Bayering up to 5×5 (color models) Exposure time Gain Gamma Hue Region of interest (ROI) Reverse X/Y Saturation Camera control • • • • • Sync out modes: Trigger ready, input Temperature monitoring (sensor board) Test image LED luminance control Firmware update Technical drawing Camera hardware options The Alvium Cameras Hardware Options document informs about submodels, such as bare board or open housing cameras with different lens mounts. Bare Board 26.3 25 7.7 19.7* 26.4 26.3 25 26.4 26.3 25 26.4 A (10 : 1) Sensor area Do not mount here 0.05 1.75 1.25 1.5 0.05 (gap) Mounting area Mounting area A 1.4 *Mechanical length for C-Mount, for other mounts and details, see the user guide. Bare board 90° 30.1 26.3 25 7.7 19.7* 26.4 0.05 (gap) Mounting area Mounting area A 1.4 *Mechanical length for C-Mount, for other mounts and details, see the user guide. 0.05 1.75 1.5 1.25 Sensor area Do not mount here 26.3 25 26.4 26.3 25 26.4 A (10 : 1) 30.1 Applications Powered by the ALVIUM® Technology, a unique System-on-chip designed by Allied Vision, the Alvium 1500 and Alvium 1800 Series deliver industrial performance to embedded vision with many benefits for system engineers.
11876 价格&库存
很抱歉,暂时无法提供与“11876”相匹配的价格&库存,您可以联系我们找货
