P3A-191508-T
P3A-191508-T
    NEWAGE
    TALL E.E. HOUSING
P3A-191508-T 数据手册
NOTES: UNLESS OTHERWISE SPECIFIED REV. DRAWN BY 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVELANT TO MT-11010. 3. INTERIOR SURFACE TEXTURE TO BE: NONE. 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. A M BOYER B R E V I S I O N DESCRIPTION ECO No DR XXX DATE APPROVED PRELIMINARY RELEASE 06-Apr-11 D.C. M BOYER CHANGE TITLE AND PN 25-Jan-12 D.C. C M BOYER ADD LARGER CONFIGURATION 15-Oct-12 D.C. D M BOYER REDUCE THE LENGTH OF ASSY POST 30-Nov-12 D.C. E M BOYER UPDATE NAME 25-Jan-13 D.C. F R CRUZ UPDATE TO AS BUILT 07-Jun-13 D.C. 1.0 R CRUZ RELEASED 25-Jun-13 7. THIS ENCLOSURE IS A PRESS FIT ASSEMBLY. FOR PERMANENT CLOSURE: A DROP OF ADHESIVE OR ULTRASONIC WELDING IS REQUIRED. 8. MOUNTING SCREWS FOR THE PCB ARE SOLD SEPERATELY. 9. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 10. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF OEM. 11. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 12. ALLOWABLE FLASH: 0.010 MAX. 13. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH, PROTRUDING OR BELOW FLUSH. 191508M ASSEMBLY - 191510 COVER - 191508 BASE SCALE 1.000 191508S ASSEMBLY - 191508 COVER - 191508 BASE SCALE 1.000 191508 191508 191510 191510 191508(x) CONFIGURATIONS -S -M COVER 1 BASE 1 1 COVER 1 BASE -T 1 1 191508T ASSEMBLY - 191510 COVER - 191510 BASE SCALE 1.000 6 2-32 ROUND SHANK x .187" SCREW SOLD SEPERATELY MMC 90056A075 4 5 TYPE A - FEMALE USB CONNECTOR REFERENCE ONLY CUSTOMER SUPPLIED 1 4 RJ45 FEMALE CONNECTOR REFERENCE ONLY CUSTOMER SUPPLIED 1 3 190508 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 2 2 191510 CASE - STANDARD ABS BLACK or WHITE 2 1 191508 CASE - STANDARD ABS BLACK or WHITE 2 ITEM DESCRIPTION MATERIAL COLOR QTY. BILL OF MATERIALS EXPLODED VIEW SCALE 0.900 THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2017 Customer's Part No: APPROVAL BY 181508X DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 ELEC. HOUSING - STANDARD PXX-191508X-XXX SIZE 2011-Apr-06 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 191508_R1_0 SHEET 1 OF 6 REV.DOC 1.0 191508 ASSEMBLY (1.900) K (1.490) K MAX. CLEARANCE S = (.461) M = (0.586) T = (0.711) (.894) (.020) S = (0.400) M = (0.527) T = (0.654) S = 0.820 M = 0.945 T = 1.070 SECTION K-K SCALE 1.500 191508S MODELS SHOWN (.127) MAX. CLEARANCE FOR ALL CONFIGURATIONS. TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL SECTION Y-Y BY 181508X DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 ELEC. HOUSING - STANDARD PXX-191508X-XXX SIZE 2011-Apr-06 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 191508_R1_0 SHEET 2 OF 6 REV.DOC 1.0 191508 COVER / BASE ( .779) A SCALE 1.500 SCALE 1.500 A .085 .400 .188 SECTION A-A .950 .700 2x .250 2x .000 .250 2x .700 2x .470 .950 .127 .046 .050 .146 .745 (.570) .450 2x .438 2x .061 .000 .156 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° .438 2x .450 2x (.570) .062 PRESS FIT NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 181508X DATE CHECK .745 .156 R.745 .060 ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 ELEC. HOUSING - STANDARD PXX-191508X-XXX SIZE 2011-Apr-06 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 191508_R1_0 SHEET 3 OF 6 REV.DOC 1.0 A 191510 COVER / BASE ( .756) SCALE 1.500 SCALE 1.500 .127 A .525 .313 SECTION A-A .046 .950 .700 2x .250 2x .000 .250 2x .700 2x .595 .950 .085 .745 .450 2x .438 2x .156 .061 .000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. .438 2x .450 2x X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL .062 PRESS FIT BY 181508X DATE CHECK .745 .060 .156 ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 ELEC. HOUSING - STANDARD PXX-191508X-XXX SIZE 2011-Apr-06 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 191508_R1_0 SHEET 4 OF 6 REV.DOC 1.0 191508 PCB - CUSTOMER SUPPLIED PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. .825 .615 .443 .250 2x .175 .000 .175 .250 2x .443 .615 .825 1.650 .575 .450 2x .438 2x .365 .000 1.150 .365 .438 2x .450 2x .575 R.062 .150 KEEP OUT 4 PLACES .092 4x SCALE 2.000 R.062 .062 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 181508X DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 ELEC. HOUSING - STANDARD PXX-191508X-XXX SIZE 2011-Apr-06 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 191508_R1_0 SHEET 5 OF 6 REV.DOC 1.0 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" SCALE 1.500 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES PXX-191508-XXX COVER STEP DESCRIPTION CUTTER 1-C-C1 2-C-C2 - T2 = .062" EM T2 = .062" EM - FIXTURE 300 300 ABS, BLACK Customer's Part No: APPROVAL ORIENTATION PROGRAM - o1001 o1002 BY 181508X DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 ELEC. HOUSING - STANDARD PXX-191508X-XXX SIZE 2011-Apr-06 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 191508_R1_0 SHEET 6 OF 6 REV.DOC 1.0
P3A-191508-T
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚输出,4脚集电极,5脚发射极,6脚地。
4. 参数特性:工作温度范围为-40至85度,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于工业控制、医疗设备等领域。
7. 封装信息:采用DIP6封装,尺寸为9.1x3.6mm。
P3A-191508-T 价格&库存
很抱歉,暂时无法提供与“P3A-191508-T”相匹配的价格&库存,您可以联系我们找货
