P1A-090604FU
P1A-090604FU
    NEWAGE
    EXPANDABLE USB FU
P1A-090604FU 数据手册
From Off-The-Shelf to Market-Ready© New Age Enclosures is your Single Source Solution. Let us quote modifying our Stock Enclosures to meet your end-use. visit newageenclosures.com/services or call 855-4NA-ENCL today. NOTES: R E V I S I O N DESCRIPTION UNLESS OTHERWISE SPECIFIED REV. DRAWN BY 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVELANT TO MT-11002. A M BOYER 3. INTERIOR SURFACE TEXTURE TO BE: NONE. B 4. ALL INSIDE RADII .010R. ECO No DATE APPROVED PRELIMINARY RELEASE 17-Sep-11 D.C. M BOYER ADD THICKER COMPONENTS 09-May-12 D.C. C M BOYER ADD SECOND PRESS POST 15-May-12 D.C. D M BOYER REDUCE WIDTH AND THICKNESS 16-May-12 D.C. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. E M BOYER ADD VIEWS AND NOTES 06-Feb-13 D.C. 1.0 R CRUZ UPDATE TO AS BUILT & RELEASED 25-Jun-13 D.C. 7. THIS ENCLOSURE IS A PRESS FIT ASSEMBLY. FOR PERMANENT CLOSURE: A DROP OF ADHESIVE OR ULTRASONIC WELDING IS REQUIRED. 2.0 R CRUZ UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. DR XXX 02118 REMOVE -S OPTION, UPDATE FORMAT 2018-Jul-23 8. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 9. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF OEM. 10. THE GATE REMNANT FOR THIS ENCLOSURE IS LOCATED IN THIS POSITION TO MINIMIZE THE COSMETIC IMPACT. IT IS HOWEVER VISIBLE AND VARIES IN SIZE / SHAPE. IT IS EASILY REMOVED WITH CLIPPERS. IF YOU WOULD LIKE NEW AGE TO CLIP THIS FOR YOU, PLEASE ASK YOUR SALES REPRESENTIVE FOR A FREE QUOTE. 4 11. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 12. ALLOWABLE FLASH: 0.010 MAX. 13. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH, PROTRUDING OR BELOW FLUSH. 2 14. TRIM GATE WITHIN 0.015" OF FLUSH. NOTE 10 090604TU SCALE 1.000 090604BU SCALE 1.000 CONFIGURATION LEGEND 5 NOTE 10 -Tx -Fx -Cx -Bx = = = = BOTH BOTH ONLY ONLY COVER AND BASE ARE TALL COVER AND BASE ARE SHORT (FLAT) THE COVER IS TALL (BASE IS FLAT) THE BASE IS TALL (COVER IS FLAT) -xU = ENCLOSURE WITH MOLDED TYPE A USB OPENING 1 090604CU SCALE 1.000 090604(xx) CONFIGURATIONS -TU 090604 COVER w/ TYPE A USB 090606 TALL COVER w/ TYPE A USB 1 090604 BASE w/ TYPE A USB 090606 TALL BASE w/ TYPE A USB 1 -FU 1 1 -CU 1 1 -BU 1 3 SCALE 2.000 1 090604FU SCALE 1.000 5 090604 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 4 090606U COVER - STANDARD ABS BLACK or WHITE 1 3 090606U BASE - STANDARD ABS BLACK or WHITE 1 2 090604U COVER - STANDARD ABS BLACK or WHITE 1 1 090604U BASE - STANDARD ABS BLACK or WHITE 1 ITEM DESCRIPTION MATERIAL COLOR QTY. BILL OF MATERIALS THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2018 Customer's Part No: APPROVAL BY 090604 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 EXPAND. USB - STANDARD PXX-090604XX-XXX SIZE 17-Sep-11 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 090604_R2_0 SHEET 1 OF 7 REV.DOC 2.0 090604FU ASSEMBLY .315 .007 SEE DETAIL A Y (.516) J J P P .060 .940 .127 .062 .006 SCALE 1.500 SECTION J-J SECTION Y-Y Y 2.0° R.080 .630 .026 CLEARANCE FOR USB WELD 2.0° DETAIL A SCALE 3.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 090604 DATE CHECK SECTION P-P SCALE 3.000 ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 EXPAND. USB - STANDARD PXX-090604XX-XXX SIZE 17-Sep-11 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 090604_R2_0 SHEET 2 OF 7 REV.DOC 2.0 090604TU ASSEMBLY .295 .298 Y P P .060 WALL .269 CLEAR .940 .062 PCB .149 CLEAR .060 WALL SCALE 1.500 SECTION Y-Y Y .600 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 090604 DATE CHECK ENG. SCALE SECTION P-P SCALE 3.000 AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 EXPAND. USB - STANDARD PXX-090604XX-XXX SIZE 17-Sep-11 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 090604_R2_0 SHEET 3 OF 7 REV.DOC 2.0 090604 COVER TYPE A USB OPENING .480 .037 .126 .193* .160 .035 +1° DRAFT/SIDE .000 .630 .160 R.015 Y .470 .060 X P X P .055 .000 .940 .470 SECTION Y-Y SCALE 2.000 Y +.001 .062 -.001 .060 .080 +.001 -.010 .000 +.005 -.001 +.001 .037 -.001 .008 +.005 -.001 .133* .068 SECTION X-X .193* .025 2.0° .010 .135 +5° DRAFT/SIDE SECTION P-P SCALE 4.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 090604 DATE CHECK ENG. * = ADD .135" TO DIMENSION FOR 090606 (FAT) COVER. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 EXPAND. USB - STANDARD PXX-090604XX-XXX SIZE 17-Sep-11 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 090604_R2_0 SHEET 4 OF 7 REV.DOC 2.0 090604 BASE TYPE A USB OPENING .480 .086 .153* .059 .127* .020 RELIEF .160 .630 .000 R.015 .160 FEATURE NON-EXISTENT ON 090606 (FAT) BASE Y .470 .200 .030 .055 .000 .940 .125 .470 SECTION Y-Y R.080 Y .630 SCALE 2.000 +.0010 -.0010 NO DRAFT .0610 .064 +.002 -.002 .030 +.001 -.001 .000 +.002 .056 -.002 .063* .090* BREAK EDGE R.010 .123* SECTION K-K SCALE 4.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 090604 DATE CHECK ENG. SCALE * = ADD .135" TO DIMENSION FOR 090606 (FAT) BASE. AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 EXPAND. USB - STANDARD PXX-090604XX-XXX SIZE 17-Sep-11 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 090604_R2_0 SHEET 5 OF 7 REV.DOC 2.0 090604 PCB CUSTOMER SUPPLIED PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. REFERNCE ONLY USB PLUG CONNECTOR ACON ADVANCED CONNECTEK INC. PN. C-GAR71-OO-OO (.986) .390 .036 .055 .000 +.003 -.003 .250 .160 .000 .250 .390 .160 .130 THE ENCLOSURE CAN ACCOMODATE VARIOUS PCB THICKNESSES BY REPLACING MOLD INSERTS AT MINIMAL COST. PLEASE CONTACT YOUR SALES REPRESENTITIVE FOR MORE INFORMATION. .780 .062 .500 SCALE 2.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 090604 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 EXPAND. USB - STANDARD PXX-090604XX-XXX SIZE 17-Sep-11 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 090604_R2_0 SHEET 6 OF 7 REV.DOC 2.0 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" 090604 COVER SCALE 2.000 090604 BASE SCALE 2.000 PXX-090604XX-XXX COVER STEP NO DESCRIPTION CUTTER 1 - T2 = .062" EM STEP NO DESCRIPTION 2 PAD PRINT PXX-090604XX-XXX INK COLOR - FIXTURE ABS, BLACK - X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° ORIENTATION PROGRAM - - - COVER TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. ABS, BLACK CLICHE DESCRIPTION NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 090604 DATE CHECK ENG. CLICHE No. DRAWN BY AS NOTED M BOYER 17-Sep-11 SCALE CL1010 2240 South Thornburg Street ph. (805) 595-1310 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com EXPAND. USB - STANDARD PXX-090604XX-XXX SIZE A DRAWING NAME 090604_R2_0 SHEET 7 OF 7 REV.DOC 2.0
P1A-090604FU 价格&库存
很抱歉,暂时无法提供与“P1A-090604FU”相匹配的价格&库存,您可以联系我们找货
