From Off-The-Shelf to Market-Ready© New Age Enclosures is your Single Source Solution.
Let us quote modifying our Stock Enclosures to meet your end-use.
visit newageenclosures.com/services or call 855-4NA-ENCL today.
NOTES: UNLESS OTHERWISE SPECIFIED
R E V I S I O N
REV.
DRAWN BY
ECO No
1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM.
1
M BOYER
2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH.
EQUIVELANT TO MT-11010.
2
M BOYER
0208
3. INTERIOR SURFACE TEXTURE TO BE: NONE.
3
M BOYER
2809
3.1
M BOYER
0710
4.0
R CRUZ
01419
4. ALL INSIDE RADII .010R. ALL OUTSIDE RADII .020R MAX,
UNLESS OTHERWISE SPECIFIED.
5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE
LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED
BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS
DESCRIPTION
DATE
APPROVED
PRELIMINARY RELEASE
11-Nov-2004
D.C.
UPDATE FORMAT AND RELEASE
17-Apr-2008
D.C.
UPDATE FORMAT
26-May-2009
D.C.
FORMAT
26-Mar-2010
D.C.
UPDATE TO AS-BUILT
2019-May-15
6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS
OTHERWISED SPECIFIED.
3
8. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE.
CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE.
9. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION
OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH OWNER.
10. STANDARD OR CUSTOM LABEL RECESSES ARE AVAILABLE FOR QUOTE.
4
11. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. MOUNTING SCREWS
FOR THE PCB ARE SOLD SEPERATELY.
TWO ALTERNATE MOUNTING
OPTIONS AVAILABLE
(TOP OR BOTTOM)
1
2
5
EXPLODED VIEW
SCALE 1.000
SCALE 1.000
5
NO4_HI-LO
ASSEMBLY SCREW
No4 HiLo x 3/8"
ZINC PLATED
4
4
NO4X250
PCB SCREW
No4 HiLo x 1/4"
ZINC PLATED
4
3
352510_COVER
S352510 COVER - STANDARD
ABS
BLACK or WHITE
1
2
352510_BASE
S352510 BASE - STANDARD
ABS
BLACK or WHITE
1
1
352510_PCB
352510 PCB - REFERENCE
CUSTOMER SUPPLIED
.062" THICK
2
DESCRIPTION
MATERIAL
COLOR
QTY.
ITEM
FILE
NAME
BILL OF MATERIALS
THIRD ANGLE PROJECTION
TOLERANCES: UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN U.S. INCHES.
DO NOT SCALE DRAWING
NEW AGE ENCLOSURES
X.XX = .015 X.XXXX = .001
X.XXX = .010
X.X° = 1°
NOTICE: THE INFORMATION AND DATA
CONTAINED HEREIN IS CONSIDERED
PROPRIETARY TO ALLTEC INTEGRATED
MFG INC & SHALL REMAIN THE EXCLUSIVE
PROPERTY OF ALLTEC INTEGRATED MFG INC
THE HOLDER WILL ASSUME CUSTODY AND
CONTROL THAT THIS DOCUMENT WILL
NOT BE COPIED, REPRODUCED, OR
DISCLOSED WITHOUT THE EXPRESS WRITTEN
CONSENT OF ALLTEC INTEGRATED MFG INC
POSSESSION OF THIS DOCUMENT DOES
NOT CONSTITUTE A GRANT TO
MANUFACTURE ANY ITEMS.
© 2019
Customer's Part No:
APPROVAL
BY
352510
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
2240 South Thornburg Street
ph. (805) 595-1310
MED UTILITY - STANDARD
SXX-352510-XXX
SIZE
2004-Nov-11
Santa Maria, CA. 93455
fax (805) 595-1024
www.newageenclosures.com
A
DRAWING NAME
352510_R4_0
SHEET
1 OF 5
REV.DOC
4.0
1.000
.250
2.491
.180
1.625
X
P
P
2.625
2.727
3.493
1.870
SECTION X-X
.090 TYP.
X
.020
1.764
1.750
SCALE 1.000
X.XXX = .010
X.X° = 1°
1.063
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
352510
DATE
CHECK
ENG.
SECTION P-P
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXX-352510-XXX
SIZE
2004-Nov-11
fax (805) 595-1024
A
DRAWING NAME
352510_R4_0
SHEET
2 OF 5
REV.DOC
4.0
2.190
1.690
POSTS
R.220
POSTS
SCALE 1.000
.250
.180
SECTION POSTS-POSTS
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
352510
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXX-352510-XXX
SIZE
2004-Nov-11
fax (805) 595-1024
A
DRAWING NAME
352510_R4_0
SHEET
3 OF 5
REV.DOC
4.0
1.600
.935 2x
1.120
.000
1.120
.935 2x
1.600
(3.200)
1.100
.875 2x
.620
RECOMMENDED PCB
OUTLINE
.000
(2.200)
.620
.875 2x
1.100
R.193
.125 4x
(.063)
SCALE 1.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
NOTE:
SIZES AND VERIFICATION OF ITS FIT ARE THE
APPROVAL
BY
352510
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXX-352510-XXX
SIZE
2004-Nov-11
fax (805) 595-1024
A
DRAWING NAME
352510_R4_0
SHEET
4 OF 5
REV.DOC
4.0
2nd OPERATION DETAILS
NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE
CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT.
ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES
CALL (805) 595-1310 FOR PRICING AND SCHEDULE.
THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031"
352510 COVER
SCALE 1.000
352510 BASE
SCALE 1.000
X.XXX = .010
X.X° = 1°
SXX-352510-XXX COVER
NEW AGE ENCLOSURES
ABS, BLACK
Customer's Part No:
STEP NO
DESCRIPTION
CUTTER
FIXTURE
ORIENTATION
PROGRAM
1-C-C1
2-C-C2
3-C-C2
T2 = .062" EM
T2 = .062" EM
T2 = .062" EM
269
269
269
APPROVAL
BY
352510
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXX-352510-XXX
SIZE
2004-Nov-11
fax (805) 595-1024
A
DRAWING NAME
352510_R4_0
SHEET
5 OF 5
REV.DOC
4.0
很抱歉,暂时无法提供与“S3A-352510”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+67.531281+8.73621
