S3A-292910
S3A-292910
    NEWAGE
    ROUND PUCK
S3A-292910 数据手册
NOTES: UNLESS OTHERWISE SPECIFIED 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. REV. DRAWN BY ECO No A M BOYER DRXXX B 1.0 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVALENT TO MT-11010. TEXTURE ON ENCLOSURE WILL VARY FROM TIME TO TIME AS THE TOOL WEARS AND IT BECOMES NESSESARY TO REAPPLY. R DESCRIPTION E V I S I O N DATE APPROVE PRELIMINARY RELEASE 2017-May-03 D.C. R CRUZ REVISE ENCLOSURE NAME 2017-Jul-25 D.C. R CRUZ UPDATE SHEETS AND RELEASE TO REV 1 PER CUSTOMER 2017-Aug-11 3. INTERIOR SURFACE TEXTURE TO BE: NONE. 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. ALTERNATE RESINS HAVE DIFFERENT SHRINK RATES, AND WILL EFFECT DIMENSIONS. 3 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH CUSTOMER. 9. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. 10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 4 11. ALLOWABLE FLASH: 0.010 MAX. 12. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH, PROTRUDING OR BELOW FLUSH. 13. TRIM GATE WITHIN 0.030" OF FLUSH. 2 SCALE 1.000 1 THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° 4 292910-PCB 292910 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 3 292910-COVER 292910 COVER - STANDARD ABS BLACK or WHITE 1 2 292910-BASE 292910 BASE - STANDARD ABS BLACK or WHITE 1 1 SCREW_HILO-NO4X375 #4 HiLo x .375" SCREW ZINK PLATED 3/8" LONG 4 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2017 Customer's Part No: APPROVAL BY 292910 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - 2.9" ROUND SXX-292910-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2017-May-03 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 292910_R1_0 SHEET 1 OF 6 REV.DOC 1.0 292910 ASSEMBLY P X X P 2.900 [73,66] SCALE 0.700 .025 [0,64] .287 [7,29] .685 [17,4] .030 [0,76] SEE DETAIL A 1.027 [26,09] .090 [2,29] .227 [5,77] DETAIL A SCALE 1.500 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. SECTION P-P SECTION X-X .533 [13,54] .090 [2,29] X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 292910 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - 2.9" ROUND SXX-292910-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2017-May-03 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 292910_R1_0 SHEET 2 OF 6 REV.DOC 1.0 292910 COVER 65.0° P 25.0° 25.0° X X 65.0° 65.0° P 25.0° 25.0° SCALE 0.700 65.0° SECTION P-P TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° SECTION X-X NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 292910 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - 2.9" ROUND SXX-292910-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2017-May-03 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 292910_R1_0 SHEET 3 OF 6 REV.DOC 1.0 292910 BASE P X X P SCALE 0.700 SECTION P-P TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES SECTION X-X Customer's Part No: APPROVAL BY 292910 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - 2.9" ROUND SXX-292910-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2017-May-03 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 292910_R1_0 SHEET 4 OF 6 REV.DOC 1.0 292910 PCBPCB - CUSTOMER SUPPLIED SIZES ARE RECOMMENDATIONS ONLY. FINAL .750 [19,05] .000 [0] .750 [19,05] SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. 2.535 x 45° [64,39] .750 [19,05] 2.695 [68,45] .000 [0] .400 KEEP OUT [10,16] .750 [19,05] .100 KEEP OUT [2,54] SCALE 0.700 .250 [6,35] .062 [1,57] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 292910 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - 2.9" ROUND SXX-292910-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2017-May-03 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 292910_R1_0 SHEET 5 OF 6 REV.DOC 1.0 292910 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" 292910 COVER SCALE 1.000 292910 BASE SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES SXX-292910-XXX COVER - Customer's Part No: ABS, BLACK APPROVAL STEP DESCRIPTION CUTTER FIXTURE ORIENTATION PROGRAM 1-C-C1 2-C-C2 - T2 = .062" EM T2 = .062" EM - - o1001 o1002 BY 292910 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - 2.9" ROUND SXX-292910-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2017-May-03 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 292910_R1_0 SHEET 6 OF 6 REV.DOC 1.0
S3A-292910 价格&库存
很抱歉,暂时无法提供与“S3A-292910”相匹配的价格&库存,您可以联系我们找货
S3A-292910
  • 1+78.822851+10.20520
