R E V I S I O N
REV. DRAWN BY ECO No
1
SUGGESTION: END CAN BE MOLDED IN
A TRANSLUSCENT MATERIAL OR
ALTERNATE COLOR.
DESCRIPTION
M BOYER
PRELIMINARY RELEASE
M BOYER
REVISION LIST CONDENSED - SEE REV 10 OR PRIOR
DATE
APPROVED
07-Jul-06
D.C.
10.2 M BOYER 0211
NOTE CHANGE
13-Jan-11
D.C.
10.3 M BOYER 0311
REMOVE "LENS" FROM DRAWING LANGUAGE
08-Feb-11
D.C.
10.4 M BOYER 0611
UPDATE TITLE FROM "USB DEVICE" TO "USB STICK"
01-Mar-11
D.C.
10.5 M BOYER 2711
MARK ASSEMBLY DIMENSIONS AS "PRESS FIT"
21-Oct-11
SCALE 1.250
NOTES:
UNLESS OTHERWISE SPECIFIED
1. DIMENSIONS TO BE SYMMETRICAL ABOUT CENTERLINES WITHIN .003 T.I.R.
2. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM.
4
3. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVELANT TO MT-11010.
1
4. INTERIOR SURFACE TEXTURE TO BE: NONE.
5. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED.
6. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF
THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT
THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED.
7. 1 DEGREES DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS
OTHERWISED SPECIFIED.
8. THIS ENCLOSURE IS A PRESS FIT ASSEMBLY. FOR PERMANENT CLOSURE: A DROP
ADHESIVE OR ULTRASONIC WELDING IS REQUIRED.
2
9. MATERIAL / COLOR:
BLACK OR WHITE ARE STANDARD ABS COLORS. CUSTOM
MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE.
EXPLODED VIEW
SCALE 1.250
3
P210603
P210603
* = ENCLOSURE IS TO BE ASSEMBLED USING
P210603
THE "210603 END" OR "210603 END w/ KEYRING"
P210603
NOT BOTH. SEE NOTE 8
P210603(x) CONFIGURATIONS
-K
-L
CASE HALF
2
2
END w/ KEYRING *
1
END *
1
CAP
-C
11. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED
BY THE SOLID MODEL FILE.
1
5
210603 USB CAP - STANDARD
SOLD SEPERATELY
BLACK or WHITE
1
4
210603 END
ABS
BLACK or WHITE
1
3
ABS
BLACK or WHITE
1
2
210603 CASE HALF - STANDARD
ABS
BLACK or WHITE
2
1
210603 PCB - REFERENCE
CUSTOMER SUPPLIED
.032" THICK
1
ITEM
DESCRIPTION
MATERIAL
COLOR
QTY.
BILL OF MATERIALS
10. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION
OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF EACH OWNER. SOLID
MODELS ARE AVAILABLE FOR DOWNLOAD AT OUR WEBSITE.
THIRD ANGLE PROJECTION
TOLERANCES: UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN U.S. INCHES.
DO NOT SCALE DRAWING
NEW AGE ENCLOSURES
X.XX = .015 X.XXXX = .001
X.XXX = .010
X.X° = 1°
NOTICE: THE INFORMATION AND DATA
CONTAINED HEREIN IS CONSIDERED
PROPRIETARY TO ALLTEC INTEGRATED
MFG INC & SHALL REMAIN THE EXCLUSIVE
PROPERTY OF ALLTEC INTEGRATED MFG INC
THE HOLDER WILL ASSUME CUSTODY AND
CONTROL THAT THIS DOCUMENT WILL
NOT BE COPIED, REPRODUCED, OR
DISCLOSED WITHOUT THE EXPRESS WRITTEN
CONSENT OF ALLTEC INTEGRATED MFG INC
POSSESSION OF THIS DOCUMENT DOES
NOT CONSTITUTE A GRANT TO
MANUFACTURE ANY ITEMS.
© 2017
Customer's Part No:
APPROVAL
BY
210603X
2240 South Thornburg Street
ph. (805) 595-1310
USB STICK - STANDARD
PXX-210603X-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2006-Jul-07
Santa Maria, CA. 93455
fax (805) 595-1024
www.newageenclosures.com
A
DRAWING NAME
210603_R10_5
SHEET
1 OF 7
REV.DOC
10.5
2.987
2.138
P
R
R
.673
SCALE 2.000
P
.193 CLEAR
.375
SECTION R-R
SECTION P-P
.064 CLEAR
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
210603X
ph. (805) 595-1310
PXX-210603X-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2006-Jul-07
fax (805) 595-1024
A
DRAWING NAME
210603_R10_5
SHEET
2 OF 7
REV.DOC
10.5
.010
.125 +1° DRAFT
"PRESS FIT"
X
.052 x 0.030
R3.00
"PRESS FIT"
.122 +1° DRAFT
X
DETAIL C
SCALE 4.000
(2.053)
SCALE 2.000
.033
.015
.080
.035
.495
1.970
1.774
1.624
.010
.082
.000
.105
SECTION X-X
.122
( .125)
POLISH OR
SUPER FINE
EDM FINISH
ON POST.
"PRESS FIT"
SEE DETAIL B
"PRESS FIT"
"PRESS FIT"
.250
.200
.250
DETAIL A
SCALE 4.000
"PRESS FIT"
R2.000
DETAIL B
SCALE 4.000
SEE DETAIL C
SEE DETAIL A
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
210603X
ph. (805) 595-1310
PXX-210603X-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2006-Jul-07
fax (805) 595-1024
A
DRAWING NAME
210603_R10_5
SHEET
3 OF 7
REV.DOC
10.5
210603 END
WITH KEY RING AND WITHOUT.
PLEASE SPECIFY PREFERENCE WHEN ORDERING
.047
CRITICAL DIMENSIONS:
SAME AS END W/ RING
.010
A
.025
A
.054
.081
.200
.129
.025
.025
.423
.050
.142
.142
.014
.029
P210603K END w/ KEYRING
SCALE 3.000
.392
.031
P210603L END
SCALE 3.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
210603X
ph. (805) 595-1310
PXX-210603X-XXX
DATE
CHECK
ENG.
USE
.141 CORE PIN
SECTION A-A
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2006-Jul-07
fax (805) 595-1024
A
DRAWING NAME
210603_R10_5
SHEET
4 OF 7
REV.DOC
10.5
OPTIONAL USB CAP
P210603C CAP
.035
.171
R.098
1.5°
2.0°
.168
.515
SCALE 3.000
.183
.480
MT-11010 or EQUIV.
SECTION Y-Y
SECTION A-A
.080
.220
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
210603X
ph. (805) 595-1310
PXX-210603X-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2006-Jul-07
fax (805) 595-1024
A
DRAWING NAME
210603_R10_5
SHEET
5 OF 7
REV.DOC
10.5
P210603 PCB - CUSTOMER SUPPLIED
.907
.706
.567
.000
.823
.907
.853
SIZES AND VERIFICATION OF IT'S FIT ARE THE
SOLE RESPONSIBILITY OF THE OEM.
.596
.265
.235
.212 2x
.000
.474
.212 2x
.235
.265
NOTE B
SCALE 2.000
R.010
SUGGESTED TYPE A USB PLUG CONNECTOR
ACON ADVANCED CONNECTEK INC.
PN. C-GAR71-OO-OO
www.acon.com
NOTE A
.139
.837
.907
.621
.651
.175
.075
.510
(1.503)
.122
.061 CLEAR SPACE
.190 CLEAR SPACE
.000
.823
.029
.230
.242
.212
.187
.000
.187
.212
.242
.230
NOTE
A. FICTITIOUS COMPONENT SHOWN TO REPRESENT VERTICAL
SPACE AVAILABLE.
B. KEEP OUT ZONES REPRESENT AREAS WHERE THE PLASTIC
ENCLOSURE WILL CONTACT THE PCB.
C. SOLID MODELS (STP) ARE AVAILABLE FOR DOWNLOAD.
OTHER FORMATS ARE AVAILABLE UPON REQUEST.
X.XXX = .010
X.X° = 1°
NOTE B
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
210603X
ph. (805) 595-1310
PXX-210603X-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2006-Jul-07
fax (805) 595-1024
A
DRAWING NAME
210603_R10_5
SHEET
6 OF 7
REV.DOC
10.5
2nd OPERATION DETAILS
NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE
CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT.
ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES
CALL (805) 595-1310 FOR PRICING AND SCHEDULE.
THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031"
SCALE 1.500
PXX-210603X-XXX CASE HALF COVER
ABS, BLACK
STEP NO
DESCRIPTION
CUTTER
FIXTURE
ORIENTATION
PROGRAM
1-C-C1
3-C-C2
T2 = .062" EM
T2 = .062" EM
140
140
SINGLE
SINGLE
PXX-210603X-XXX CASE HALF BASE
ABS, BLACK
STEP NO
DESCRIPTION
CUTTER
FIXTURE
ORIENTATION
PROGRAM
2-B-C1
4-B-C2
T2 = .062" EM
T2 = .062" EM
140
140
SINGLE
SINGLE
STEP
TYPE
5-C-P1 PAD PRINT
ABS, BLACK
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
210603X
ph. (805) 595-1310
PXX-210603X-XXX
DATE
CHECK
ENG.
FIXTURE
INK COLOR
CLICHE DESCRIPTION
CLICHE No.
128
WHITE
LOGO AND LABELS
CL1010 R1
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2006-Jul-07
fax (805) 595-1024
A
DRAWING NAME
210603_R10_5
SHEET
7 OF 7
REV.DOC
10.5
很抱歉,暂时无法提供与“P3A-210603XK”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5+51.595115+6.67944
