NOTES:
R E V I S I O N
UNLESS OTHERWISE SPECIFIED
1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM.
2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH.
EQUIVALENT TO MT-11010.
3. INTERIOR SURFACE TEXTURE TO BE: NONE.
4. ALL INSIDE RADII .010R. ALL OUTSIDE RADII .020R MAX,
UNLESS OTHERWISE SPECIFIED.
5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY
AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL
FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END
OF THE FEATURE UNLESS OTHERWISE SPECIFIED.
REV.
DRAWN BY
ECO No
DESCRIPTION
DATE
APPROVED
A
M BOYER
DR XXX
B
M BOYER
N/A
PRELIMINARY RELEASE
03-Oct-09
D.C.
CHANGE EXTERIOR
24-Oct-09
C
M BOYER
N/A
RECESS AND CHAMFER ADJUSTMENTS
D.C.
27-Oct-09
D.C.
D
M BOYER
N/A
REMOVE LABEL RECESS
30-Oct-09
D.C.
1.0
M BOYER
N/A
UPDATE TO AS-BUILT AND RELEASE
26-Mar-10
D.C.
2.0
M BOYER
2510
ADJUST POST HEIGHT
07-Jul-10
D.C.
2.1
R CRUZ
1014
UPDATE NOTES
17-Mar-14
6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS
PERMISSIBLE UNLESS OTHERWISED SPECIFIED.
7. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. MOUNTING
SCREWS FOR THE PCB ARE CUSTOMER SUPPLIED.
8. MATERIAL / COLOR:
ABS PLASTIC IS STANDARD IN BLACK
OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE
UPON REQUEST FOR QUOTE.
9. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND
VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY
OF EACH CUSTOMER.
2
3
1
4
SCALE 1.500
THIRD ANGLE PROJECTION
TOLERANCES: UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN U.S. INCHES.
DO NOT SCALE DRAWING
NEW AGE ENCLOSURES
X.XX = .015 X.XXXX = .001
X.XXX = .010
X.X° = 1°
4
SCREW_HILO-NO4X500
#4 HiLo x .500" SCREW
#4 HiLo x 1/2"
ZINK PLATED
2
3
312208_PCB
312208 PCB - REFERENCE
.062" THICK
CUSTOMER SUPPLIED
1
2
312208_MALE
312208 MALE - STANDARD
ABS
BLACK-WHITE
1
1
312208_FEMALE
312208 FEMALE - STANDARD
ABS
BLACK-WHITE
1
DESCRIPTION
MATERIAL
COLOR
QTY.
ITEM
FILE
NAME
BILL OF MATERIALS
NOTICE: THE INFORMATION AND DATA
CONTAINED HEREIN IS CONSIDERED
PROPRIETARY TO ALLTEC INTEGRATED
MFG INC & SHALL REMAIN THE EXCLUSIVE
PROPERTY OF ALLTEC INTEGRATED MFG INC
THE HOLDER WILL ASSUME CUSTODY AND
CONTROL THAT THIS DOCUMENT WILL
NOT BE COPIED, REPRODUCED, OR
DISCLOSED WITHOUT THE EXPRESS WRITTEN
CONSENT OF ALLTEC INTEGRATED MFG INC
POSSESSION OF THIS DOCUMENT DOES
NOT CONSTITUTE A GRANT TO
MANUFACTURE ANY ITEMS.
© 2014
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
STANDARD - PROJECT BOX
SXX-312208 ASSEMBLY
SIZE
03-Oct-09
San Luis Obispo, CA. 93401
fax (805) 595-1024
www.newageenclosures.com
312208
DRAWING NAME
A 312208_R2_1
SHEET
1 OF 6
REV.DOC
2.1
312208 ASSEMBLY
3.0°
.100
15.0°
.027
1.129
.875
.840
.000
2.257
1.129
.175
.875
.065
20.0°
D
1.546
R
R
3.092
SECTION D-D
.000
1.546
D
SCALE 1.000
2.0°
.538 CLEAR
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
SECTION R-R
.100 CLEAR
ENG.
SCALE
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-312208 ASSEMBLY
SIZE
03-Oct-09
fax (805) 595-1024
312208
DRAWING NAME
A 312208_R2_1
SHEET
2 OF 6
REV.DOC
2.1
312208 FEMALE
.420
.027
T
1.040
.945
.875
.000
.875
2.257
.945
1.040
.100
.077
1.125
.780
.312
.250
3.092
.000
.125
R.090
P
1.125
P
1.453
SECTION T-T
SCALE 1.000
T
.040
.078 x4
.070
.330
SECTION P-P
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
.250
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-312208 ASSEMBLY
SIZE
03-Oct-09
fax (805) 595-1024
312208
DRAWING NAME
A 312208_R2_1
SHEET
3 OF 6
REV.DOC
2.1
312208 MALE
.188
1.040
.875
.000
2.257
.875
.420
1.040
.658
.040
1.065
.780
Y
Y
.092
.000
3.092
+.001
-.001
.183 2x
.202
1.065
1.453
SCALE 1.000
.040 4x
.078 x4 NO DRAFT
.070
20.0°
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
SECTION Y-Y
(.533)
APPROVAL
.070
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-312208 ASSEMBLY
SIZE
03-Oct-09
fax (805) 595-1024
312208
DRAWING NAME
A 312208_R2_1
SHEET
4 OF 6
REV.DOC
2.1
312208 PCB
SIZES AND VERIFICATION OF ITS FIT ARE THE
SOLE RESPONSIBILITY OF THE OEM.
.940
.875
.000
.875
.940
1.880
.062
1.450
(.125)
.000
2.900
R.063
SCALE 1.000
1.450
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-312208 ASSEMBLY
SIZE
03-Oct-09
fax (805) 595-1024
312208
DRAWING NAME
A 312208_R2_1
SHEET
5 OF 6
REV.DOC
2.1
2nd OPERATION DETAILS
NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE
CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT.
ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES
CALL (805) 595-1310 FOR PRICING AND SCHEDULE.
THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031"
312208 MALE
SCALE 1.000
312208 FEMALE
SCALE 1.000
SXX-312208-XXX MALE
STEP NO
1
2
DESCRIPTION
CUTTER
T2 = .062" EM
T2 = .062" EM
SXX-312208-XXX FEMALE
STEP NO
4
5
DESCRIPTION
CUTTER
T2 = .062" EM
T2 = .062" EM
SXX-312208-XXX MALE
STEP
TYPE
FIXTURE
1
PAD PRINT
189
INK COLOR
ABS, BLACK
FIXTURE
189
189
ABS, BLACK
FIXTURE
189
189
ORIENTATION
ORIENTATION
ABS, BLACK
CLICHE DESCRIPTION
PROGRAM
PROGRAM
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
CLICHE No.
CL1010 R1
SCALE
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-312208 ASSEMBLY
SIZE
03-Oct-09
fax (805) 595-1024
312208
DRAWING NAME
A 312208_R2_1
SHEET
6 OF 6
REV.DOC
2.1
很抱歉,暂时无法提供与“S3A-312208”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+78.999551+10.22161
- 5+67.521135+8.73644
- 10+63.1089010+8.16555
- 25+57.7166525+7.46785
- 50+53.9455950+6.97992
- 100+50.42232100+6.52405
- 250+46.11405250+5.96661
- 500+44.36139500+5.73984
