P3A-120704U
P3A-120704U
    NEWAGE
    USB KEY
P3A-120704U 数据手册
NOTES: UNLESS OTHERWISE SPECIFIED REV. DRAWN BY 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. R E V I S I O N DESCRIPTION DATE APPROVED PRELIMINARY RELEASE 28-Jan-09 D.C. 0710 UPDATE FORMAT 20-Mar-10 D.C. M BOYER 0911 ADD CONFIG TREE AND UPDATE FORMAT 30-Mar-11 D.C. M BOYER 6713 REVISE HOOK AREA 30-Sep-13 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVELANT TO MT-11010. 1 M BOYER 1.1 M BOYER 3. INTERIOR SURFACE TEXTURE TO BE: NONE. 1.2 4. ALL INSIDE RADII .010R. ALL OUTSIDE RADII .020R MAX, UNLESS OTHERWISE SPECIFIED. 2.0 ECO No 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. THIS ENCLOSURE IS A SNAP FIT ASSEMBLY. FOR PERMANENT CLOSURE: A DROP OF ADHESIVE IS REQUIRED. 2 8. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 9. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF OEM. 3 10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 11. TRIM GATE WITHIN 0.030" OF FLUSH. 12. STANDARD OR CUSTOM LABEL RECESSES ARE AVAILABLE UPON REQUEST FOR QUOTE. 1 EXPLODED VIEW SCALE 2.500 SCALE 2.500 USB OPENING 120704(x) CONFIGURATIONS 120704 120704 120704 120704 COVER COVER w/ USB OPENING BASE BASE w/ USB OPENING -S 1 1 -U 1 120704_PCB 120704 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 2 120704_COVER 120704X COVER - STANDARD ABS BLACK or WHITE 1 1 120704_BASE 120704X BASE - STANDARD ABS BLACK or WHITE 1 DESCRIPTION MATERIAL COLOR QTY. FILE NAME BILL OF MATERIALS TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° 1 3 ITEM THIRD ANGLE PROJECTION NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2013 Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - USB KEY PXX-120704X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 28-Jan-09 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 120704 DRAWING NAME A 120704X_R2_0 SHEET 1 OF 6 REV.DOC 2.0 .357 .242 .000 .242 .357 .201 .091 .000 .091 .201 OPTIONAL USB OPENING IN STANDARD LOCATION X SCALE 3.000 R.020 .525 .181 R20.139 .045 1.229 .069 CLEAR .062 REF. PCB .171 CLEAR .055 .010 X R1.006 SCALE 2.000 SECTION X-X P120704U SHOWN WITH (CUSTOMER SUPPLIED) PCB .715 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° .020 .403 NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - USB KEY PXX-120704X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 28-Jan-09 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 120704 DRAWING NAME A 120704X_R2_0 SHEET 2 OF 6 REV.DOC 2.0 P120704X COVER .036 .483 USB .081 .050 SCALE 2.000 .060 .206 .000 R.025 .206 R.020 .536 G .614 .433 .000 .045 .010 .496 TEXTURE: MT-11010 EXTERIOR RECESS .010" .020 .172 CLIP GATE BELOW INTERIOR INTERLOCK SHELF .433 .614 SEE DETAIL A G SECTION G-G SCALE 2.000 .282 .050 .191 .312 3.0° DRAFT TYP. TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. .031 .050 DETAIL A SCALE 4.000 X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - USB KEY PXX-120704X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 28-Jan-09 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 120704 DRAWING NAME A 120704X_R2_0 SHEET 3 OF 6 REV.DOC 2.0 P120704X BASE .532 .081 .036 (.093) .484 USB .040 R.020 .073 .453 .463 .034 .065 H .012 TEXTURE: MT-11010 EXTERIOR SCALE 2.000 X X .906 .488 H SECTION H-H .030 SCALE 2.000 CLIP GATE BELOW INTERIOR INTERLOCK SHELF .047 .403 22.3° .191 .045 .030 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: SECTION X-X APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - USB KEY PXX-120704X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 28-Jan-09 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 120704 DRAWING NAME A 120704X_R2_0 SHEET 4 OF 6 REV.DOC 2.0 P120704X PCB - CUSTOMER SUPPLIED PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. .475 .178 .596 .114 USB PLUG CONNECTOR ACON ADVANCED CONNECTEK INC. PN. C-UAR70-OO-OO www.acon.com PCB .062" THICK .108 .080 MAX .062 THICK 1.025 .040 4x .200 .125 .000 .125 .200 .030 4x .020 x 45° NOT REQUIRED (COSMETIC) SCALE 2.000 .520 KEEP OUT ZONES TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - USB KEY PXX-120704X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 28-Jan-09 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 120704 DRAWING NAME A 120704X_R2_0 SHEET 5 OF 6 REV.DOC 2.0 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" P120704X COVER SCALE 2.000 P120704X BASE SCALE 2.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES STEP NO 1 2 PXX-120704X-XXX COVER DESCRIPTION - CUTTER T2 = .062" EM T2 = .062" EM - ABS, BLACK FIXTURE 242 242 ORIENTATION - Customer's Part No: APPROVAL PROGRAM BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - USB KEY PXX-120704X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 28-Jan-09 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 120704 DRAWING NAME A 120704X_R2_0 SHEET 6 OF 6 REV.DOC 2.0
P3A-120704U 价格&库存
很抱歉,暂时无法提供与“P3A-120704U”相匹配的价格&库存,您可以联系我们找货
