R E V I S I O N
P260906(x) CONFIGURATIONS
-S
-U
P260906 COVER
1
P260906 COVER w/ USB
1
P260906 BASE
1
P260906 BASE w/ USB
1
4
M2 SCREW x 4mm - REFERENCE
CUSTOMER SUPPLIED
CUSTOMER SUPPLIED
4
3
260906 COVER - STANDARD
ABS
BLACK or WHITE
1
2
260906 BASE - STANDARD
ABS
BLACK or WHITE
1
1
260906 PCB - REFERENCE
CUSTOMER SUPPLIED
.062" THICK
1
ITEM
DESCRIPTION
MATERIAL
COLOR
QTY.
BILL OF MATERIALS
REV.
DRAWN BY
1
M BOYER
2
M BOYER
3
ECO No
DESCRIPTION
DATE
APPROVED
PRELIMINARY RELEASE
08-Apr-08
D.C.
3408
REMOVE SHOWN USB CUTOUT
22-Oct-08
D.C.
M BOYER
0109
PUT USB CUTOUT BACK AS A MOLDING OPTION
15-Jan-09
D.C.
4
M BOYER
0210
SHOW ONE PCB
27-Jan-10
D.C.
4.1
M BOYER
0710
UPDATE FORMAT
20-Mar-10
D.C.
4.2
M BOYER
3310
UPDATE BOM
31-Aug-10
D.C.
4.3
M BOYER
0411
UPDATE LABEL RECESS TO AS-BUILT
10-Feb-11
D.C.
4.4
M BOYER
1211
INCLUDE PCB SCREW INFORMATION
11-Apr-11
D.C.
4.5
M BOYER
1911
UPDATE PCB HOLE RECOMMENDATIONS
26-May-11
D.C.
4.6
M BOYER
2711
CHANGE ASSEMBLY DIMENSIONS TO "PRESS FIT"
21-Oct-11
D.C.
5.0
M BOYER
1113
UPDATE TO AS BUILT
18-Mar-13
D.C.
5.1
R CRUZ
3013
UPDATE TEXTURE CALLOUT
04-Jun-13
D.C.
5.2
R CRUZ
1614
REMOVE PCB SCREW PART NUMBER
02-Apr-14
3
1
4
MOLDED CUTOUT
(OPTIONAL)
FOR TYPE A USB
ON STANDARD PCB
ATTACHED TO COVER
2
NOTES:
SCALE 1.500
EXPLODED VIEW
SCALE 1.000
UNLESS OTHERWISE SPECIFIED
1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM.
2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVALENT TO MT-11020.
3. INTERIOR SURFACE TEXTURE: NONE
4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED.
SCALE 1.500
5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF
THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT
THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED.
6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS
OTHERWISED SPECIFIED.
7. THIS ENCLOSURE IS A PRESS FIT ASSEMBLY. FOR PERMANENT CLOSURE: A DROP
OF ADHESIVE OR ULTRASONIC WELDING IS REQUIRED.
8. MOUNTING SCREWS FOR THE PCB ARE CUSTOMER SUPPLIED.
9. MATERIAL / COLOR:
ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM
MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE.
10. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION
OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH CUSTOMER.
11. STANDARD OR CUSTOM LABEL RECESSES ARE AVAILABLE FOR QUOTE.
THIRD ANGLE PROJECTION
TOLERANCES: UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN U.S. INCHES.
X.XX = .015 X.XXXX = .001
X.XXX = .010
X.X° = 1°
DO NOT SCALE DRAWING
NOTICE: THE INFORMATION AND DATA
CONTAINED HEREIN IS CONSIDERED
PROPRIETARY TO ALLTEC INTEGRATED
MFG INC & SHALL REMAIN THE EXCLUSIVE
PROPERTY OF ALLTEC INTEGRATED MFG INC
THE HOLDER WILL ASSUME CUSTODY AND
CONTROL THAT THIS DOCUMENT WILL
NOT BE COPIED, REPRODUCED, OR
DISCLOSED WITHOUT THE EXPRESS WRITTEN
CONSENT OF ALLTEC INTEGRATED MFG INC
POSSESSION OF THIS DOCUMENT DOES
NOT CONSTITUTE A GRANT TO
MANUFACTURE ANY ITEMS.
© 2014
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
STANDARD - MINI REMOTE
PXX-260906X ASSEMBLY
SIZE
08-Apr-08
San Luis Obispo, CA. 93401
fax (805) 595-1024
www.newageenclosures.com
260906
DRAWING NAME
A 260906_R5_2
SHEET
1 OF 6
REV.DOC
5.2
2.578
P
A
U
(.006)
U
A
.898
.181
.476
P
SCALE 1.500
SECTION U-U
SCALE 3.000
.562
SECTION X-X
(.123)
OPTIONAL CUTOUT
SEE BILL
OF MATERIALS
PCB MOUNTED TO 260906 COVER, BUT
ALTERNATE PCB MOUNTING POSTS ARE
AVAILABLE IN THE BASE. ALTERNATE
POST HEIGHT MAY BE REQUIRED TO
ALIGN STANDARD USB OPENING.
VARIOUS POST HEIGHTS ARE
QUOTE.
PRESS FIT
CLOSURE
SEE NOTES
SECTION A-A
(.063)
(.275)
SECTION P-P
SCALE 2.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SIZE
08-Apr-08
fax (805) 595-1024
260906
DRAWING NAME
A 260906_R5_2
SHEET
2 OF 6
REV.DOC
5.2
260906 COVER
.115
(.100)
OPTIONAL
MOLD
CUTOUT
.062
"PRESS FIT"
.020
1.289
1.073
1.148
.000
.094
.786
.708
1.289
SECTION Y-Y
.132
X
.449
SECTION D-D
SCALE 3.000
.308
.037
.268
.476
.000
Y
Y
.268
.308
.449
X
SCALE 1.500
.055 WALL TYP.
LABEL RECESS AREA
AVAILABLE FOR CUSTOM TOOLING
.100 PCB POSTS
.270
1.289
1.190
1.000
.000
1.000
1.190
1.289
SECTION X-X
.449
.350
.300
.000
.125
.300
.350
.449
.040
.062
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
D
DATE
ENG.
SCALE
"PRESS FIT"
BY
CHECK
D
.125
AS NOTED
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SIZE
08-Apr-08
fax (805) 595-1024
260906
DRAWING NAME
A 260906_R5_2
SHEET
3 OF 6
REV.DOC
5.2
1.125
.000
.093
.734
1.165
260906 BASE
.292
.262
LABEL RECESS - .005 STANDARD
2 PLACES
CUSTOM INSERTS ARE AVAILABLE
F
.000
F
.262
.292
R.068
R.084
.055 WALL THICKNESS TYP.
.048
.122
5.0°
.155
OPTIONAL
MOLD
CUTOUT
SECTION F-F
1.289
1.190
1.000
.000
1.000
1.190
.107
1.289
.115
.449
.350
.300
.000
.475
.300
.350
.449
R.015
SCALE 1.500
"PRESS FIT"
.125
.062
.040
X.XXX = .010
X.X° = 1°
.312
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
.030
R1.000
.410
BY
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SIZE
08-Apr-08
fax (805) 595-1024
260906
DRAWING NAME
A 260906_R5_2
SHEET
4 OF 6
REV.DOC
5.2
P260906 PCB - CUSTOMER SUPPLIED
SIZES AND VERIFICATION OF ITS FIT ARE THE
SOLE RESPONSIBILITY OF THE OEM.
1.210
1.000
.000
1.000
1.210
(2.420)
.368
.300
.000
(.735)
.300
.368
SCALE 1.500
.092
.130 x 45°
4 PLACES
.063
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SIZE
08-Apr-08
fax (805) 595-1024
260906
DRAWING NAME
A 260906_R5_2
SHEET
5 OF 6
REV.DOC
5.2
2nd OPERATION DETAILS
NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE
CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT.
ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES
CALL (805) 595-1310 FOR PRICING AND SCHEDULE.
THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031"
MOLDED
TYPE A USB
OPENING
MOLDED
TYPE A USB
OPENING
P260906 COVER
SCALE 1.000
STEP NO
1
2
STEP NO
4
5
P260906 BASE
SCALE 1.000
PXX-260906X-XXX COVER
DESCRIPTION
CUTTER
T2 = .062" EM
T2 = .062" EM
PXX-260906X-XXX BASE
DESCRIPTION
CUTTER
T2 = .062" EM
T2 = .062" EM
ABS, BLACK
FIXTURE
106
106
ORIENTATION
ABS, BLACK
FIXTURE
106
106
ORIENTATION
PROGRAM
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
PROGRAM
BY
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SIZE
08-Apr-08
fax (805) 595-1024
260906
DRAWING NAME
A 260906_R5_2
SHEET
6 OF 6
REV.DOC
5.2
很抱歉,暂时无法提供与“P3A-260906U”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+52.291701+6.76962
- 5+44.725915+5.79016
- 10+41.8035410+5.41183
- 25+38.2293825+4.94913
- 50+35.7315250+4.62576
- 100+33.39789100+4.32365
- 250+30.54491250+3.95431
- 500+28.54918500+3.69594
- 1000+27.940941000+3.61720
