S6L-303013
S6L-303013
    NEWAGE
    3 INCH ROUND OUTDOOR
S6L-303013 数据手册
From Off-The-Shelf to Market-Ready© New Age Enclosures is your Single Source Solution. Let us quote modifying our Stock Enclosures to meet your end-use. visit newageenclosures.com/services or call 855-4NA-ENCL today. NOTES: UNLESS OTHERWISE SPECIFIED 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVALENT TO MT-11010. TEXTURE ON ENCLOSURE WILL VARY FROM TIME TO TIME AS THE TOOL WEARS AND IT BECOMES NESSESARY TO REAPPLY. 3. INTERIOR SURFACE TEXTURE TO BE: NONE. 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. R E V I S I O N REV. DRAWN BY ECO No DESCRIPTION DATE APPROVE A M BOYER DR XXXX PRELIMINARY RELEASE 2017-Jun-27 D.C. B M BOYER REPLACED DOMED COVER WITH CURVED COVER 2017-Jul-13 D.C. C M BOYER REVISE ORING PATH 2017-Sep-08 D.C. D M BOYER UPDATE FEET HEIGHT 2018-Jan-09 D.C. E M BOYER UPDATE HEIGHT AND ADD STRAP 2018-Mar-08 D.C. F M BOYER ADAPT GENERIC FEATURES FOR NAE LINE 2018-Mar-19 D.C. G M BOYER UPDATE TEXTURE INFORMATION 2018-Apr-03 D.C. H M BOYER REVISE TITLE OF DRAWING 2018-Apr-06 D.C. I R CRUZ UPDATE TO #037 O-RING 2018-Apr-25 D.C. 1.0 R CRUZ UPDATE TO AS-BUILT AND RELEASE 2019-Aug-08 02219 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. MATERIAL / COLOR: ASA PLASTIC IS STANDARD IN BLACK OR GRAY. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. ALTERNATE RESINS HAVE DIFFERENT SHRINK RATES, AND WILL EFFECT DIMENSIONS. 2 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH CUSTOMER. 10. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. FOR THE PCB ARE SOLD SEPARATELY. MOUNTING SCREWS 11. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 6 12. ALLOWABLE FLASH: 0.010 MAX. 13. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH, PROTRUDING OR BELOW FLUSH. 4 14. THIS ENCLOSURE IS DESIGNED FOR OUTDOOR USE AND MEETS IPX7 INGRESS PROTECTION STANDARD. 3 7 1 SCALE 0.800 5 SCALE 0.900 7 303013-ORING #037 O-RING SILICONE 70A VARIES 1 6 PEM-INSERT_6-32 PEM INSERT 6-32 x .250" BRASS OVER MOLDED 4 5 6-32_PHILLIPS_SCREW 6-32 PHILLIPS SCREW x .500" STAINLESS STEEL MMC 91772A146 4 4 SCREW_HILO-NO4X250 #4 HiLo SCREW x .250" ZINC PLATED CUSTOMER SUPPLIED 4 3 303013-PCB 303013 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 2 303013-COVER 303013 COVER - STANDARD ASA BLACK or GRAY 1 1 303013-BASE 303013 BASE - STANDARD ASA BLACK or GRAY 1 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2018 Customer's Part No: APPROVAL BY 303013 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 3" ROUND OUTDOOR - STANDARD SXX-303013-XXX ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2017-Jun-27 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 303013_R1_0 SHEET 1 OF 8 REV.DOC 1.0 303013 ASSEMBLY P (3.010) (.236 MIN CLEARANCE) (.653 CLEARANCE) P SECTION P-P SCALE 1.000 SCALE 1.000 (.815) (.430) (.030) (1.275) TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 303013 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 3" ROUND OUTDOOR - STANDARD SXX-303013-XXX ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2017-Jun-27 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 303013_R1_0 SHEET 2 OF 8 REV.DOC 1.0 303013 ASSEMBLY X Y Y SCALE 1.000 X SECTION X-X SECTION Y-Y TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 303013 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 3" ROUND OUTDOOR - STANDARD SXX-303013-XXX ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2017-Jun-27 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 303013_R1_0 SHEET 3 OF 8 REV.DOC 1.0 303013 COVER 1.348 .640 (R10.000) Y Y 1.925 2.962 SCALE 1.000 .100 (20.0° ) SECTION Y-Y (.091) (.165) TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° .815 .130 NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 303013 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 3" ROUND OUTDOOR - STANDARD SXX-303013-XXX ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2017-Jun-27 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 303013_R1_0 SHEET 4 OF 8 REV.DOC 1.0 .000 303013 BASE 2.375 .245 X Y Y .000 SCALE 1.000 SECTION X-X X 6.0° 3.010 .070 .150 .430 SEE DETAIL A DETAIL A SCALE 4.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. SECTION Y-Y X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 303013 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 3" ROUND OUTDOOR - STANDARD SXX-303013-XXX ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2017-Jun-27 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 303013_R1_0 SHEET 5 OF 8 REV.DOC 1.0 303013 O-RING ( 2.629 OD) ( 2.489 ID) ( .070) # 037 O-RING SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 303013 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 3" ROUND OUTDOOR - STANDARD SXX-303013-XXX ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2017-Jun-27 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 303013_R1_0 SHEET 6 OF 8 REV.DOC 1.0 303013 PCB - CUSTOMER SUPPLIED .062 .805 .674 .785 .637 .000 .637 .785 .674 .805 PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. 1.332 .963 .605 .000 R.805 R.370 .605 .963 R.180 SCALE 1.000 1.332 .125 4x R1.332 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 303013 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 3" ROUND OUTDOOR - STANDARD SXX-303013-XXX ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2017-Jun-27 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 303013_R1_0 SHEET 7 OF 8 REV.DOC 1.0 303013 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES SXX-303013-XXX COVER - Customer's Part No: ASA, BLACK APPROVAL STEP NO DESCRIPTION CUTTER FIXTURE ORIENTATION PROGRAM 1-C-C1 2-C-C2 - T2 = .062" EM T2 = .062" EM - - o1001 o1002 BY 303013 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 3" ROUND OUTDOOR - STANDARD SXX-303013-XXX ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2017-Jun-27 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 303013_R1_0 SHEET 8 OF 8 REV.DOC 1.0
S6L-303013 价格&库存
很抱歉,暂时无法提供与“S6L-303013”相匹配的价格&库存,您可以联系我们找货
