NOTES:
UNLESS OTHERWISE SPECIFIED
REV.
DRAWN BY
ECO No
A
R CRUZ
DR XXX
2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH.
EQUIVELANT TO MT-11020. APPEARANCE AND DEPTH OF
TEXTURE CAN VARY OVER TIME DUE TO MOLD WEAR.
B
3. INTERIOR SURFACE TEXTURE TO BE: NONE.
1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM.
4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED.
R E V I S I O N
DESCRIPTION
DATE
APPROVE
PRELIMINARY RELEASE
2015-May-18
D.C.
R CRUZ
UPDATE NOTE 2, PART NAME, PCB SHAPE
2015-Jun-23
D.C.
C
M BOYER
REVISE SIZE AND DRAWING FORMAT
2015-Oct-27
D.C.
D
R CRUZ
ADD RIBS TO BASE, INCREASE ASSY POST ID & OD
2015-Dec-15
D.C.
E
M BOYER
REVISE TEXTURE NOTE
2016-Feb-22
D.C.
1.0
R CRUZ
UPDATE FORMAT, UPDATE NOTE 2, RELEASE TO MFG PER CUSTOMER
2017-Apr-19
D.C.
5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE
LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED
BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS
6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS
OTHERWISED SPECIFIED.
7. MATERIAL / COLOR:
ABS PLASTIC IS STANDARD IN BLACK OR WHITE.
CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE.
8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION
OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF EACH OWNER.
3
9. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED.
10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED
BY THE SOLID MODEL FILE.
11. ALLOWABLE FLASH: 0.010 MAX.
12. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH,
PROTRUDING OR BELOW FLUSH.
13. TRIM GATE WITHIN 0.030" OF FLUSH.
4
2
SCALE 1.000
1
SCALE 0.500
THIRD ANGLE PROJECTION
TOLERANCES: UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN U.S. INCHES.
DO NOT SCALE DRAWING
NEW AGE ENCLOSURES
X.XX = .015 X.XXXX = .001
X.XXX = .010
X.X° = 1°
4
353515_PCB
353515 PCB - REFERENCE
.062" THICK
CUSTOMER SUPPLIED
1
3
353515_COVER
353515 COVER - STANDARD
ABS
BLACK or WHITE
1
2
353515_BASE
353515 BASE - STANDARD
ABS
BLACK or WHITE
1
1
SCREW_HILO-NO4X375
#4 HiLo x .375" SCREW
ZINK PLATED
3/8" LONG
4
DESCRIPTION
MATERIAL
COLOR
QTY.
ITEM
FILE
NAME
BILL OF MATERIALS
NOTICE: THE INFORMATION AND DATA
CONTAINED HEREIN IS CONSIDERED
PROPRIETARY TO ALLTEC INTEGRATED
MFG INC & SHALL REMAIN THE EXCLUSIVE
PROPERTY OF ALLTEC INTEGRATED MFG INC
THE HOLDER WILL ASSUME CUSTODY AND
CONTROL THAT THIS DOCUMENT WILL
NOT BE COPIED, REPRODUCED, OR
DISCLOSED WITHOUT THE EXPRESS WRITTEN
CONSENT OF ALLTEC INTEGRATED MFG INC
POSSESSION OF THIS DOCUMENT DOES
NOT CONSTITUTE A GRANT TO
MANUFACTURE ANY ITEMS.
© 2017
Customer's Part No:
APPROVAL
BY
353515
2240 South Thornburg Street
ph. (805) 595-1310
STANDARD - MEDIUM HUB
SXX-353515-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
R CRUZ
SIZE
2015-May-18
Santa Maria, CA. 93455
fax (805) 595-1024
www.newageenclosures.com
A
DRAWING NAME
353515_R1_0
SHEET
1 OF 6
REV.DOC
1.0
3.500
353515 ASSEMBLY
3.500
R7.000
.062
R.800
SCALE 0.667
1.550
DETAIL A
SCALE 2.000
1.000
1.061
R.175
.471
2.300
2.300
SECTION A-A
.328
SEE DETAIL A
(.062)
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
353515
ph. (805) 595-1310
SXX-353515-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
R CRUZ
SIZE
2015-May-18
fax (805) 595-1024
A
DRAWING NAME
353515_R1_0
SHEET
2 OF 6
REV.DOC
1.0
3.500
.015
.080
353515 COVER
C
.050
R7.000
3.500
.058
.044
SCALE 0.667
DETAIL B
SCALE 2.000
R.800
C
SEE DETAIL B
1.061
3.0° DRAFT
2.300
2.300
.0580
.218 OD
SECTION C-C
3.419 -5° DRAFT/SIDE
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
.089 ID
APPROVAL
BY
353515
ph. (805) 595-1310
SXX-353515-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
R CRUZ
SIZE
2015-May-18
fax (805) 595-1024
A
DRAWING NAME
353515_R1_0
SHEET
3 OF 6
REV.DOC
1.0
3.500
353515 BASE
B
.023
.0400
.312 +5° DRAFT/SIDE
3.500
R7.000
R.800
SCALE 0.667
B
.328
.020
.230 +5° DRAFT/SIDE
DETAIL C
SCALE 2.000
.125 +2° DRAFT/SIDE
.471
3.0°
R.175
SECTION B-B
2.300
.080
SEE DETAIL C
2.300
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
353515
ph. (805) 595-1310
SXX-353515-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
R CRUZ
SIZE
2015-May-18
fax (805) 595-1024
A
DRAWING NAME
353515_R1_0
SHEET
4 OF 6
REV.DOC
1.0
353515 PCB - CUSTOMER SUPPLIED
1.579
1.150
.000
1.150
1.579
PCB SIZES/SHAPE ARE RECOMMENDATIONS ONLY. ALTERNATE
PCB DESIGNS ARE COMPATIBLE BUT MUST FIT INSIDE ENVELOPE
DIMENSIONS AND MAINTAIN MOUNTING HOLE LOCATION AND SIZE.
FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE
RESPONSIBILITY OF THE CUSTOMER.
1.579
1.150
(2.300) S.Q.
.000
1.150
1.579
45.0° x .586 (4PL)
SCALE 1.000
.125 4x
.325 KEEP OUT ZONE 4x
.062
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
353515
ph. (805) 595-1310
SXX-353515-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
R CRUZ
SIZE
2015-May-18
fax (805) 595-1024
A
DRAWING NAME
353515_R1_0
SHEET
5 OF 6
REV.DOC
1.0
2nd OPERATION DETAILS
NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE
CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT.
ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES
CALL (805) 595-1310 FOR PRICING AND SCHEDULE.
THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031"
353515 COVER
SCALE 1.000
353515 BASE
SCALE 1.000
Sxx-353515-xxx
COVER
STEP NO
DESCRIPTION
CUTTER
1-C-C1
2-C-C2
T2 = .062" EM
T2 = .062" EM
STEP NO
DESCRIPTION
3-C-P1
PAD PRINT
Sxx-353515-xxx
INK COLOR
BLACK
FIXTURE
ORIENTATION
PROGRAM
o1000
o1000
COVER
ABS, BLACK
ABS, BLACK
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
353515
ph. (805) 595-1310
SXX-353515-XXX
DATE
CHECK
ENG.
CLICHE DESCRIPTION
CLICHE No.
CLXXXX R1
SCALE
AS NOTED
DRAWN BY
R CRUZ
SIZE
2015-May-18
fax (805) 595-1024
A
DRAWING NAME
353515_R1_0
SHEET
6 OF 6
REV.DOC
1.0
很抱歉,暂时无法提供与“S3A-353515”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+85.756531+11.09392
- 5+73.291205+9.48134
- 10+68.5059510+8.86229
- 25+62.6554225+8.10544
- 50+58.5635850+7.57610
- 100+54.73784100+7.08118
- 250+50.06072250+6.47612
- 500+48.65755500+6.29460
