NOTES:
R E V I S I O N
UNLESS OTHERWISE SPECIFIED
1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM.
2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH.
EQUIVELANT TO MT-11010.
3. INTERIOR SURFACE TEXTURE TO BE: NONE
4. ALL INSIDE RADII .010R. ALL OUTSIDE RADII .020R MAX,
UNLESS OTHERWISE SPECIFIED.
5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT
THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES
AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE
FEATURE UNLESS OTHERWISE SPECIFIED.
REV.
DRAWN BY
ECO No
DESCRIPTION
DATE
APPROVED
A-G
M BOYER
PRELIMINARY THROUGH CONCEPT - SEE REV G
14-Jun-2012
D.C.
1.0
M BOYER
RELEASED TO MFG PER CUSTOMER
27-Nov-2012
D.C.
1.1
R CRUZ
4614
UPDATE TEXTURE CALLOUT
21-Oct-2014
D.C.
2.0
M BOYER
4914
INCLUDE WALL CRADLE
01-Dec-2014
D.C.
2.1
M BOYER
INCLUDE CRADLE TEXTURE CALLOUT
03-Apr-2015
D.C.
2.2
R CRUZ
02615
UPDATE WALL CRADLE NOTCH TOLERANCE ON BASE
22-May-2015
D.C.
2.3
M BOYER
04815
REVISE ASSY SCREW LENGTH
2015-Nov-05
6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS
OTHERWISED SPECIFIED.
7. MATERIAL / COLOR:
ABS PLASTIC IS STANDARD IN BLACK OR WHITE.
CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE.
5
8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND
VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF
EACH OWNER.
2
9. ASSEMBLY SCREWS FOR THE ENCLOSURE ARE PROVIDED. MOUNTING
SCREWS FOR PCB AND BATTERY CONTACTS SOLD SEPERATELY.
4
10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED
BY THE SOLID MODEL FILE.
11. ALLOWABLE FLASH: 0.010 MAX.
12. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH,
PROTRUDING OR BELOW FLUSH.
1
10
11
281109(x) CONFIGURATIONS
-Blank
281109 COVER
1
281109 BASE
1
281109 BASE MODIFIED (2nd OP)
281109 WALL CRADLE
281109 HATCH
1
#2 HiLo SCREW .312"
4
9
-K
1
-W
SCALE 0.900
1
1
1
4
6
1
7
11
AAA-SINGL-CONTACT-POS
ACC-AAAPOS-5226
SPRING STEEL
SOLD SEPERATELY
10
AAA-SINGL-CONTACT-NEG
ACC-AAANEG-5204
SPRING STEEL
SOLD SEPERATELY
1
1
9
AAA-DBL-CONTACT
ACC-AAADBL-5214L
SPRING STEEL
SOLD SEPERATELY
1
8
SCREW-DRYWALLX750
DRYWALL SCREW - REFERENCE
CUSTOMER SUPPLIED
DRYWALL SCREW
2
7
281109_WALL-CRADLE
281109 WALL CRADLE - STANDARD
ABS
BLACK or WHITE
1
6
281109_HATCH
281109 HATCH - STANDARD
ABS
BLACK or WHITE
1
5
281109_COVER
281109 COVER - STANDARD
ABS
BLACK or WHITE
1
4
281109_BASE-MODIFIED
281109 BASE - MODIFIED
ABS
BLACK or WHITE
1
3
SCREW_HILO-NO2X312
#2 HiLo x .312" SCREW
ZINK PLATED
5/16" LONG
4
2
281109_PCB
REFERENCE ONLY
CUSTOMER SUPPLIED
.062" THICK
1
1
AAA-BATTERY
REFERENCE ONLY
CUSTOMER SUPPLIED
"AAA" SIZE
2
DESCRIPTION
MATERIAL
COLOR
QTY.
ITEM
FILE
NAME
BILL OF MATERIALS
8
EXPLODED VIEW
SCALE 0.950
THIRD ANGLE PROJECTION
TOLERANCES: UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN U.S. INCHES.
DO NOT SCALE DRAWING
NEW AGE ENCLOSURES
X.XX = .015 X.XXXX = .001
X.XXX = .010
X.X° = 1°
NOTICE: THE INFORMATION AND DATA
CONTAINED HEREIN IS CONSIDERED
PROPRIETARY TO ALLTEC INTEGRATED
MFG INC & SHALL REMAIN THE EXCLUSIVE
PROPERTY OF ALLTEC INTEGRATED MFG INC
THE HOLDER WILL ASSUME CUSTODY AND
CONTROL THAT THIS DOCUMENT WILL
NOT BE COPIED, REPRODUCED, OR
DISCLOSED WITHOUT THE EXPRESS WRITTEN
CONSENT OF ALLTEC INTEGRATED MFG INC
POSSESSION OF THIS DOCUMENT DOES
NOT CONSTITUTE A GRANT TO
MANUFACTURE ANY ITEMS.
© 2015
Customer's Part No:
APPROVAL
BY
DATE
ENG.
QUALITY
SCALE
AS NOTED
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
STANDARD - COMPACT AAA
SXX-281109X-XXX
SIZE
2012-Jun-15
San Luis Obispo, CA. 93401
fax (805) 595-1024
www.newageenclosures.com
281109
DRAWING NAME
A 281109_R2_3
SHEET
1 OF 8
REV.DOC
2.3
3.0°
DRAFT TYP.
.040
.940
.198
R.150
SECTION C-C
DETAIL A
SCALE 3.000
1.095
SEE DETAIL A
.020
B
C
2.809
C
SCALE 1.000
SECTION B-B
B
.075 x 45° CHAMFER
DOUBLE BATTERY CONTACT (BRIDGE)
SHOULD BE INSTALLED ON THIS END
OF THE ENCLOSURE.
R.150
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-281109X-XXX
SIZE
2012-Jun-15
fax (805) 595-1024
281109
DRAWING NAME
A 281109_R2_3
SHEET
2 OF 8
REV.DOC
2.3
281109 COVER
SEE DETAIL D
.025
.025
.163
SECTION F-F
DETAIL D
SCALE 4.000
.222
1.095
.600
R
3.0°
.035
F
F
(.197)
.075
.075
2.809
.075 CHAMFER D1
.071 CHAMFER D2
2.350
SECTION R-R
.062
R
.188
R.150
SCALE 1.000
.460
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-281109X-XXX
SIZE
2012-Jun-15
fax (805) 595-1024
281109
DRAWING NAME
A 281109_R2_3
SHEET
3 OF 8
REV.DOC
2.3
281109 BASE
.250 +3°
.662
.045
.460
.100
3.0°
3.0°
1.095
.157
R.150
.600
.875
R.050
.093 THRU
SEE DETAIL B
.015
.028
1.940
.150 -3°
.960
INSIDE
LABEL
AREA
2.350
2.809
E
E
SCALE 1.000
.250
SEE DETAIL C
.175
.057
6.0°
.495
DETAIL B
SCALE 3.000
.020
.250
SECTION E-E
R.207
.028
.982-3°
DRAFT/SIDE
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
.095
DETAIL C
SCALE 3.000
BY
DATE
CHECK
ENG.
.252
SCALE
AS NOTED
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-281109X-XXX
SIZE
2012-Jun-15
fax (805) 595-1024
281109
DRAWING NAME
A 281109_R2_3
SHEET
4 OF 8
REV.DOC
2.3
281109 HATCH
2.390
X
X
1.073
.150 +5° DRAFT/SIDE
SCALE 1.000
R.200
R.150
.176
.105
.057
.450
.250
.018
3.0°
30.0°
.148
.075
.094
R.050
.974 -3°
R3.000
.500
.050
.018
.070
.050
SECTION X-X
SCALE 2.000
.105
.038
5.0°
.168
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-281109X-XXX
SIZE
2012-Jun-15
fax (805) 595-1024
281109
DRAWING NAME
A 281109_R2_3
SHEET
5 OF 8
REV.DOC
2.3
281109 PCB - CUSTOMER SUPPLIED
SIZES AND VERIFICATION OF IT'S FIT ARE THE
SOLE RESPONSIBILITY OF THE OEM.
1.310
1.175 2x
.955 x2
.375
.000
.040
.375
.955 x2
1.175 2x
1.310
(2.620)
FOUR BATTERY CONTACT
LOCATIONS SHOWN TO
ACCOMODATE POLARITY
VARIATIONS.
R.125
.450
.300 2x
.225 2x
(.900)
.150 4x
.000
.225 2x
.300 2x
.450
SCALE 2.000
.040 4x
.081
.156 4x
.015
.040
R.125
.063
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
NOTE
1. BATTERY CONNECTION POINTS SHOWN AT BOTH ENDS
TO ALLOW ALTERNATE ASSEMBLY OPTION.
BY
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-281109X-XXX
SIZE
2012-Jun-15
fax (805) 595-1024
281109
DRAWING NAME
A 281109_R2_3
SHEET
6 OF 8
REV.DOC
2.3
281109 WALL CRADLE & 281109 BATTERY BASE
2nd OPERATION DETAILS - PAGE 1 of 2
3.0°
-Blank
281109 COVER
1
281109 BASE
1
281109 WALL CRADLE
281109 HATCH
1
#2 HiLo SCREW .312"
4
NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE
CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT.
ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES
CALL (805) 595-1310 FOR PRICING AND SCHEDULE.
THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031"
3.0°
.575
A
-K
1
1
1
1
4
-W
1
.370
.085
.100
100.0°
C
MT-11010 TEXTURE
C
2.948
2.000
1.050
2.806 -2°
DRAFT/SIDE
.125
.187
.065
.370
.350
A
.250 -10°
DRAFT/SIDE
.600
.056 CHAMFER D1
2.0°
.015 CHAMFER D2
SECTION A-A
281109 WALL CRADLE
SCALE 1.000
SCALE 1.000
.60
.888
45.0°
.32
R.04
(.070)
.60
SECTION C-C
2.2
.065
.368±.005
R.100
.368±.005
2.2
.125
NOTCHES MUST BE ADDED
TO SECURE BASE TO
WALL CRADLE
4 PLACES
1.100
SXX-281109-XXX BASE
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
ABS, BLACK
APPROVAL
STEP NO
DESCRIPTION
CUTTER
FIXTURE
ORIENTATION
PROGRAM
1-B-C1
2-B-C2
2 WALL SLOTS ON END
2 WALL SLOTS ON END
T2 = .062" EM
T2 = .062" EM
297
297
DUAL
DUAL
o4901
o4901
BY
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-281109X-XXX
SIZE
2012-Jun-15
fax (805) 595-1024
281109
DRAWING NAME
A 281109_R2_3
SHEET
7 OF 8
REV.DOC
2.3
PAGE 2 of 2
-Blank
281109 COVER
1
281109 BASE
1
281109 WALL CRADLE
281109 HATCH
1
#2 HiLo SCREW .312"
4
-K
1
1
1
1
4
-W
1
281109 COVER
SCALE 1.000
STEP NO
1-C-C1
2-C-C2
STEP NO
3-C-P1
SXX-281109-XXX
DESCRIPTION
DESCRIPTION
PAD PRINT
COVER
CUTTER
T2 = .062" EM
T2 = .062" EM
SXX-281109-XXX
INK COLOR
ABS, BLACK
FIXTURE
290
290
COVER
FIXTURE
291
ORIENTATION
ABS, BLACK
CLICHE DESCRIPTION
PROGRAM
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
CLICHE No.
SCALE
AS NOTED
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-281109X-XXX
SIZE
2012-Jun-15
fax (805) 595-1024
281109
DRAWING NAME
A 281109_R2_3
SHEET
8 OF 8
REV.DOC
2.3
很抱歉,暂时无法提供与“S1A-281109-K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5+77.869495+10.08177
