S1A-303015-K
S1A-303015-K
    NEWAGE
    2 AA CUBE - KIT
S1A-303015-K 数据手册
From Off-The-Shelf to Market-Ready© New Age Enclosures is your Single Source Solution. Let us quote modifying our Stock Enclosures to meet your end-use. visit newageenclosures.com/services or call 855-4NA-ENCL today. V I S I O N DATE APPROVE A M BOYER PRELIMINARY RELEASE 2018-Oct-25 D.C. B M BOYER REVISE TITLE 2018-Nov-15 D.C. C M BOYER UPDATE MODEL PER REVIEW FEEDBACK 2019-Feb-25 D.C. D M BOYER REVISE PER FEEDBACK MEETING 2019-Apr-18 D.C. E M BOYER REVISE PER FA DESIGN REVIEW 2019-Jun-26 D.C. 1.0 R CRUZ UPDATE TO AS-BUILT 2019-Dec-17 03519 DESCRIPTION E DRAWN BY 2 ECO No R REV. NOTES: 6 UNLESS OTHERWISE SPECIFIED 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH, EQUIVELANT TO MT-11010. APPEARANCE AND DEPTH OF TEXTURE VARIES OVER TIME DUE TO WEAR. 1 3. INTERIOR SURFACE TEXTURE TO BE: AS MOLDED. 8 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 9 7. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 11 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH OWNER. 7 9. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. 10 10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 3 11. ALLOWABLE FLASH: 0.005 MAX. 12. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH, PROTRUDING OR BELOW FLUSH. 4 13. TRIM GATE WITHIN 0.015" OF FLUSH. 5 303015(x) CONFIGURATIONS -Blank -K 303015 COVER 1 1 303015 BATTERY BASE 1 303015 BATTERY WALL BASE 1 303015 BATTERY HATCH 1 303015 WALL PLATE 1 303015 PCB 1* 1* #4 HiLo SCREW .375" 4 4 * = NOT INCLUDED (CUSTOMER SUPPLIED) 303015 EXPLODED VIEW SCALE 0.660 11 AA-SINGL-CONTACT-POS ACC-AAPOS-5223 SPRING STEEL SOLD SEPARATELY 10 AA-SINGL-CONTACT-NEG ACC-AANEG-5201 SPRING STEEL SOLD SEPARATELY 1 1 9 AA-DBL-CONTACT ACC-AADBL-5212 SPRING STEEL SOLD SEPARATELY 1 8 SCREW_HILO-NO4X375 #4 HiLo x .375" SCREW ZINC PLATED INCLUDED 4 7 BATTERY_AA "AA" SIZE BATTERY REFERENCE CUSTOMER SUPPLIED 2 6 303015-PCB_062 303015 .062" PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 5 303015-WALLPLATE-FLAT 303015 WALL PLATE - STANDARD ABS BLACK or WHITE 1 4 303015-WALLBASE 303015 WALL BASE - STANDARD ABS BLACK or WHITE 1 3 303015-HATCH 303015 HATCH - STANDARD ABS BLACK or WHITE 1 2 303015-COVER 303015 COVER - STANDARD ABS BLACK or WHITE 1 1 303015-BASE 303015 BATTERY BASE - STANDARD ABS BLACK or WHITE 1 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2019 Customer's Part No: APPROVAL BY 303015 2240 South Thornburg Street ph. (805) 595-1310 2 AA CUBE - STANDARD SXX-303015X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2018-Oct-25 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 303015_R1_0 SHEET 1 OF 9 REV.DOC 1.0 303015 ASSEMBLY 1.500 [38,1] 3.000 [76,2] S SCALE 0.750 S R.400 [10,16] .550 [13,97] 1.527 (1.677) [38,79] [42,6] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL SECTION S-S BY 303015 2240 South Thornburg Street ph. (805) 595-1310 2 AA CUBE - STANDARD SXX-303015X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2018-Oct-25 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 303015_R1_0 SHEET 2 OF 9 REV.DOC 1.0 303015 COVER 2.733 [69,43] X Y Y SCALE 0.750 X R.267 [6,77] SECTION X-X .610 [15,49] .715 [18,16] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 303015 2240 South Thornburg Street ph. (805) 595-1310 2 AA CUBE - STANDARD SXX-303015X-XXX DATE CHECK ENG. SECTION Y-Y SCALE AS NOTED DRAWN BY M BOYER SIZE 2018-Oct-25 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 303015_R1_0 SHEET 3 OF 9 REV.DOC 1.0 303015 BASE .887 [22,53] 3.000 [76,2] X SCALE 0.750 X SECTION X-X OPEN SLOTS TO RECEIVE WALL PLATE AVAILABLE ON 303015K CONFIGURATION ONLY TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 303015 2240 South Thornburg Street ph. (805) 595-1310 2 AA CUBE - STANDARD SXX-303015X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2018-Oct-25 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 303015_R1_0 SHEET 4 OF 9 REV.DOC 1.0 303015 WALL BASE SECTION H-H X H H SCALE 0.750 X SECTION X-X TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 303015 2240 South Thornburg Street ph. (805) 595-1310 2 AA CUBE - STANDARD SXX-303015X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2018-Oct-25 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 303015_R1_0 SHEET 5 OF 9 REV.DOC 1.0 303015 HATCH 1.520 [38,61] X Y Y .015 [0,38] 2.020 [51,31] SCALE 0.750 X R.110 [2,79] SECTION X-X TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES SECTION Y-Y Customer's Part No: APPROVAL BY 303015 2240 South Thornburg Street ph. (805) 595-1310 2 AA CUBE - STANDARD SXX-303015X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2018-Oct-25 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 303015_R1_0 SHEET 6 OF 9 REV.DOC 1.0 303015 WALL PLATE 2.740 [69,6] X 1.500 [38,1] .150 [3,81] 2.530 [64,26] .170 [4,32] SECTION X-X SCALE 0.750 R.270 [6,86] X .472 [11,98] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 303015 2240 South Thornburg Street ph. (805) 595-1310 2 AA CUBE - STANDARD SXX-303015X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2018-Oct-25 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 303015_R1_0 SHEET 7 OF 9 REV.DOC 1.0 303015 PCB - CUSTOMER SUPPLIED 1.351 [34,31] .950 2x [24,13] .000 [0] .290 2x [7,37] .290 2x [7,37] .950 2x [24,13] 1.351 [34,31] PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. .062 [1,57] 1.351 [34,31] 1.085 2x [27,56] .950 2x [24,13] .385 x4 [9,78] KEEP OUT ZONE .000 [0] SEE DETAIL A .950 2x [24,13] 1.085 2x [27,56] .250 4x [6,35] R.251 [6,37] 1.351 [34,31] SCALE 0.750 .200 [5,08] DEPENDING ON HOW THE CONTACTS ARE USED, IN SERIES OR PARALLEL, THE BOARD WILL NEED TWO OR FOUR SOLDER HOLES. THE BATTERY CONTACTS CAN ALSO BE BENT 90 DEGREES AND WIRED TO THE BOARD INSTEAD OF DIRECTLY SOLDERED IN THESE LOCATIONS. .046 [1,17] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: DETAIL A SCALE 4.000 APPROVAL BY 303015 2240 South Thornburg Street ph. (805) 595-1310 2 AA CUBE - STANDARD SXX-303015X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2018-Oct-25 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 303015_R1_0 SHEET 8 OF 9 REV.DOC 1.0 303015 - 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" 303015 COVER SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES SXX-303015X-XXX COVER STEP NO DESCRIPTION CUTTER 1-C-C1 2-C-C2 - T2 = .062" EM T2 = .062" EM - FIXTURE - Customer's Part No: ABS, BLACK APPROVAL ORIENTATION PROGRAM - - BY 303015 2240 South Thornburg Street ph. (805) 595-1310 2 AA CUBE - STANDARD SXX-303015X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2018-Oct-25 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 303015_R1_0 SHEET 9 OF 9 REV.DOC 1.0
S1A-303015-K 价格&库存
很抱歉,暂时无法提供与“S1A-303015-K”相匹配的价格&库存,您可以联系我们找货
