S6L-542713
S6L-542713
    NEWAGE
    WATER RESISTANT UTILITY
S6L-542713 数据手册
From Off-The-Shelf to Market-Ready© New Age Enclosures is your Single Source Solution. Let us quote modifying our Stock Enclosures to meet your end-use. visit newageenclosures.com/services or call 855-4NA-ENCL today. NOTES: R E V I S I O N UNLESS OTHERWISE SPECIFIED 1. CORNERS DRAWN SHARP TO BE R.010 MAXIMUM. REV. DRAWN BY DATE APPROVED A-L M BOYER PRELIMINARY DESIGN - SEE REV L FOR REV. A-L DESCRIPTIONS 17-Jun-13 D.C. 1.0 R CRUZ RELEASED TO MFG PER CUSTOMER 17-Jun-13 D.C. 1.1 M BOYER REVISE SCREW PART NUMBER 18-Jun-13 D.C. 2.0 R CRUZ 8513 O-RING TO BE SOLD WITH ENCLOSURE 30-Dec-13 D.C. 2.1 R CRUZ 02115 UPDATE NOTE 6 20-May-15 D.C. 3.0 R CRUZ 03115 CHANGE O-RING COLOR FROM NATURAL TO BLUE 06-Jul-15 D.C. 4.0 R CRUZ 00418 O-RING AND NOTE UPDATES 2. EXTERIOR SURFACE TEXTURE TO BE MT-11020, UNLESS SPECIFIED OTHERWISE 3. ALL INSIDE RADII .020R. UNLESS OTHERWISE SPECIFIED. 4. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 5. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. ECO No DESCRIPTION 2018-Jun-20 6. MATERIAL / COLOR: ENCLOSURE IN ASA PLASTIC IS STANDARD IN BLACK OR GREY. SLIGHT COSMETIC SWIRLING, BLUSHING, AND/OR DISCOLORATION CAN OCCUR IN THIS ENCLOSURE DUE TO UV INHIBITORS IN THE RESIN. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 7. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH OWNER. 8. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. FOR THE PCB ARE SOLD SEPERATELY. MOUNTING SCREWS 9. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 1 10. ALLOWABLE FLASH: 0.010 MAX. 11. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH, PROTRUDING OR BELOW FLUSH. 12. TRIM GATE WITHIN 0.030" OF FLUSH. 13. THIS ENCLOSURE IS CONSTRUCTED FOR INDOOR OR OUTDOOR USE TO PROVIDE A DEGREE OF PROTECTION TO THE EQUIPMENT INSIDE AGAINST THE INGRESS OF SOLID FORIEGN OBJECTS (FALLING DIRT); AND TO PROVIDE A DEGREE OF PROTECTION WITH RESPECT TO TO HARMFUL EFFECTS ON THE EQUIPMENT DUE TO THE INGRESS OF WATER (DRIPPING OR SPLASHING). 8 TEXTURE: MT-11020 TEXTURE: B1 POLISH 6 4 5 7 3 SCALE 0.700 SCALE 0.400 2 8 6-32_PHILLIPS_SCREW 6-32 PHILLIPS SCREW x .375" 18-8 STAINLESS S-MS 6-32.375 4 7 6-32X344_BRASS-INSERT 6-32 BRASS INSERT x .344" TRISTAR 632x344MB OVER-MOLDED 4 6 542713_ORING OR-156 ORING - STANDARD SHORE A INCLUDED 1 5 SCREW_HILO-NO4 #4 HiLo SCREW x .250" ZINC PLATED CUSTOMER SUPPLIED 4 4 SCREW-DRYWALLX750 DRYWALL SCREW REFERENCE ONLY CUSTOMER SUPPLIED 4 3 542713_PCB 542713 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 2 542713_WALL-BASE 542713 WALL BASE - STANDARD ASA BLACK or GREY 1 1 542713_COVER 542713 COVER - STANDARD ASA BLACK or GREY 1 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2018 Customer's Part No: APPROVAL BY 542713 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 WATER RESISTANT UTILITY SXL-542713-XXX SIZE 2009-Oct-12 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 542713_R4_0 SHEET 1 OF 6 REV.DOC 4.0 542713 ASSEMBLY .285 CLEAR 3.800 .775 CLEAR 2.730 1.300 Y 3.150 1.108 S S 4.620 5.430 .525 5.509 4.000 LABEL RECESS x2 0.012" Y R.095 R7.595 SECTION Y-Y 20.0° 1.920 SCALE 0.500 .093 1.270 RECESS R.270 .199 (.010) 2.020 RECESS .314 3.6° DRAFT INTERIOR 5° DRAFT EXTERIOR (R.048) SECTION S-S .090 SEE DETAIL A TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DETAIL A SCALE 2.000 X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 542713 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 WATER RESISTANT UTILITY SXL-542713-XXX SIZE 2009-Oct-12 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 542713_R4_0 SHEET 2 OF 6 REV.DOC 4.0 542713 COVER 3.530 2.730 1.920 Y .085 TYP. 2.980 +.002 .070 -.002 .850 2.500 5.350 -5° DRAFT/SIDE 4.620 5.430 E E .190 SECTION Y-Y R.500 R.275 Y R8.000 R7.595 R.095 20.0° SCALE 0.500 .020 .120 .093 .020 DETAIL D SCALE 1.500 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. .085 X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL SEE DETAIL D 2.650 -5° DRAFT/SIDE SECTION E-E BY 542713 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 WATER RESISTANT UTILITY SXL-542713-XXX SIZE 2009-Oct-12 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 542713_R4_0 SHEET 3 OF 6 REV.DOC 4.0 542713 WALL BASE 3.800 3.150 5° DRAFT TYP. 2.010 Y 2.020 R.270 .145 1.270 .285 .185 5.509 4.200 4.000 .105 1.108 E E .145 SCALE 0.500 .335 Y .187 SECTION Y-Y SEE DETAIL B OVER-MOLDED BRASS INSERT SEE B.O.M. ON SHEET 1 .060 4.0° .098 .140 .430 SECTION E-E .430 DETAIL B SCALE 3.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 542713 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 WATER RESISTANT UTILITY SXL-542713-XXX SIZE 2009-Oct-12 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 542713_R4_0 SHEET 4 OF 6 REV.DOC 4.0 542713 PCB - CUSTOMER SUPPLIED 2.500 2.100 2x .000 2.100 2x 2.500 PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. 1.180 1.005 2x .000 1.005 2x 1.180 R.400 SCALE 1.000 .120 4x .062 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 542713 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 WATER RESISTANT UTILITY SXL-542713-XXX SIZE 2009-Oct-12 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 542713_R4_0 SHEET 5 OF 6 REV.DOC 4.0 542713 - 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" SCALE 1.000 SXL-542712-XXX COVER - ASA, BLACK STEP DESCRIPTION CUTTER FIXTURE ORIENTATION PROGRAM 1-C-C1 2-C-C2 3-C-C3 - T2 = .062" EM T2 = .062" EM T2 = .062" EM 246 246 246 - - SXL-542712-XXX COVER STEP TYPE FIXTURE INK COLOR 4-C-P1 PAD PRINT 246 WHITE - ASA, BLACK TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 542713 DATE CHECK ENG. CLICHE DESCRIPTION CLICHE No. LOGO AND LABELS CL1010 R1 SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 WATER RESISTANT UTILITY SXL-542713-XXX SIZE 2009-Oct-12 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 542713_R4_0 SHEET 6 OF 6 REV.DOC 4.0
S6L-542713
1. 物料型号:文档中提到了多种物料型号,例如6-32 PHILLIPS SCREW、6-32X344 BRASS-INSERT、542713 ORING等。
2. 器件简介:文档描述了New Age Enclosures提供的产品,包括CNC切割、部件装饰、定制颜色和材料、RF/EMI屏蔽、定制工具插入、定制外壳和设计。
3. 引脚分配:文档中没有明确提到具体的引脚分配信息。
4. 参数特性:文档提到了材料/颜色信息,例如外壳标准为ASA塑料,颜色为黑色或灰色。还提到了O型圈的材质为Shore A,并包含了一些公差信息。
5. 功能详解:文档中描述了外壳的构造,适用于室内或室外使用,可保护内部设备免受固体异物(如落尘)和水(如滴溅)的影响。
6. 应用信息:文档提到了New Age Enclosures可以根据客户需求提供定制服务,包括修改标准外壳以满足特定用途。
7. 封装信息:文档中提到了外壳的尺寸和公差信息,以及一些特定的制造细节,如CNC加工、垫印、组装和配送。
S6L-542713 价格&库存
很抱歉,暂时无法提供与“S6L-542713”相匹配的价格&库存,您可以联系我们找货
