P3A-301910
P3A-301910
    NEWAGE
    ELECTRONIC HOUSING
P3A-301910 数据手册
NOTES: R E V I S I O N UNLESS OTHERWISE SPECIFIED 1. DIMENSIONS TO BE SYMMETRICAL ABOUT CENTERLINES WITHIN .003 TIR REV. DRAWN BY ECO No DESCRIPTION DATE APPROVED 1 M BOYER PRELIMINARY RELEASE 28-Oct-04 D.C. 2. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 2 M BOYER ADJUST TO AS-BUILT & ADD PCB INFO 17-Dec-04 D.C. 3. EXTERIOR SURFACE TEXTURE TO BE FINE MATTE FINISH. 3 M BOYER 0208 UPDATE FORMAT AND RELEASE 14-May-08 D.C. 4. INTERIOR SURFACE TEXTURE TO BE: NONE. 3.1 M BOYER 0710 UPDATE FORMAT 20-Mar-10 D.C. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 4.0 M BOYER 1710 ADD RIBS - MODIFY PCB SIZE 02-Jul-10 D.C. 5.0 M BOYER 4610 ADD RIBS, MODIFY ASSY POSTS 10-Nov-10 D.C. 6. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 6.0 M BOYER 5110 MODIFY ASSEMBLY POSTS 02-Dec-10 D.C. 7.0 M BOYER 5210 ADD STEP TO ASSEMBLY POSTS 07-Dec-10 D.C. 7.1 M BOYER 0511 UPDATE LABEL RECESS TO AS-BUILT 12-Feb-11 D.C. 7.2 M BOYER 2711 CHANGE ASSEMBLY DIMENSIONS TO "PRESS FIT" 21-Oct-11 7. STANDARD OR CUSTOM LABEL RECESSES ARE AVAILABLE UPON REQUEST FOR QUOTE. 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF EACH OWNER. 9. THIS ENCLOSURE IS A PRESS FIT ASSEMBLY. FOR PERMANENT CLOSURE: A DROP OF ADHESIVE OR ULTRASONIC WELDING IS REQUIRED. "PRESS FIT" 1.007 SCALE 1.500 ENCLOSURE HALVES ARE SELF-MATING WITH IDENTICAL COVER AND BASE. SECTION B-B SCALE 1.500 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. THIRD ANGLE PROJECTION X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° 3 #4 HiLo x .250" SCREW ZINK PLATED SOLD SEPERATELY 4 2 301910 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 1 301910 CASE HALF - STANDARD ABS BLACK or WHITE 2 ITEM DESCRIPTION MATERIAL COLOR QTY. BILL OF MATERIALS NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2010 = 1° NEW AGE ENCLOSURES DO NOT SCALE DRAWING Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - ELEC. HOUSING PXX-301910 ASSEMBLY SIZE 28-Oct-04 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 301910 DRAWING NAME A 301910_R7_2 SHEET 1 OF 4 REV.DOC 7.2 2.014 VARIOUS HEIGHT PCB MOUNTING POSTS ARE AVAILABLE UPON REQUEST. 1.472 .488 SEE DETAIL A 1.075 .350 X (.138 ) E L .138 E .795 3.001 1.133 .093 .250 .095 .922 x .010 R.250 SECTION .902 L-L .045 R.015 AROUND BASE OF POSTS SECTION X-X .220 .010 .020 L SEE DETAIL B X "PRESS FIT" .089 CASE HALF SCALE 0.900 (.214 ) (.138 ) TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° SECTION E-E .010 DETAIL B LABEL RECESS SCALE 10.000 DETAIL A MALE ASSEMBLY POST SCALE 1.800 = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. .094 STEPPED POSTS SCALE AS NOTED DRAWN BY .076 M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - ELEC. HOUSING PXX-301910 ASSEMBLY SIZE 28-Oct-04 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 301910 DRAWING NAME A 301910_R7_2 SHEET 2 OF 4 REV.DOC 7.2 P301910 PCB - CUSTOMER SUPPLIED PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. 2x .600 .688 .405 .538 .000 .688 .600 .538 .405 2x 1.375 .062 R.095 1.375 1.155 .735 .567 .125 2x 4x 2.750 .000 .567 2x .735 1.155 1.375 SCALE 1.500 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - ELEC. HOUSING PXX-301910 ASSEMBLY SIZE 28-Oct-04 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 301910 DRAWING NAME A 301910_R7_2 SHEET 3 OF 4 REV.DOC 7.2 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" SECTION PCB-PCB SCALE 1.250 SCALE 1.250 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° PXX-301910-XXX COVER STEP NO 1 2 3 DESCRIPTION - CUTTER T2 = .062" EM T2 = .062" EM T2 = .062" EM - FIXTURE - ORIENTATION - = 1° NEW AGE ENCLOSURES ABS, BLACK PROGRAM - Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - ELEC. HOUSING PXX-301910 ASSEMBLY SIZE 28-Oct-04 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 301910 DRAWING NAME A 301910_R7_2 SHEET 4 OF 4 REV.DOC 7.2
P3A-301910 价格&库存
很抱歉,暂时无法提供与“P3A-301910”相匹配的价格&库存,您可以联系我们找货
