1A-180804B
1A-180804B
    NEWAGE
    BUTTON USB DRIVE
1A-180804B 数据手册
From Off-The-Shelf to Market-Ready© New Age Enclosures is your Single Source Solution. Let us quote modifiying our Stock Enclosures to meet your end-use. visit newageenclosures.com/services or call 855-4NA-ENCL today. 180804 180804 180804 180804 180804 180804 180804 180804 180804(x) CONFIGURATIONS -S -U -62U COVER 1 1 COVER w/USB OPENING 1 COVER w/BUTTON HOLE COVER w/USB & BUTTON HOLE BASE 1 BASE w/USB 1 BASE w/USB w/.062 PCB 1 BUTTON -SB 1 1 -UB -62UB 1 1 R E V I S I O N -B REV. DRAWN BY 1 M BOYER ECO No PRELIMINARY RELEASE DATE APPROVED 2005-May-04 D.C. REVISIONS 2-11 ARCHIVED ON REV 12.1 1 1 DESCRIPTION REVISIONS 12.0-13.1 ARCHIVED ON REV 13.1 14.0 M BOYER 02316 UPDATE CONFIGURATION TREE 2016-Apr-20 D.C. 15.0 M BOYER 04516 ADD .062" PCB OPTION TO CONFIGURATION TREE 2016-Sep-02 D.C. 16.0 M BOYER 03117 MAKE REFERENCE TO WALL RIB IN BASE NOT AVAILABLE IN ALL VERSIONS 2017-Dec-14 1 'UB' & 'SB' SERIES ONLY NOTES: UNLESS OTHERWISE SPECIFIED 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH (EQUIVALENT TO MT-11010.) NOTE 12 USB OPENING 'U' & 'UB' SERIES ONLY 3. INTERIOR SURFACE TEXTURE TO BE: NONE 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. THIS ENCLOSURE IS A PRESS FIT ASSEMBLY. FOR PERMANENT CLOSURE: A DROP ADHESIVE OR ULTRASONIC WELDING IS REQUIRED. 8. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 9. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH CUSTOMER. 10. STANDARD OR CUSTOM LABEL RECESSES ARE AVAILABLE FOR QUOTE. 11. "STANDARD" VERSION ENCLOSURE COVER NOT AVAILABLE WITH RIBS. SHEET 4 FOR DETAILS. USB CAP NOT SHOWN 12. THE GATE REMNANT FOR THIS ENCLOSURE IS LOCATED IN THIS POSITION TO MINIMIZE ANY COSMETIC IMPACT. IT IS HOWEVER VISIBLE AND VARIES IN SIZE / SHAPE. IT IS EASILY REMOVED WITH CLIPPERS. IF YOU WOULD LIKE NEW AGE TO CLIP THIS FOR YOU, PLEASE ASK YOUR SALES REPRESENTIVE FOR A FREE QUOTE. NOTE 12 SCALE 2.000 USB OPENING U & UB SERIES ONLY 4 180804 PCB - REFERENCE .027"-.062" THICK CUSTOMER SUPPLIED 1 3 180804UB COVER - STANDARD ABS BLACK or WHITE 1 2 180804UB BASE - STANDARD ABS BLACK or WHITE 1 1 180804 BUTTON SOLD SEPERATE -- 1 ITEM DESCRIPTION MATERIAL COLOR QTY. BILL OF MATERIALS SEE 13. ASSEMBLY POST DIMENSIONS WILL VARY DEPENDING ON THE "PRESS FIT" OF THE ENCLOSURE. THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2017 Customer's Part No: APPROVAL BY 180804 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - USB DRIVE PXX-180804XX-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2005-May-04 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 180804_R16_0 SHEET 1 OF 8 REV.DOC 16.0 (.759 AT FRONT) [19,28] .800 [20,32] .477 [12,12] .495 [12,57] 1.800 [45,72] SCALE 2.000 .035 [0,88] .425 [10,8] .015 [0,38] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 180804 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - USB DRIVE PXX-180804XX-XXX DATE CHECK ENG. SCALE 2.000 SCALE AS NOTED DRAWN BY M BOYER SIZE 2005-May-04 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 180804_R16_0 SHEET 2 OF 8 REV.DOC 16.0 R Y Y SCALE 2.500 R SECTION R-R SEE DETAIL A .495 [12,57] (.188 CLEAR) [4,76] SECTION Y-Y .693 [17,59] .031 [0,787] (.107 CLEAR) [2,71] .098 [2,49] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: SECTION P-P SCALE 4.000 .025 [0,62] APPROVAL BY 180804 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - USB DRIVE PXX-180804XX-XXX DATE CHECK DETAIL A SCALE 4.000 ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2005-May-04 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 180804_R16_0 SHEET 3 OF 8 REV.DOC 16.0 NOTE: CONFIGURATION 180804-S ONLY 1. END RIBS NOT INCLUDED 2. 1 DEGREE DRAFT ON SIDE RIB 3. ALIGNMENT POSTS .080" TALL 180804 COVER .213 [5,4] .510 [12,95] .800 [20,32] .620 [15,75] .400 [10,16] INTERIOR SUPPORT RIBS NOT AVAILABLE ON -S CONFIGURATION Y SEE DETAIL R .025 +1° [0,64] DRAFT/SIDE "PRESS FIT" R.055 [1,4] LABEL RECESS .010 DEEP .790 [20,07] (.705 ) [17,91] 1.510 [38,35] 1.360 [34,54] 1.800 [45,72] SCALE 2.000 .305 [7,75] OPTIONAL FEATURE .821 [20,84] .830 [21,08] .133 [3,38] .080 [2,03] .163 [4,13] .125 [3,18] SCALE 2.000 3° DRAFT TYP. .082** [2,08] R.015 [0,38] 2.0° .020 [0,51] Y .020 [0,51] .205 [5,21] .031 [0,79] SECTION Y-Y .520 [13,21] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. .046 [1,18] .480 [12,19] .089 [2,26] .032 FOR -S CONFIGURATION .010 FOR -U/-UB CONFIGURATION X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: DETAIL R SCALE 3.000 .050 [1,27] APPROVAL BY 180804 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - USB DRIVE PXX-180804XX-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2005-May-04 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 180804_R16_0 SHEET 4 OF 8 REV.DOC 16.0 3° DRAFT TYP. 180804 BASE .233 [5,91] REFERENCE ONLY FEATURE. NOT AVAILABLE IN ALL VERSIONS. .798 [20,28] .550 [13,97] .500 [12,7] .130 [3,3] .790 [20,07] .100 [2,54] .050 [1,27] X 1.400 [35,56] .025 [0,64] .300 [7,62] X 1.798 [45,68] 1.506 [38,25] SCALE 2.000 .830 [21,08] R.03 SCALE 2.000 .620 ±.002 [15,75] GATE LOCATION .04 x .02 .104 FOR .027 PCB [2,64] .069 FOR .062 PCB R.015 [0,38] "PRESS FIT" TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° .109 ±.001 [2,77] .480 -2° [12,19] DRAFT / SIDE ±.002 .130 [3,3] NEW AGE ENCLOSURES .035 [0,89] Customer's Part No: APPROVAL BY 180804 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - USB DRIVE PXX-180804XX-XXX DATE CHECK ENG. SECTION X-X SCALE 3.000 SCALE AS NOTED DRAWN BY M BOYER SIZE 2005-May-04 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 180804_R16_0 SHEET 5 OF 8 REV.DOC 16.0 P180804 PCB - CUSTOMER SUPPLIED .293 [7,45] .274 [6,96] .333 [8,45] .176 [4,47] .205 [5,21] .000 [0] .176 [4,47] .274 [6,96] .293 [7,45] SUGGESTED TYPE A USB PLUG CONNECTOR ACON, ADVANCED CONNECTEK INC. PN. C-UAR70-00-00 .643 [16,32] .755 [19,18] .605 [15,37] .255 [6,48] .130 [3,31] .000 [0] .170 [4,31] .755 [19,18] .676 [17,18] PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF THE CUSTOMER. www.acon.com/en-global/product/detail/378 (.477 ) [12,12] .333 [8,45] SCALE 2.000 KEEP OUT ZONES 4x 1.510 [38,35] .100 [2,54] .062or .027 [1,57] (.590 ) [14,99] .178 [4,52] .114 [2,9] .113 [2,86] (.435 ) [11,05] .112 MAX [2,84] .064 [1,63] "STANDARD" 180804-S CONFIGURATION CAN ACCOMODATE 0.027" to 0.031" PCB. OR 180804-62 CONFIGURATION CAN ACCOMODATE 0.062" PCB. TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 180804 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - USB DRIVE PXX-180804XX-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2005-May-04 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 180804_R16_0 SHEET 6 OF 8 REV.DOC 16.0 OPTIONAL BUTTON .075 [1,91] .125 [3,18] ( .047 ) [1,19] X .014 [0,36] SECTION R-R SCALE 2.500 .008 [0,21] COSMETIC SURFACE .075 [1,91] 30.0° .104 [2,64] .164 [4,17] .060 [1,52] SCALE 16.000 SCALE 16.000 X .078 [1,98] 19.0° SECTION X-X TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 180804 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - USB DRIVE PXX-180804XX-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2005-May-04 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 180804_R16_0 SHEET 7 OF 8 REV.DOC 16.0 2nd OPERATION DETAILS MOLDED TYPE A USB OPENING .000 [0] (.213) [5,4] .000 [0] .000 [0] (.900 ) [22,86] (.899 ) [22,84] PXX-180804U-XXX COVER - ABS, BLACK STEP NO DESCRIPTION CUTTER FIXTURE ORIENTATION PROGRAM 1-C-C1 2-C-C2 END CUT END CUT T2 = .062" EM T2 = .062" EM 100 100 2 UP LR- CENTER XY 2 UP LR- CENTER XY o1001 o1002 PXX-180804U-XXX BASE - ABS, BLACK TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL STEP NO DESCRIPTION CUTTER FIXTURE ORIENTATION PROGRAM 3-B-C1 4-B-C2 END CUT END CUT T2 = .062" EM T2 = .062" EM 100 100 2 UP LR- CENTER XY 2 UP LR- CENTER XY o1003 o1004 .000 [0] 180804 BASE SCALE 1.500 (.399 ) [10,14] (.899 ) [22,84] (.399 ) [10,14] (.900 ) [22,86] (.400 ) [10,16] .000 [0] (.400 ) [10,16] 180804 COVER SCALE 1.500 MOLDED TYPE A USB OPENING NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" BY 180804 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - USB DRIVE PXX-180804XX-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2005-May-04 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 180804_R16_0 SHEET 8 OF 8 REV.DOC 16.0
1A-180804B 价格&库存
很抱歉,暂时无法提供与“1A-180804B”相匹配的价格&库存,您可以联系我们找货
1A-180804B
  • 1+4.832931+0.62549
  • 5+4.128795+0.53436
  • 10+3.8620710+0.49984
  • 25+3.5334825+0.45731
  • 50+3.3032550+0.42752
  • 100+3.08763100+0.39961
  • 250+2.82345250+0.36542
  • 500+2.63916500+0.34157
  • 1000+2.466811000+0.31926
库存:186
