S1A-352510
S1A-352510
    NEWAGE
    MEDIUM UTILITY
S1A-352510 数据手册
From Off-The-Shelf to Market-Ready© New Age Enclosures is your Single Source Solution. Let us quote modifying our Stock Enclosures to meet your end-use. visit newageenclosures.com/services or call 855-4NA-ENCL today. NOTES: UNLESS OTHERWISE SPECIFIED R E V I S I O N REV. DRAWN BY ECO No 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 1 M BOYER 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVELANT TO MT-11010. 2 M BOYER 0208 3. INTERIOR SURFACE TEXTURE TO BE: NONE. 3 M BOYER 2809 3.1 M BOYER 0710 4.0 R CRUZ 01419 4. ALL INSIDE RADII .010R. ALL OUTSIDE RADII .020R MAX, UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. DESCRIPTION DATE APPROVED PRELIMINARY RELEASE 11-Nov-2004 D.C. UPDATE FORMAT AND RELEASE 17-Apr-2008 D.C. UPDATE FORMAT 26-May-2009 D.C. FORMAT 26-Mar-2010 D.C. UPDATE TO AS-BUILT 2019-May-15 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 3 8. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 9. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH OWNER. 10. STANDARD OR CUSTOM LABEL RECESSES ARE AVAILABLE FOR QUOTE. 4 11. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. MOUNTING SCREWS FOR THE PCB ARE SOLD SEPERATELY. TWO ALTERNATE MOUNTING OPTIONS AVAILABLE (TOP OR BOTTOM) 1 2 5 EXPLODED VIEW SCALE 1.000 SCALE 1.000 5 NO4_HI-LO ASSEMBLY SCREW No4 HiLo x 3/8" ZINC PLATED 4 4 NO4X250 PCB SCREW No4 HiLo x 1/4" ZINC PLATED 4 3 352510_COVER S352510 COVER - STANDARD ABS BLACK or WHITE 1 2 352510_BASE S352510 BASE - STANDARD ABS BLACK or WHITE 1 1 352510_PCB 352510 PCB - REFERENCE CUSTOMER SUPPLIED .062" THICK 2 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2019 Customer's Part No: APPROVAL BY 352510 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 MED UTILITY - STANDARD SXX-352510-XXX SIZE 2004-Nov-11 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 352510_R4_0 SHEET 1 OF 5 REV.DOC 4.0 1.000 .250 2.491 .180 1.625 X P P 2.625 2.727 3.493 1.870 SECTION X-X .090 TYP. X .020 1.764 1.750 SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° 1.063 NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 352510 DATE CHECK ENG. SECTION P-P SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 MED UTILITY - STANDARD SXX-352510-XXX SIZE 2004-Nov-11 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 352510_R4_0 SHEET 2 OF 5 REV.DOC 4.0 2.190 1.690 POSTS R.220 POSTS SCALE 1.000 .250 .180 SECTION POSTS-POSTS TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 352510 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 MED UTILITY - STANDARD SXX-352510-XXX SIZE 2004-Nov-11 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 352510_R4_0 SHEET 3 OF 5 REV.DOC 4.0 1.600 .935 2x 1.120 .000 1.120 .935 2x 1.600 (3.200) 1.100 .875 2x .620 RECOMMENDED PCB OUTLINE .000 (2.200) .620 .875 2x 1.100 R.193 .125 4x (.063) SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: NOTE: PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH OWNER. APPROVAL BY 352510 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 MED UTILITY - STANDARD SXX-352510-XXX SIZE 2004-Nov-11 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 352510_R4_0 SHEET 4 OF 5 REV.DOC 4.0 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" 352510 COVER SCALE 1.000 352510 BASE SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° SXX-352510-XXX COVER - NEW AGE ENCLOSURES ABS, BLACK Customer's Part No: STEP NO DESCRIPTION CUTTER FIXTURE ORIENTATION PROGRAM 1-C-C1 2-C-C2 3-C-C2 - T2 = .062" EM T2 = .062" EM T2 = .062" EM 269 269 269 - - APPROVAL BY 352510 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 MED UTILITY - STANDARD SXX-352510-XXX SIZE 2004-Nov-11 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 352510_R4_0 SHEET 5 OF 5 REV.DOC 4.0
S1A-352510 价格&库存
很抱歉,暂时无法提供与“S1A-352510”相匹配的价格&库存,您可以联系我们找货
