0P-210603C
0P-210603C
    NEWAGE
    CAP USB STICK
0P-210603C 数据手册
R E V I S I O N REV. DRAWN BY ECO No 1 SUGGESTION: END CAN BE MOLDED IN A TRANSLUSCENT MATERIAL OR ALTERNATE COLOR. DESCRIPTION M BOYER PRELIMINARY RELEASE M BOYER REVISION LIST CONDENSED - SEE REV 10 OR PRIOR DATE APPROVED 07-Jul-06 D.C. 10.2 M BOYER 0211 NOTE CHANGE 13-Jan-11 D.C. 10.3 M BOYER 0311 REMOVE "LENS" FROM DRAWING LANGUAGE 08-Feb-11 D.C. 10.4 M BOYER 0611 UPDATE TITLE FROM "USB DEVICE" TO "USB STICK" 01-Mar-11 D.C. 10.5 M BOYER 2711 MARK ASSEMBLY DIMENSIONS AS "PRESS FIT" 21-Oct-11 SCALE 1.250 NOTES: UNLESS OTHERWISE SPECIFIED 1. DIMENSIONS TO BE SYMMETRICAL ABOUT CENTERLINES WITHIN .003 T.I.R. 2. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 4 3. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVELANT TO MT-11010. 1 4. INTERIOR SURFACE TEXTURE TO BE: NONE. 5. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. 6. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 7. 1 DEGREES DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 8. THIS ENCLOSURE IS A PRESS FIT ASSEMBLY. FOR PERMANENT CLOSURE: A DROP ADHESIVE OR ULTRASONIC WELDING IS REQUIRED. 2 9. MATERIAL / COLOR: BLACK OR WHITE ARE STANDARD ABS COLORS. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. EXPLODED VIEW SCALE 1.250 3 P210603 P210603 * = ENCLOSURE IS TO BE ASSEMBLED USING P210603 THE "210603 END" OR "210603 END w/ KEYRING" P210603 NOT BOTH. SEE NOTE 8 P210603(x) CONFIGURATIONS -K -L CASE HALF 2 2 END w/ KEYRING * 1 END * 1 CAP -C 11. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 1 5 210603 USB CAP - STANDARD SOLD SEPERATELY BLACK or WHITE 1 4 210603 END ABS BLACK or WHITE 1 3 210603 END w/ KEYRING ABS BLACK or WHITE 1 2 210603 CASE HALF - STANDARD ABS BLACK or WHITE 2 1 210603 PCB - REFERENCE CUSTOMER SUPPLIED .032" THICK 1 ITEM DESCRIPTION MATERIAL COLOR QTY. BILL OF MATERIALS 10. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF EACH OWNER. SOLID MODELS ARE AVAILABLE FOR DOWNLOAD AT OUR WEBSITE. THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2017 Customer's Part No: APPROVAL BY 210603X 2240 South Thornburg Street ph. (805) 595-1310 USB STICK - STANDARD PXX-210603X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2006-Jul-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 210603_R10_5 SHEET 1 OF 7 REV.DOC 10.5 2.987 2.138 P R R .673 SCALE 2.000 P .193 CLEAR .375 SECTION R-R SECTION P-P .064 CLEAR TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 210603X 2240 South Thornburg Street ph. (805) 595-1310 USB STICK - STANDARD PXX-210603X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2006-Jul-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 210603_R10_5 SHEET 2 OF 7 REV.DOC 10.5 .010 .125 +1° DRAFT "PRESS FIT" X .052 x 0.030 R3.00 "PRESS FIT" .122 +1° DRAFT X DETAIL C SCALE 4.000 (2.053) SCALE 2.000 .033 .015 .080 .035 .495 1.970 1.774 1.624 .010 .082 .000 .105 SECTION X-X .122 ( .125) POLISH OR SUPER FINE EDM FINISH ON POST. "PRESS FIT" SEE DETAIL B "PRESS FIT" "PRESS FIT" .250 .200 .250 DETAIL A SCALE 4.000 "PRESS FIT" R2.000 DETAIL B SCALE 4.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. SEE DETAIL C SEE DETAIL A X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 210603X 2240 South Thornburg Street ph. (805) 595-1310 USB STICK - STANDARD PXX-210603X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2006-Jul-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 210603_R10_5 SHEET 3 OF 7 REV.DOC 10.5 210603 END WITH KEY RING AND WITHOUT. PLEASE SPECIFY PREFERENCE WHEN ORDERING .047 CRITICAL DIMENSIONS: SAME AS END W/ RING .010 A .025 A .054 .081 .200 .129 .025 .025 .423 .050 .142 .142 .014 .029 P210603K END w/ KEYRING SCALE 3.000 .392 .031 P210603L END SCALE 3.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 210603X 2240 South Thornburg Street ph. (805) 595-1310 USB STICK - STANDARD PXX-210603X-XXX DATE CHECK ENG. USE .141 CORE PIN SECTION A-A SCALE AS NOTED DRAWN BY M BOYER SIZE 2006-Jul-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 210603_R10_5 SHEET 4 OF 7 REV.DOC 10.5 OPTIONAL USB CAP P210603C CAP .035 .171 R.098 1.5° 2.0° .168 .515 SCALE 3.000 .183 .480 MT-11010 or EQUIV. SECTION Y-Y SECTION A-A .080 .220 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 210603X 2240 South Thornburg Street ph. (805) 595-1310 USB STICK - STANDARD PXX-210603X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2006-Jul-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 210603_R10_5 SHEET 5 OF 7 REV.DOC 10.5 P210603 PCB - CUSTOMER SUPPLIED .907 .706 .567 .000 .823 .907 .853 PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. .596 .265 .235 .212 2x .000 .474 .212 2x .235 .265 NOTE B SCALE 2.000 R.010 SUGGESTED TYPE A USB PLUG CONNECTOR ACON ADVANCED CONNECTEK INC. PN. C-GAR71-OO-OO www.acon.com NOTE A .139 .837 .907 .621 .651 .175 .075 .510 (1.503) .122 .061 CLEAR SPACE .190 CLEAR SPACE .000 .823 .029 .230 .242 .212 .187 .000 .187 .212 .242 .230 NOTE A. FICTITIOUS COMPONENT SHOWN TO REPRESENT VERTICAL SPACE AVAILABLE. B. KEEP OUT ZONES REPRESENT AREAS WHERE THE PLASTIC ENCLOSURE WILL CONTACT THE PCB. C. SOLID MODELS (STP) ARE AVAILABLE FOR DOWNLOAD. OTHER FORMATS ARE AVAILABLE UPON REQUEST. TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NOTE B NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 210603X 2240 South Thornburg Street ph. (805) 595-1310 USB STICK - STANDARD PXX-210603X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2006-Jul-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 210603_R10_5 SHEET 6 OF 7 REV.DOC 10.5 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" SCALE 1.500 PXX-210603X-XXX CASE HALF COVER - ABS, BLACK STEP NO DESCRIPTION CUTTER FIXTURE ORIENTATION PROGRAM 1-C-C1 3-C-C2 - T2 = .062" EM T2 = .062" EM 140 140 SINGLE SINGLE - PXX-210603X-XXX CASE HALF BASE - ABS, BLACK TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. STEP NO DESCRIPTION CUTTER FIXTURE ORIENTATION PROGRAM 2-B-C1 4-B-C2 - T2 = .062" EM T2 = .062" EM 140 140 SINGLE SINGLE - PXX-210603X-XXX CASE HALF COVER STEP TYPE 5-C-P1 PAD PRINT - ABS, BLACK X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 210603X 2240 South Thornburg Street ph. (805) 595-1310 USB STICK - STANDARD PXX-210603X-XXX DATE CHECK ENG. FIXTURE INK COLOR CLICHE DESCRIPTION CLICHE No. 128 WHITE LOGO AND LABELS CL1010 R1 SCALE AS NOTED DRAWN BY M BOYER SIZE 2006-Jul-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 210603_R10_5 SHEET 7 OF 7 REV.DOC 10.5
0P-210603C 价格&库存
很抱歉,暂时无法提供与“0P-210603C”相匹配的价格&库存,您可以联系我们找货
