S3A-261707-K
S3A-261707-K
    NEWAGE
    AAA FOB - KIT
S3A-261707-K 数据手册
NOTES: UNLESS OTHERWISE SPECIFIED REV. DRAWN BY 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. A M BOYER 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVALENT TO MT-11006. B 3. INTERIOR SURFACE TEXTURE TO BE: NONE. 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. R E V I S I O N DESCRIPTION ECO No DR XXX DATE APPROVED PRELIMINARY RELEASE 17-May-13 D.C. M BOYER REVISE PART NUMBER AND REVISE PER MEETING 25-Jun-13 D.C. C R CRUZ ADD BELT CLIP INFORMATION 18-Oct-13 D.C. D M BOYER REVISE BELT CLIP 11-Nov-13 D.C. E M BOYER REVISE PER MEETING NOV 18 2013 19-Nov-13 D.C. F R CRUZ UPDATE CONFIGURATION TABLE 27-May-14 D.C. 12-Jun-14 D.C. 1.0 R CRUZ 0319 UPDATE TO AS BUILT AND RELEASE 2.0 M BOYER 03015 REDUCE THICKNESS OF BATTERY CONTACT SLOT 2015-Jul-07 7. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH OWNER. 2 9. STANDARD OR CUSTOM LABEL RECESSES ARE AVAILABLE FOR QUOTE. 10. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. 4 11. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 10 8 SCALE 0.750 1 261707(x) CONFIGURATIONS -Blank -BC 261707 COVER 1 261707 BASE 1 261707 HATCH 1 261707 BELT CLIP 1 #4 HiLo SCREW .375" 2 10 NO4_HI-LO 9 -K 1 1 1 1 2 SCREW - HiLo #4 6 7 No4 HiLo x 3/8" ZINC PLATED 2 9 AAA-SINGL-CONTACT-POS ACC-AAAPOS-5226 SOLD SEPERATELY NICKEL PLATED 1 8 AAA-SINGL-CONTACT-NEG ACC-AAANEG-5204 SOLD SEPERATELY NICKEL PLATED 1 7 AAA-DBL-CONTACT ACC-AAADBL-5214L SOLD SEPERATELY NICKEL PLATED 1 6 AAA-BATTERY AAA BATTERY REFERENCE CUSTOMER SUPPLIED 2 5 261707-PCB 261707 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 4 261707-HATCH 261707 HATCH - STANDARD ABS BLACK or WHITE 1 3 261707-COVER 261707 COVER - STANDARD ABS BLACK or WHITE 1 2 261707-BELT-CLIP 261707 BELT CLIP ABS BLACK or WHITE 1 1 261707-BASE 261707 BASE - STANDARD ABS BLACK or WHITE 1 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS 3 SCALE 0.750 5 THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2017 Customer's Part No: APPROVAL BY 261707 2240 South Thornburg Street ph. (805) 595-1310 AAA FOB - STANDARD SXX-261707-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2013-May-17 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 261707_R2_0 SHEET 1 OF 8 REV.DOC 2.0 .875 [22,22] .735 [18,67] .550 2x [13,97] .265 [6,73] (.700 ) [17,78] .000 [0] .875 [22,22] .875 [22,22] .590 [14,98] .000 [0] .692 [17,58] .875 [22,22] 261707 ASSEMBLY 1.310 [33,27] 1.310 [33,27] 1.122 [28,5] 1.000 [25,4] .798 [20,26] .088 [2,24] LABEL RECESS x .012" DEEP .125 CLEAR [3,18] Y .062 PCB [1,57] (2.620 ) [66,55] .000 [0] LABEL RECESS x .012" DEEP Y .313 CLEAR [7,95] .000 [0] .798 [20,26] 1.122 [28,5] 1.000 [25,4] 1.310 [33,27] R.100 [2,54] 1.310 [33,27] SECTION R-R SCALE 1.000 R.135 [3,43] R.225 [5,71] R.250 [6,35] .020 [0,51] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES SECTION Y-Y Customer's Part No: APPROVAL BY 261707 2240 South Thornburg Street ph. (805) 595-1310 AAA FOB - STANDARD SXX-261707-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2013-May-17 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 261707_R2_0 SHEET 2 OF 8 REV.DOC 2.0 261707 COVER .070 [1,78] .000 [0] .340 [8,64] .152 [3,86] 1.750 [44,45] P 5.0° .035 [0,89] H 1.310 [33,27] H 1.000 [25,4] .725 [18,42] LABEL RECESS x 0.012 2.244 [57,01] 2.620 [66,547] .000 [0] .220 [5,59] .156 [3,96] .124 [3,15] .725 [18,42] 1.000 [25,4] .043 [1,09] .040 [1,02] 5.0° .875 [22,22] .017 [0,43] .550 x2 [13,97] 1.282 [32,56] .000 [0] P SCALE 1.000 1.310 [33,27] SECTION P-P .875 [22,22] R.085 [2,16] 10.0° .088 [2,24] 3.0° R.250 [6,35] DETAIL A SCALE 4.000 .066 [1,67] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: .040 [1,02] APPROVAL SECTION H-H BY 261707 2240 South Thornburg Street ph. (805) 595-1310 AAA FOB - STANDARD SXX-261707-XXX DATE CHECK SEE DETAIL A ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2013-May-17 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 261707_R2_0 SHEET 3 OF 8 REV.DOC 2.0 261707 BASE .615 [15,62] .400 [10,16] .875 [22,22] .000 [0] .875 [22,22] .000 [0] .550 [13,97] .340 [8,64] X 1.310 [33,27] 1.000 [25,4] Y Y .000 [0] .250 [6,35] 1.000 [25,4] SCALE 1.000 .088 [2,24] 1.310 [33,27] SECTION X-X X .053 [1,35] .073 [1,85] .320 [8,13] .125 [3,18] SEE DETAIL B .055 [1,4] SECTION Y-Y DETAIL B SCALE 2.000 .075 [1,91] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 261707 2240 South Thornburg Street ph. (805) 595-1310 AAA FOB - STANDARD SXX-261707-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2013-May-17 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 261707_R2_0 SHEET 4 OF 8 REV.DOC 2.0 261707 HATCH .258 [6,55] X 1.120 [28,44] SEE DETAIL D .060 [1,52] Y .620 [15,75] Y .000 [0] .030 [0,76] .620 [15,75] 1.120 [28,44] X SCALE 1.000 1.024 [26,02] .210 [5,33] .000 [0] .203 [5,15] SECTION X-X SEE DETAIL C .238 [6,04] SECTION Y-Y R.250 [6,35] .140 [3,56] .203 [5,15] DETAIL D SCALE 3.000 .065 [1,65] 40.0° .083 [2,11] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL DETAIL C SCALE 3.000 .075 [1,91] BY 261707 2240 South Thornburg Street ph. (805) 595-1310 AAA FOB - STANDARD SXX-261707-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2013-May-17 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 261707_R2_0 SHEET 5 OF 8 REV.DOC 2.0 261707 BELT CLIP 1.113 [28,27] .075 [1,91] 1.964 [49,89] .097 [2,45] G E E 2.267 [57,57] SCALE 0.750 G SECTION G-G 1.771 [44,98] .720 [18,29] SECTION E-E TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES .870 [22,1] Customer's Part No: APPROVAL BY 261707 2240 South Thornburg Street ph. (805) 595-1310 AAA FOB - STANDARD SXX-261707-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2013-May-17 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 261707_R2_0 SHEET 6 OF 8 REV.DOC 2.0 261707 PCB - CUSTOMER SUPPLIED PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. (1.380 ) [35,05] .600 [15,24] .000 [0] .200 [5,08] .550 2x [13,97] .780 [19,81] (.580 ) [14,73] 1.213 [30,8] 1.055 [26,8] 1.000 [25,4] .285 KEEP OUT ZONE 2x (2.425) [61,6] R.031 [0,79] .000 [0] HATCHED SECTION (LEGS) IS NOT NESESSARY FOR PROPER FUNCTION. (DESIGNER'S CHOICE) .195 2x [4,95] 1.000 [25,4] 1.213 [30,8] CENTER OF ENCLOSURE (NOT CENTER OF PCB) 1.055 [26,8] SCALE 1.000 .150 CHAMFER x 45° .062 [1,57] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 261707 2240 South Thornburg Street ph. (805) 595-1310 AAA FOB - STANDARD SXX-261707-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2013-May-17 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 261707_R2_0 SHEET 7 OF 8 REV.DOC 2.0 261707 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" 261807 COVER SCALE 1.000 261807 BASE SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES SXX-261707-XXX COVER STEP DESCRIPTION CUTTER 1-C-C1 2-C-C2 - T2 = .062" EM T2 = .062" EM - FIXTURE 295 295 ABS, BLACK Customer's Part No: APPROVAL ORIENTATION PROGRAM - o1001 o1002 BY 261707 2240 South Thornburg Street ph. (805) 595-1310 AAA FOB - STANDARD SXX-261707-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2013-May-17 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 261707_R2_0 SHEET 8 OF 8 REV.DOC 2.0
S3A-261707-K 价格&库存
很抱歉,暂时无法提供与“S3A-261707-K”相匹配的价格&库存,您可以联系我们找货
