S1A-251510
S1A-251510
    NEWAGE
    MINI AAA BATTERY BOX
S1A-251510 数据手册
NOTES: UNLESS OTHERWISE SPECIFIED REV. DRAWN BY 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. DATE APPROVED PRELIMINARY RELEASE 16-Mar-2009 D.C. 2109 UPDATE MODEL, ADD DRAFT AND FORMAT 18-Apr-2009 D.C. M BOYER 4309 ADD SURFACE CALLOUT AND MODIFY HATCH 14-Dec-2009 D.C. 3.1 M BOYER 0710 UPDATE FORMAT 20-Mar-2010 D.C. 4.0 M BOYER 1210 ADD CORING IN REAR 04-May-2010 D.C. 4.1 M BOYER 2810 UPDATE VIEWS AND 2ND-OP PAGE 28-Jul-2010 D.C. 1 M BOYER 2 M BOYER 3 4. ALL INSIDE RADII .010R. ALL OUTSIDE RADII .020R MAX, UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVALENT TO MT-11020. 3. INTERIOR SURFACE TEXTURE TO BE: NONE 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH CUSTOMER. 9. ASSEMBLY HARDWARE PROVIDED. R E V I S I O N DESCRIPTION ECO No 5.0 R CRUZ 7713 ADD "TALL" CONFIGURATION 01-Nov-2013 D.C. 6.0 R CRUZ 2214 INCLUDE WALL CRADLE OPTION 19-May-2014 D.C. 7.0 M BOYER 0814 CHANGE TEXTURE CALLOUT 21-May-2014 D.C. 7.1 R CRUZ 0361 UPDATE WALL CRADLE DIMENSIONS TO AS BUILT 18-Jun-2014 D.C. 8.0 M BOYER 5214 REMOVE TALL CONFIG AND INCLUDE PCB NOTCH 15-Dec-2014 BATTERY CONTACTS SOLD SEPERATELY 10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 251510(x) CONFIGURATIONS -Blank -K 251510 COVER 1 1 251510 BASE 1 251510 MACHINED BASE 1 251510 HATCH 1 1 251510 WALL CRADLE 1 #2 HiLo SCREW .375" 4 4 5 2 -WP 4 8 1 1 10 STANDARD 251510 SCALE 0.750 9 3 6 10 AAA-SINGL-CONTACT-POS ACC-AAAPOS-5226 SPRING STEEL SOLD SEPERATELY 1 9 AAA-SINGL-CONTACT-NEG ACC-AAANEG-5204 SPRING STEEL SOLD SEPERATELY 1 8 AAA-DBL-CONTACT ACC-AAADBL-5214L SPRING STEEL SOLD SEPERATELY 1 7 251510_WALL-CRADLE 251510 WALL CRADLE - STANDARD ABS BLACK or WHITE 1 6 251510_HATCH 251510 HATCH - STANDARD ABS BLACK or WHITE 1 5 251510_COVER 251510 COVER - STANDARD ABS BLACK or WHITE 1 4 251510_BASE 251510 BASE - STANDARD ABS BLACK or WHITE 1 3 NO_2_HI-LO_SCREW No2 HI-LO x .375" STEEL 3/8" LONG 4 2 251510_PCB REFERENCE ONLY CUSTOMER SUPPLIED .062" THICK 1 1 AAA-BATTERY REFERENCE ONLY CUSTOMER SUPPLIED "AAA" SIZE 2 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS 7 EXPLODED VIEW 251510K SCALE 0.600 THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2014 Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - MINI AAA SXX-251510X ASSEMBLY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 16-Mar-2009 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 251510 A DRAWING NAME 251510_R8_0 SHEET 1 OF 8 REV.DOC 8.0 .080 SECTION C-C P SEE DETAIL A R.165 F 1.599 SEE DETAIL B C 2.559 C SCALE 1.000 P F SECTION F-F SECTION P-P .925 .268 PCB CAPTURED 1.070 DETAIL B SCALE 2.000 SECTION Y-Y DETAIL A SCALE 2.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: NOTE: BATTERY CONTACT TABS CAN BE PUSHED THROUGH THE PCB AND SOLDERED TO THE SURFACE OR THE TAB CAN BE BENT BACK AT 90° AND WIRED. APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - MINI AAA SXX-251510X ASSEMBLY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 16-Mar-2009 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 251510 A DRAWING NAME 251510_R8_0 SHEET 2 OF 8 REV.DOC 8.0 S251510 - COVER .025 SECTION F-F .525 1.599 1.250 .515 D (.178) .267 F F 2.559 SCALE 1.000 2.000 251510 STANDARD SECTION D-D D .062 .188 .925 R.165 3.0° TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° .025 NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - MINI AAA SXX-251510X ASSEMBLY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 16-Mar-2009 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 251510 A DRAWING NAME 251510_R8_0 SHEET 3 OF 8 REV.DOC 8.0 .150 S251510 - BASE .250 .045 .525 .870 .093 J 2.000 INSIDE LABEL AREA 1.885 1.250 .090 .960 E E SECTION J-J SCALE 1.000 .250 J .175 3.0° .250 R.207 .057 .150 SECTION E-E TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - MINI AAA SXX-251510X ASSEMBLY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 16-Mar-2009 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 251510 A DRAWING NAME 251510_R8_0 SHEET 4 OF 8 REV.DOC 8.0 1.452 S251510 - WALL CRADLE .360 .190 SECTION Y-Y 1.000 .695 .170 2.756 1.700 2.0° SCALE 1.000 .374 .180 SECTION X-X 2nd OPERATION REQUIRED ON 251510 BASE TO ACCEPT CRADLE TABS .360 SECTION Y-Y TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - MINI AAA SXX-251510X ASSEMBLY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 16-Mar-2009 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 251510 A DRAWING NAME 251510_R8_0 SHEET 5 OF 8 REV.DOC 8.0 1.160 1.075 x2 1.000 x2 .800 .000 .800 .830 x2 1.000 x2 1.160 S251510 - PCB .690 .625 x2 .225 x2 .000 .125 .225 x2 .030 R.078 .625 x2 .690 SCALE 2.000 .015 R.125 .063 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: NOTE 1. BATTERY CONNECTION POINTS SHOWN AT BOTH ENDS TO ALLOW ALTERNATE ASSEMBLY OPTION. APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - MINI AAA SXX-251510X ASSEMBLY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 16-Mar-2009 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 251510 A DRAWING NAME 251510_R8_0 SHEET 6 OF 8 REV.DOC 8.0 2nd OPERATION DETAILS (PAGE 1 OF 2) NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" .353 NOTCHES FOR WALL CRADLE .094 4x .303 4x .348 .000 .348 251510 BASE SCALE 1.000 STEP 1 STEP 2 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES STEP NO 1-B-C1 2-B-C2 SXX-251510X-XXX BASE DESCRIPTION CRADLE NOTCHES CRADLE NOTCHES CUTTER T2 = .062" EM T2 = .062" EM - ABS, BLACK FIXTURE 190 190 ORIENTATION SINGLE SINGLE Customer's Part No: APPROVAL PROGRAM - BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - MINI AAA SXX-251510X ASSEMBLY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 16-Mar-2009 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 251510 A DRAWING NAME 251510_R8_0 SHEET 7 OF 8 REV.DOC 8.0 2nd OPERATION DETAILS (PAGE 2 OF 2) NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" 251510 COVER SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES STEP NO 1-C-C1 2-C-C2 SXX-251510X-XXX COVER DESCRIPTION - CUTTER T2 = .062" EM T2 = .062" EM - ABS, BLACK FIXTURE 190 190 ORIENTATION - Customer's Part No: APPROVAL PROGRAM - BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - MINI AAA SXX-251510X ASSEMBLY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 16-Mar-2009 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 251510 A DRAWING NAME 251510_R8_0 SHEET 8 OF 8 REV.DOC 8.0
S1A-251510 价格&库存
很抱歉,暂时无法提供与“S1A-251510”相匹配的价格&库存,您可以联系我们找货
