S1A-312208
S1A-312208
    NEWAGE
    SMALL PROJECT BOX
S1A-312208 数据手册
NOTES: R E V I S I O N UNLESS OTHERWISE SPECIFIED 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVALENT TO MT-11010. 3. INTERIOR SURFACE TEXTURE TO BE: NONE. 4. ALL INSIDE RADII .010R. ALL OUTSIDE RADII .020R MAX, UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. REV. DRAWN BY ECO No DESCRIPTION DATE APPROVED A M BOYER DR XXX B M BOYER N/A PRELIMINARY RELEASE 03-Oct-09 D.C. CHANGE EXTERIOR 24-Oct-09 C M BOYER N/A RECESS AND CHAMFER ADJUSTMENTS D.C. 27-Oct-09 D.C. D M BOYER N/A REMOVE LABEL RECESS 30-Oct-09 D.C. 1.0 M BOYER N/A UPDATE TO AS-BUILT AND RELEASE 26-Mar-10 D.C. 2.0 M BOYER 2510 ADJUST POST HEIGHT 07-Jul-10 D.C. 2.1 R CRUZ 1014 UPDATE NOTES 17-Mar-14 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. MOUNTING SCREWS FOR THE PCB ARE CUSTOMER SUPPLIED. 8. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 9. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH CUSTOMER. 2 3 1 4 SCALE 1.500 THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° 4 SCREW_HILO-NO4X500 #4 HiLo x .500" SCREW #4 HiLo x 1/2" ZINK PLATED 2 3 312208_PCB 312208 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 2 312208_MALE 312208 MALE - STANDARD ABS BLACK-WHITE 1 1 312208_FEMALE 312208 FEMALE - STANDARD ABS BLACK-WHITE 1 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2014 Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - PROJECT BOX SXX-312208 ASSEMBLY SIZE 03-Oct-09 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 312208 DRAWING NAME A 312208_R2_1 SHEET 1 OF 6 REV.DOC 2.1 312208 ASSEMBLY 3.0° .100 15.0° .027 1.129 .875 .840 .000 2.257 1.129 .175 .875 .065 20.0° D 1.546 R R 3.092 SECTION D-D .000 1.546 D SCALE 1.000 2.0° TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. .538 CLEAR X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK SECTION R-R .100 CLEAR ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - PROJECT BOX SXX-312208 ASSEMBLY SIZE 03-Oct-09 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 312208 DRAWING NAME A 312208_R2_1 SHEET 2 OF 6 REV.DOC 2.1 312208 FEMALE .420 .027 T 1.040 .945 .875 .000 .875 2.257 .945 1.040 .100 .077 1.125 .780 .312 .250 3.092 .000 .125 R.090 P 1.125 P 1.453 SECTION T-T SCALE 1.000 T .040 .078 x4 .070 .330 SECTION P-P TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES .250 Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - PROJECT BOX SXX-312208 ASSEMBLY SIZE 03-Oct-09 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 312208 DRAWING NAME A 312208_R2_1 SHEET 3 OF 6 REV.DOC 2.1 312208 MALE .188 1.040 .875 .000 2.257 .875 .420 1.040 .658 .040 1.065 .780 Y Y .092 .000 3.092 +.001 -.001 .183 2x .202 1.065 1.453 SCALE 1.000 .040 4x .078 x4 NO DRAFT .070 20.0° TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: SECTION Y-Y (.533) APPROVAL .070 BY DATE CHECK ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - PROJECT BOX SXX-312208 ASSEMBLY SIZE 03-Oct-09 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 312208 DRAWING NAME A 312208_R2_1 SHEET 4 OF 6 REV.DOC 2.1 312208 PCB PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. .940 .875 .000 .875 .940 1.880 .062 1.450 (.125) .000 2.900 R.063 SCALE 1.000 1.450 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - PROJECT BOX SXX-312208 ASSEMBLY SIZE 03-Oct-09 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 312208 DRAWING NAME A 312208_R2_1 SHEET 5 OF 6 REV.DOC 2.1 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" 312208 MALE SCALE 1.000 312208 FEMALE SCALE 1.000 SXX-312208-XXX MALE STEP NO 1 2 DESCRIPTION - CUTTER T2 = .062" EM T2 = .062" EM - SXX-312208-XXX FEMALE STEP NO 4 5 DESCRIPTION - CUTTER T2 = .062" EM T2 = .062" EM SXX-312208-XXX MALE STEP TYPE FIXTURE 1 PAD PRINT 189 INK COLOR ABS, BLACK FIXTURE 189 189 - ABS, BLACK FIXTURE 189 189 - ORIENTATION ORIENTATION - ABS, BLACK CLICHE DESCRIPTION PROGRAM TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. PROGRAM - X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. CLICHE No. CL1010 R1 SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - PROJECT BOX SXX-312208 ASSEMBLY SIZE 03-Oct-09 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 312208 DRAWING NAME A 312208_R2_1 SHEET 6 OF 6 REV.DOC 2.1
S1A-312208 价格&库存
很抱歉,暂时无法提供与“S1A-312208”相匹配的价格&库存,您可以联系我们找货
S1A-312208
  • 1+79.006531+10.22161
  • 5+67.527105+8.73644
  • 10+63.1144710+8.16555
  • 25+57.7217525+7.46785
  • 50+53.9503650+6.97992
  • 100+50.42677100+6.52405
  • 250+46.11812250+5.96661
  • 500+44.36531500+5.73984
库存:3
