S6L-272013
S6L-272013
    NEWAGE
    SMALL OUTDOOR UTILITY
S6L-272013 数据手册
From Off-The-Shelf to Market-Ready© New Age Enclosures is your Single Source Solution. Let us quote modifying our Stock Enclosures to meet your end-use. visit newageenclosures.com/services or call 855-4NA-ENCL today. NOTES: UNLESS OTHERWISE SPECIFIED 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. E I S I O N DATE APPROVE A M BOYER PRELIMINARY RELEASE 2017-Jun-07 D.C. B M BOYER REMOVE SCREW HOLES ENLARGE STRAP SLOT 2017-Jun-13 D.C. C M BOYER REVISE SLOT WITH SINGLE SCREW HOLE ADDED 2017-Jun-15 D.C. D M BOYER REVISE NOTES 2017-Jun-16 D.C. E M BOYER THICKEN WALL TABS 2017-Jun-22 D.C. F M BOYER INCREASE LENGTH BY .03 TO FIT OTS ORING 2018-Feb-16 D.C. G M BOYER INCREASE COVER HEIGHT 2018-Feb-21 D.C. I M BOYER ADD EAR GUSSETS 2018-Mar-16 D.C. J M BOYER INCLUDE CONFIG TREE 2018-Jun-18 D.C. K R CRUZ UPDATE O-RING DETAILS 2018-Aug-22 D.C. 1.0 R CRUZ UPDATE TO AS BUILT AND RELEASE TO MFG 2019-Feb-19 3. INTERIOR SURFACE TEXTURE TO BE: NONE. 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 00319 DESCRIPTION V DRAWN BY 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVALENT TO MT-11020. TEXTURE ON ENCLOSURE WILL VARY FROM TIME TO TIME AS THE TOOL WEARS AND IT BECOMES NESSESARY TO REAPPLY. ECO No R REV. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. MATERIAL / COLOR: ASA PLASTIC IS STANDARD IN BLACK OR GRAY. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. ALTERNATE RESINS HAVE DIFFERENT SHRINK RATES, AND WILL EFFECT DIMENSIONS. 2 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH CUSTOMER. 9. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. FOR THE PCB AND WALL ARE SOLD SEPARATELY. MOUNTING SCREWS 10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 4 11. ALLOWABLE FLASH: 0.010 MAX. 12. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH, PROTRUDING OR BELOW FLUSH. 9 13. TRIM GATE WITHIN 0.030" OF FLUSH. 7 14. THIS ENCLOSURE IS DESIGNED FOR OUTDOOR USE AND MEETS IPX7 INGRESS PROTECTION STANDARD. 6 5 3 SXX-272013(x) CONFIGURATIONS 272013 COVER w/ STANDARD TEXTURE 272013 COVER w/ POLISHED LABEL RECESS 272013 WALL BASE 272013 ORING 6-32 x .375" STAINLESS PHILLIPS SCREW -blank 1 1 1 4 -B1 1 1 1 1 4 8 SCALE 1.000 9 PEM-INSERT_6-32 PEM INSERT 6-32 x .250" BRASS OVER MOLDED 4 8 6-32_PHILLIPS_SCREW 6-32 PHILLIPS SCREW x .375" STAINLESS STEEL MMC 91772A146 4 7 272013-ORING SHORE A INCLUDED 1 6 SCREW_HILO-NO4X250 272013 ORING, #4 HiLo SCREW x .250" OR-036 ZINC PLATED CUSTOMER SUPPLIED 8 5 SCREW-DRYWALLX750 DRYWALL SCREW REFERENCE ONLY CUSTOMER SUPPLIED 2 4 272013-PCB-TOP 272013 TOP PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 3 272013-PCB-BOT 272013 BOTTOM PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 2 272013-COVER 272013 COVER - STANDARD ASA BLACK or GRAY 1 1 272013-BASE 272013 BASE - STANDARD ASA BLACK or GRAY 1 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS SCALE 0.900 THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2018 Customer's Part No: APPROVAL BY 272013 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 SM OUTDOOR UTILITY - STANDARD SXX-272013-XXX ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2017-Jun-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 272013_R1_0 SHEET 1 OF 6 REV.DOC 1.0 272013 ASSEMBLY 2.705 2.386 2.000 2.810 R.545 SCALE 1.000 .885 1.300 .030 .385 .175 .090 .285 .478 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: SECTION Y-Y .090 .173 APPROVAL BY 272013 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 SM OUTDOOR UTILITY - STANDARD SXX-272013-XXX ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2017-Jun-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 272013_R1_0 SHEET 2 OF 6 REV.DOC 1.0 272013 COVER 2.672 1.934 1.967 1.869 .716 1.229 .090 SCALE 1.000 (R.382) .100 1.255 CONFIG 272013B1 = LABEL RECESS POLISHED TO B1 FINISH 3.0° .885 .075 .154 .090 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. .664 X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES SECTION Y-Y 2.574 Customer's Part No: APPROVAL BY 272013 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 SM OUTDOOR UTILITY - STANDARD SXX-272013-XXX ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2017-Jun-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 272013_R1_0 SHEET 3 OF 6 REV.DOC 1.0 272013 WALL BASE 1.934 2.705 .821 .814 2.810 .716 1.229 2.386 SCALE 1.000 1.255 .385 .100 .085 .062 .180 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES SECTION Y-Y .085 Customer's Part No: .090 APPROVAL BY 272013 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 SM OUTDOOR UTILITY - STANDARD SXX-272013-XXX ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2017-Jun-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 272013_R1_0 SHEET 4 OF 6 REV.DOC 1.0 272013 PCB - CUSTOMER SUPPLIED 272013 O-RING PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. OR-036 DUROMETER 70A (MEDIUM) OR EQUIVALENT 1.207 .672 .628 .000 .672 .628 1.207 2.415 2.605 .062 .070 .855 .358 .319 .000 1.710 1.900 .319 .125 .358 R.285 .855 272013 TOP PCB SCALE 1.000 SCALE 1.000 2.375 .070 1.187 .628 .652 .000 .652 .628 1.187 2.364 ID .062 .835 2.504 OD .358 .299 .000 .299 .358 .125 R.285 .835 272013 BOTTOM PCB SCALE 1.000 1.670 OFF THE SHELF EQUIVALENT SCALE 0.500 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 272013 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 SM OUTDOOR UTILITY - STANDARD SXX-272013-XXX ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2017-Jun-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 272013_R1_0 SHEET 5 OF 6 REV.DOC 1.0 272013 - 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES SXX-272013-XXX COVER - Customer's Part No: ASA, BLACK APPROVAL STEP DESCRIPTION CUTTER FIXTURE ORIENTATION PROGRAM 1-C-C1 2-C-C2 - T2 = .062" EM T2 = .062" EM TBD TBD - o1001 o1002 BY 272013 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 SM OUTDOOR UTILITY - STANDARD SXX-272013-XXX ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2017-Jun-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 272013_R1_0 SHEET 6 OF 6 REV.DOC 1.0
S6L-272013 价格&库存
很抱歉,暂时无法提供与“S6L-272013”相匹配的价格&库存,您可以联系我们找货
