P7P-382612
P7P-382612
    NEWAGE
    RASPBERRY PI3 TINKER ENCLOSURE
P7P-382612 数据手册
From Off-The-Shelf to Market-Ready© New Age Enclosures is your Single Source Solution. Let us quote modifying our Stock Enclosures to meet your end-use. visit newageenclosures.com/services or call 855-4NA-ENCL today. NOTES: UNLESS OTHERWISE SPECIFIED REV. DRAWN BY ECO No A M BOYER DR1622 B 3. INTERIOR SURFACE TEXTURE TO BE: B3 E V I S I O N DATE APPROVE PRELIMINARY RELEASE 2017-Oct-11 D.C. M BOYER REVISE SHAPE AND SIZE 2017-Nov-15 D.C. C M BOYER UPDATE MATERIAL TREE AND TEXTURE INFO 2018-Feb-16 D.C. D R CRUZ UPDATE NOTES, UPDATE OPTIONS TABLE 2018-Apr-23 D.C. 1.0 M BOYER 00519 UPDATE TO AS-BUILT AND REVISE NOTES 2019-Feb-07 D.C. 2.0 R CRUZ 02719 UPDATE TO AS-BUILT FOR NEW DIMENSIONS 2019-Oct-01 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVALENT TO MT-11020. TEXTURE ON ENCLOSURE WILL VARY FROM TIME TO TIME AS THE TOOL WEARS AND IT BECOMES NESSESARY TO REAPPLY. R DESCRIPTION 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 4 6. ONE DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. MATERIAL / COLOR: SEE OPTIONS TABLE FOR STANDARD MATERIAL AND COLOR OPTIONS. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. ALTERNATE RESINS HAVE DIFFERENT SHRINK RATES, AND WILL EFFECT DIMENSIONS. 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH CUSTOMER. 1 9. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 2 10. ALLOWABLE FLASH: 0.010 MAX. 11. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH, PROTRUDING OR BELOW FLUSH. 12. TRIM GATE WITHIN 0.030" OF FLUSH. 3 13. REFERENCE THE PRODUCT SPEC AND SERVICE GUIDE. SCALE 0.900 PXX-382612 OPTIONS MATERIAL, COLOR ABS, WHITE ABS, BLACK POLYCARBONATE, POLYCARBONATE, POLYCARBONATE, POLYCARBONATE, SCALE 0.900 THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES PREFIX CLEAR SEMI-TRANSLUCENT DARK RED SEMI-TRANSLUCENT SMOKE GRAY SEMI-TRANSLUCENT BLUE P1AP3AP0PP2PP4PP7P- X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° 4 382612_COVER 382612 COVER - STANDARD SEE TREE SEE TREE 1 3 382612_BASE 382612 BASE - STANDARD SEE TREE SEE TREE 1 2 382612_PCB_RASPBERRY_PI3 RASPBERRY Pi 3 MODEL B .050" THICK CUSTOMER SUPPLIED 1 1 SCREW_HILO-NO2X312 #2 HiLo x .312" SCREW ZINC PLATED 5/16" LONG 4 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2019 Customer's Part No: APPROVAL BY 382612 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 RASPBERRY Pi 3 ENCLOSURE PXX-382612-XXX SIZE 2017-Oct-11 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 382612_R2_0 SHEET 1 OF 4 REV.DOC 2.0 382612 ASSEMBLY 3.822 3.595 LABEL RECESS 2.415 Y 4X R.175 2.642 Y SCALE 0.750 .020 RECESS 1.246 SECTION Y-Y 2.950 1.750 4X .345 1.700 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 382612 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 RASPBERRY Pi 3 ENCLOSURE PXX-382612-XXX SIZE 2017-Oct-11 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 382612_R2_0 SHEET 2 OF 4 REV.DOC 2.0 382612 COVER .336 (1.911) .241 .000 1.372 (1.911) .100 (1.321) .352 .000 .297 .402 1.052 (1.321) SCALE 0.750 .095 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 382612 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 RASPBERRY Pi 3 ENCLOSURE PXX-382612-XXX SIZE 2017-Oct-11 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 382612_R2_0 SHEET 3 OF 4 REV.DOC 2.0 382612 BASE .890 SCALE 0.750 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 382612 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 RASPBERRY Pi 3 ENCLOSURE PXX-382612-XXX SIZE 2017-Oct-11 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 382612_R2_0 SHEET 4 OF 4 REV.DOC 2.0
P7P-382612 价格&库存
很抱歉,暂时无法提供与“P7P-382612”相匹配的价格&库存,您可以联系我们找货
