From Off-The-Shelf to Market-Ready© New Age Enclosures is your Single Source Solution.
Let us quote modifying our Stock Enclosures to meet your end-use.
visit newageenclosures.com/services or call 855-4NA-ENCL today.
NOTES:
UNLESS OTHERWISE SPECIFIED
REV.
DRAWN BY
ECO No
A
M BOYER
DR1622
B
3. INTERIOR SURFACE TEXTURE TO BE: B3
E
V
I
S
I
O
N
DATE
APPROVE
PRELIMINARY RELEASE
2017-Oct-11
D.C.
M BOYER
REVISE SHAPE AND SIZE
2017-Nov-15
D.C.
C
M BOYER
UPDATE MATERIAL TREE AND TEXTURE INFO
2018-Feb-16
D.C.
D
R CRUZ
UPDATE NOTES, UPDATE OPTIONS TABLE
2018-Apr-23
D.C.
1.0
M BOYER
00519
UPDATE TO AS-BUILT AND REVISE NOTES
2019-Feb-07
D.C.
2.0
R CRUZ
02719
UPDATE TO AS-BUILT FOR NEW DIMENSIONS
2019-Oct-01
1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM.
2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH.
EQUIVALENT TO MT-11020. TEXTURE ON ENCLOSURE
WILL VARY FROM TIME TO TIME AS THE TOOL WEARS AND
IT BECOMES NESSESARY TO REAPPLY.
R
DESCRIPTION
4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED.
5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE
LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED
BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS
4
6. ONE DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS
OTHERWISED SPECIFIED.
7. MATERIAL / COLOR: SEE OPTIONS TABLE FOR STANDARD MATERIAL AND
COLOR OPTIONS. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON
REQUEST FOR QUOTE. ALTERNATE RESINS HAVE DIFFERENT SHRINK
RATES, AND WILL EFFECT DIMENSIONS.
8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION
OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH CUSTOMER.
1
9. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED
BY THE SOLID MODEL FILE.
2
10. ALLOWABLE FLASH: 0.010 MAX.
11. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH,
PROTRUDING OR BELOW FLUSH.
12. TRIM GATE WITHIN 0.030" OF FLUSH.
3
13. REFERENCE THE PRODUCT SPEC AND SERVICE GUIDE.
SCALE 0.900
PXX-382612 OPTIONS
MATERIAL, COLOR
ABS, WHITE
ABS, BLACK
POLYCARBONATE,
POLYCARBONATE,
POLYCARBONATE,
POLYCARBONATE,
SCALE 0.900
THIRD ANGLE PROJECTION
TOLERANCES: UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN U.S. INCHES.
DO NOT SCALE DRAWING
NEW AGE ENCLOSURES
PREFIX
CLEAR
SEMI-TRANSLUCENT DARK RED
SEMI-TRANSLUCENT SMOKE GRAY
SEMI-TRANSLUCENT BLUE
P1AP3AP0PP2PP4PP7P-
X.XX = .015 X.XXXX = .001
X.XXX = .010
X.X° = 1°
4
382612_COVER
382612 COVER - STANDARD
SEE TREE
SEE TREE
1
3
382612_BASE
382612 BASE - STANDARD
SEE TREE
SEE TREE
1
2
382612_PCB_RASPBERRY_PI3
RASPBERRY Pi 3 MODEL B
.050" THICK
CUSTOMER SUPPLIED
1
1
SCREW_HILO-NO2X312
#2 HiLo x .312" SCREW
ZINC PLATED
5/16" LONG
4
DESCRIPTION
MATERIAL
COLOR
QTY.
ITEM
FILE
NAME
BILL OF MATERIALS
NOTICE: THE INFORMATION AND DATA
CONTAINED HEREIN IS CONSIDERED
PROPRIETARY TO ALLTEC INTEGRATED
MFG INC & SHALL REMAIN THE EXCLUSIVE
PROPERTY OF ALLTEC INTEGRATED MFG INC
THE HOLDER WILL ASSUME CUSTODY AND
CONTROL THAT THIS DOCUMENT WILL
NOT BE COPIED, REPRODUCED, OR
DISCLOSED WITHOUT THE EXPRESS WRITTEN
CONSENT OF ALLTEC INTEGRATED MFG INC
POSSESSION OF THIS DOCUMENT DOES
NOT CONSTITUTE A GRANT TO
MANUFACTURE ANY ITEMS.
© 2019
Customer's Part No:
APPROVAL
BY
382612
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
2240 South Thornburg Street
ph. (805) 595-1310
RASPBERRY Pi 3 ENCLOSURE
PXX-382612-XXX
SIZE
2017-Oct-11
Santa Maria, CA. 93455
fax (805) 595-1024
www.newageenclosures.com
A
DRAWING NAME
382612_R2_0
SHEET
1 OF 4
REV.DOC
2.0
382612 ASSEMBLY
3.822
3.595
LABEL RECESS
2.415
Y
4X R.175
2.642
Y
SCALE 0.750
.020 RECESS
1.246
SECTION Y-Y
2.950
1.750
4X .345
1.700
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
382612
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
PXX-382612-XXX
SIZE
2017-Oct-11
fax (805) 595-1024
A
DRAWING NAME
382612_R2_0
SHEET
2 OF 4
REV.DOC
2.0
382612 COVER
.336
(1.911)
.241
.000
1.372
(1.911)
.100
(1.321)
.352
.000
.297
.402
1.052
(1.321)
SCALE 0.750
.095
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
382612
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
PXX-382612-XXX
SIZE
2017-Oct-11
fax (805) 595-1024
A
DRAWING NAME
382612_R2_0
SHEET
3 OF 4
REV.DOC
2.0
382612 BASE
.890
SCALE 0.750
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
382612
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
PXX-382612-XXX
SIZE
2017-Oct-11
fax (805) 595-1024
A
DRAWING NAME
382612_R2_0
SHEET
4 OF 4
REV.DOC
2.0
很抱歉,暂时无法提供与“P1A-382612”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+96.611721+12.54938
