S6L-353113
S6L-353113
    NEWAGE
    2 AA OUTDOOR NODE
S6L-353113 数据手册
From Off-The-Shelf to Market-Ready© New Age Enclosures is your Single Source Solution. Let us quote modifying our Stock Enclosures to meet your end-use. visit newageenclosures.com/services or call 855-4NA-ENCL today. NOTES: UNLESS OTHERWISE SPECIFIED 1. CORNERS DRAWN SHARP TO BE R.010 MAXIMUM. E I S I O N DATE APPROVE A M BOYER PRELIMINARY RELEASE 2018-Apr-16 D.C. B R CRUZ UPDATE NOTE 6 AND ORING, CHANGE PART DESCRIPTION 2018-Aug-02 D.C. 1.0 R CRUZ UPDATE TO AS-BUILT 2019-Dec-03 3. ALL INSIDE RADII .020R. UNLESS OTHERWISE SPECIFIED. 03319 DESCRIPTION V DRAWN BY 2. EXTERIOR SURFACE TEXTURE TO BE MT-11020, UNLESS SPECIFIED OTHERWISE ECO No R REV. 4. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 5. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 6. MATERIAL / COLOR: ENCLOSURE IN ASA PLASTIC IS STANDARD IN BLACK OR GREY. SLIGHT COSMETIC SWIRLING, BLUSHING, AND/OR DISCOLORATION CAN OCCUR IN THIS ENCLOSURE DUE TO UV INHIBITORS IN THE RESIN. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 1 9 7. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH CUSTOMER. 8. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. FOR THE PCB ARE CUSTOMER SUPPLIED. MOUNTING SCREWS 9. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 10. ALLOWABLE FLASH: 0.010 MAX. 7 11. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH, PROTRUDING OR BELOW FLUSH. 12. TRIM GATE WITHIN 0.030" OF FLUSH. 13. THIS ENCLOSURE IS CONSTRUCTED FOR INDOOR OR OUTDOOR USE TO PROVIDE A DEGREE OF PROTECTION TO THE EQUIPMENT INSIDE AGAINST THE INGRESS OF SOLID FORIEGN OBJECTS (FALLING DIRT); AND TO PROVIDE A DEGREE OF PROTECTION WITH RESPECT TO TO HARMFUL EFFECTS ON THE EQUIPMENT DUE TO THE INGRESS OF WATER (DRIPPING OR SPLASHING). 3 TEXTURE: MT-11020 6 8 2 5 4 TEXTURE: B2 POLISH SCALE 0.400 SCALE 0.750 9 6-32_PHILLIPS_SCREW 6-32 PHILLIPS SCREW x .375" 18-8 STAINLESS S-MS 6-32.375 4 8 6-32X344_BRASS-INSERT 6-32 BRASS INSERT x .344" TRISTAR 632x344MB OVER-MOLDED 4 7 353113_ORING OR-146 SHORE A INCLUDED 1 6 SCREW_HILO-NO4 #4 HiLo SCREW x .250" ZINC PLATED CUSTOMER SUPPLIED 4 5 SCREW-DRYWALLX750 DRYWALL SCREW REFERENCE ONLY CUSTOMER SUPPLIED 4 4 353113_STRAP MOUNTING STRAP x 1.000" WIDE REFERENCE ONLY CUSTOMER SUPPLIED 1 3 353113_PCB_LOWER 353113 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 2 353113_WALL-BASE 353113 WALL BASE - STANDARD ASA BLACK or GREY 1 1 353113_COVER 353113 COVER - STANDARD ASA BLACK or GREY 1 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2018 Customer's Part No: APPROVAL BY 353113 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - 2AA NODE SXL-353113-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2018-Apr-16 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 353113_R1_0 SHEET 1 OF 7 REV.DOC 1.0 353113 ASSEMBLY (3.104) (1.300) 1.058 .285 CLEAR Y S S (3.504) LABEL RECESS x2 0.012" SECTION Y-Y Y SCALE 0.500 .228 .289 SECTION S-S SEE DETAIL A DETAIL A SCALE 2.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 353113 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - 2AA NODE SXL-353113-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2018-Apr-16 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 353113_R1_0 SHEET 2 OF 7 REV.DOC 1.0 353113 COVER 2.775 2.025 .085 TYP. .850 1.215 2.275 .070 Y E 2.615 3.425 1.875 E .175 R.072 R.250 R.477 SECTION Y-Y SCALE 0.750 Y 5.0° .020 SEE DETAIL E SECTION E-E DETAIL E SCALE 2.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 353113 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - 2AA NODE SXL-353113-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2018-Apr-16 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 353113_R1_0 SHEET 3 OF 7 REV.DOC 1.0 353113 WALL BASE 3.104 2.374 Y R.220 1.520 RECESS 1.051 .175 .920 RECESS .285 3.504 2.751 .105 2.774 1.058 E .185 E SCALE 0.750 Y OVER-MOLDED BRASS INSERT SEE B.O.M. ON SHEET 1 .187 .060 .335 5.0° SECTION Y-Y SEE DETAIL B .106 -2° DRAFT .140 SECTION E-E DETAIL B SCALE 3.000 5.0° TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL .430 BY 353113 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - 2AA NODE SXL-353113-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2018-Apr-16 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 353113_R1_0 SHEET 4 OF 7 REV.DOC 1.0 353113 O-RING (1.627) .000 (1.627) OR-146 DUROMETER 70A (MEDIUM) OR EQUIVALENT 2.818 OD 2.612 ID (.927) .000 (.927) R.391 .103 SCALE 1.000 OFF THE SHELF EQUIVALENT SCALE 1.000 SECTION Y-Y SEE DETAIL C ( .103) TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES DETAIL C SCALE 10.000 Customer's Part No: APPROVAL BY 353113 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - 2AA NODE SXL-353113-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2018-Apr-16 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 353113_R1_0 SHEET 5 OF 7 REV.DOC 1.0 353113 PCB - CUSTOMER SUPPLIED 2X 1.375 1.532 .000 1.532 2X 1.375 PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. .832 2X .525 4X .120 .000 2X .525 .832 CHAMFER .300 SCALE 1.000 .062 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 353113 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - 2AA NODE SXL-353113-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2018-Apr-16 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 353113_R1_0 SHEET 6 OF 7 REV.DOC 1.0 353113 - 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" 35113 COVER SCALE 1.000 SXL-353113-XXX COVER - ASA, BLACK STEP NO DESCRIPTION CUTTER FIXTURE ORIENTATION PROGRAM 1-C-C1 2-C-C2 3-C-C3 - T2 = .062" EM T2 = .062" EM T2 = .062" EM 391 391 391 - - SXL-353113-XXX COVER - TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 353113 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - 2AA NODE SXL-353113-XXX DATE CHECK ASA, BLACK ENG. STEP TYPE FIXTURE INK COLOR CLICHE DESCRIPTION CLICHE No. 4-C-P1 PAD PRINT 390 WHITE LOGO AND LABELS CLXXXXn R1 SCALE AS NOTED DRAWN BY M BOYER SIZE 2018-Apr-16 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 353113_R1_0 SHEET 7 OF 7 REV.DOC 1.0
S6L-353113 价格&库存
很抱歉,暂时无法提供与“S6L-353113”相匹配的价格&库存,您可以联系我们找货
