From Off-The-Shelf to Market-Ready© New Age Enclosures is your Single Source Solution.
Let us quote modifying our Stock Enclosures to meet your end-use.
visit newageenclosures.com/services or call 855-4NA-ENCL today.
NOTES:
UNLESS OTHERWISE SPECIFIED
1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM.
2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH.
EQUIVALENT TO MT-11010. TEXTURE ON ENCLOSURE
WILL VARY FROM TIME TO TIME AS THE TOOL WEARS AND
IT BECOMES NESSESARY TO REAPPLY.
3. INTERIOR SURFACE TEXTURE TO BE: NONE.
4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED.
5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE
LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED
BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS
R
E
V
I
S
I
O
N
REV.
DRAWN BY
ECO No
DESCRIPTION
DATE
APPROVE
A
M BOYER
DR XXXX
PRELIMINARY RELEASE
2017-Jun-27
D.C.
B
M BOYER
REPLACED DOMED COVER WITH CURVED COVER
2017-Jul-13
D.C.
C
M BOYER
REVISE ORING PATH
2017-Sep-08
D.C.
D
M BOYER
UPDATE FEET HEIGHT
2018-Jan-09
D.C.
E
M BOYER
UPDATE HEIGHT AND ADD STRAP
2018-Mar-08
D.C.
F
M BOYER
ADAPT GENERIC FEATURES FOR NAE LINE
2018-Mar-19
D.C.
G
M BOYER
UPDATE TEXTURE INFORMATION
2018-Apr-03
D.C.
H
M BOYER
REVISE TITLE OF DRAWING
2018-Apr-06
D.C.
I
R CRUZ
UPDATE TO #037 O-RING
2018-Apr-25
D.C.
1.0
R CRUZ
UPDATE TO AS-BUILT AND RELEASE
2019-Aug-08
02219
6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS
OTHERWISED SPECIFIED.
7. MATERIAL / COLOR:
ASA PLASTIC IS STANDARD IN BLACK OR GRAY.
CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE.
ALTERNATE RESINS HAVE DIFFERENT SHRINK RATES, AND WILL EFFECT
DIMENSIONS.
2
8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION
OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH CUSTOMER.
10. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED.
FOR THE PCB ARE SOLD SEPARATELY.
MOUNTING SCREWS
11. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED
BY THE SOLID MODEL FILE.
6
12. ALLOWABLE FLASH: 0.010 MAX.
13. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH,
PROTRUDING OR BELOW FLUSH.
4
14. THIS ENCLOSURE IS DESIGNED FOR OUTDOOR USE
AND MEETS IPX7 INGRESS PROTECTION STANDARD.
3
7
1
SCALE 0.800
5
SCALE 0.900
7
303013-ORING
#037 O-RING
SILICONE 70A
VARIES
1
6
PEM-INSERT_6-32
PEM INSERT 6-32 x .250"
BRASS
OVER MOLDED
4
5
6-32_PHILLIPS_SCREW
6-32 PHILLIPS SCREW x .500"
STAINLESS STEEL
MMC 91772A146
4
4
SCREW_HILO-NO4X250
#4 HiLo SCREW x .250"
ZINC PLATED
CUSTOMER SUPPLIED
4
3
303013-PCB
303013 PCB - REFERENCE
.062" THICK
CUSTOMER SUPPLIED
1
2
303013-COVER
303013 COVER - STANDARD
ASA
BLACK or GRAY
1
1
303013-BASE
303013 BASE - STANDARD
ASA
BLACK or GRAY
1
DESCRIPTION
MATERIAL
COLOR
QTY.
ITEM
FILE
NAME
BILL OF MATERIALS
THIRD ANGLE PROJECTION
TOLERANCES: UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN U.S. INCHES.
DO NOT SCALE DRAWING
NEW AGE ENCLOSURES
X.XX = .015 X.XXXX = .001
X.XXX = .010
X.X° = 1°
NOTICE: THE INFORMATION AND DATA
CONTAINED HEREIN IS CONSIDERED
PROPRIETARY TO ALLTEC INTEGRATED
MFG INC & SHALL REMAIN THE EXCLUSIVE
PROPERTY OF ALLTEC INTEGRATED MFG INC
THE HOLDER WILL ASSUME CUSTODY AND
CONTROL THAT THIS DOCUMENT WILL
NOT BE COPIED, REPRODUCED, OR
DISCLOSED WITHOUT THE EXPRESS WRITTEN
CONSENT OF ALLTEC INTEGRATED MFG INC
POSSESSION OF THIS DOCUMENT DOES
NOT CONSTITUTE A GRANT TO
MANUFACTURE ANY ITEMS.
© 2018
Customer's Part No:
APPROVAL
BY
303013
DATE
CHECK
2240 South Thornburg Street
ph. (805) 595-1310
3" ROUND OUTDOOR - STANDARD
SXX-303013-XXX
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2017-Jun-27
Santa Maria, CA. 93455
fax (805) 595-1024
www.newageenclosures.com
A
DRAWING NAME
303013_R1_0
SHEET
1 OF 8
REV.DOC
1.0
303013 ASSEMBLY
P
(3.010)
(.236
MIN CLEARANCE)
(.653 CLEARANCE)
P
SECTION P-P
SCALE 1.000
SCALE 1.000
(.815)
(.430)
(.030)
(1.275)
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
303013
DATE
CHECK
ph. (805) 595-1310
SXX-303013-XXX
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2017-Jun-27
fax (805) 595-1024
A
DRAWING NAME
303013_R1_0
SHEET
2 OF 8
REV.DOC
1.0
303013 ASSEMBLY
X
Y
Y
SCALE 1.000
X
SECTION X-X
SECTION Y-Y
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
303013
DATE
CHECK
ph. (805) 595-1310
SXX-303013-XXX
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2017-Jun-27
fax (805) 595-1024
A
DRAWING NAME
303013_R1_0
SHEET
3 OF 8
REV.DOC
1.0
303013 COVER
1.348
.640
(R10.000)
Y
Y
1.925
2.962
SCALE 1.000
.100
(20.0° )
SECTION Y-Y
(.091)
(.165)
X.XXX = .010
X.X° = 1°
.815
.130
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
303013
DATE
CHECK
ph. (805) 595-1310
SXX-303013-XXX
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2017-Jun-27
fax (805) 595-1024
A
DRAWING NAME
303013_R1_0
SHEET
4 OF 8
REV.DOC
1.0
.000
303013 BASE
2.375
.245
X
Y
Y
.000
SCALE 1.000
SECTION X-X
X
6.0°
3.010
.070
.150
.430
SEE DETAIL A
DETAIL A
SCALE 4.000
SECTION Y-Y
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
303013
DATE
CHECK
ph. (805) 595-1310
SXX-303013-XXX
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2017-Jun-27
fax (805) 595-1024
A
DRAWING NAME
303013_R1_0
SHEET
5 OF 8
REV.DOC
1.0
303013 O-RING
( 2.629 OD)
( 2.489 ID)
( .070)
# 037 O-RING
SCALE 1.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
303013
DATE
CHECK
ph. (805) 595-1310
SXX-303013-XXX
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2017-Jun-27
fax (805) 595-1024
A
DRAWING NAME
303013_R1_0
SHEET
6 OF 8
REV.DOC
1.0
303013 PCB
- CUSTOMER SUPPLIED
.062
.805
.674
.785
.637
.000
.637
.785
.674
.805
SIZES AND VERIFICATION OF ITS FIT ARE THE
SOLE RESPONSIBILITY OF THE OEM.
1.332
.963
.605
.000
R.805
R.370
.605
.963
R.180
SCALE 1.000
1.332
.125 4x
R1.332
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
303013
DATE
CHECK
ph. (805) 595-1310
SXX-303013-XXX
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2017-Jun-27
fax (805) 595-1024
A
DRAWING NAME
303013_R1_0
SHEET
7 OF 8
REV.DOC
1.0
303013 2nd OPERATION DETAILS
NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE
CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT.
ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES
CALL (805) 595-1310 FOR PRICING AND SCHEDULE.
THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031"
SCALE 1.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
SXX-303013-XXX
COVER
Customer's Part No:
ASA, BLACK
APPROVAL
STEP NO
DESCRIPTION
CUTTER
FIXTURE
ORIENTATION
PROGRAM
1-C-C1
2-C-C2
T2 = .062" EM
T2 = .062" EM
o1001
o1002
BY
303013
DATE
CHECK
ph. (805) 595-1310
SXX-303013-XXX
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2017-Jun-27
fax (805) 595-1024
A
DRAWING NAME
303013_R1_0
SHEET
8 OF 8
REV.DOC
1.0
很抱歉,暂时无法提供与“S3L-303013”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+106.036601+13.77362
