S1A-353515
S1A-353515
    NEWAGE
    MEDIUM HUB
S1A-353515 数据手册
NOTES: UNLESS OTHERWISE SPECIFIED REV. DRAWN BY ECO No A R CRUZ DR XXX 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVELANT TO MT-11020. APPEARANCE AND DEPTH OF TEXTURE CAN VARY OVER TIME DUE TO MOLD WEAR. B 3. INTERIOR SURFACE TEXTURE TO BE: NONE. 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. R E V I S I O N DESCRIPTION DATE APPROVE PRELIMINARY RELEASE 2015-May-18 D.C. R CRUZ UPDATE NOTE 2, PART NAME, PCB SHAPE 2015-Jun-23 D.C. C M BOYER REVISE SIZE AND DRAWING FORMAT 2015-Oct-27 D.C. D R CRUZ ADD RIBS TO BASE, INCREASE ASSY POST ID & OD 2015-Dec-15 D.C. E M BOYER REVISE TEXTURE NOTE 2016-Feb-22 D.C. 1.0 R CRUZ UPDATE FORMAT, UPDATE NOTE 2, RELEASE TO MFG PER CUSTOMER 2017-Apr-19 D.C. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF EACH OWNER. 3 9. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. 10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 11. ALLOWABLE FLASH: 0.010 MAX. 12. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH, PROTRUDING OR BELOW FLUSH. 13. TRIM GATE WITHIN 0.030" OF FLUSH. 4 2 SCALE 1.000 1 SCALE 0.500 THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° 4 353515_PCB 353515 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 3 353515_COVER 353515 COVER - STANDARD ABS BLACK or WHITE 1 2 353515_BASE 353515 BASE - STANDARD ABS BLACK or WHITE 1 1 SCREW_HILO-NO4X375 #4 HiLo x .375" SCREW ZINK PLATED 3/8" LONG 4 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2017 Customer's Part No: APPROVAL BY 353515 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - MEDIUM HUB SXX-353515-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY R CRUZ SIZE 2015-May-18 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 353515_R1_0 SHEET 1 OF 6 REV.DOC 1.0 3.500 353515 ASSEMBLY 3.500 R7.000 .062 R.800 SCALE 0.667 1.550 DETAIL A SCALE 2.000 1.000 1.061 R.175 .471 2.300 2.300 SECTION A-A .328 SEE DETAIL A (.062) TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 353515 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - MEDIUM HUB SXX-353515-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY R CRUZ SIZE 2015-May-18 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 353515_R1_0 SHEET 2 OF 6 REV.DOC 1.0 3.500 .015 .080 353515 COVER C .050 R7.000 3.500 .058 .044 SCALE 0.667 DETAIL B SCALE 2.000 R.800 C SEE DETAIL B 1.061 3.0° DRAFT 2.300 2.300 .0580 .218 OD SECTION C-C 3.419 -5° DRAFT/SIDE TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: .089 ID APPROVAL BY 353515 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - MEDIUM HUB SXX-353515-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY R CRUZ SIZE 2015-May-18 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 353515_R1_0 SHEET 3 OF 6 REV.DOC 1.0 3.500 353515 BASE B .023 .0400 .312 +5° DRAFT/SIDE 3.500 R7.000 R.800 SCALE 0.667 B .328 .020 .230 +5° DRAFT/SIDE DETAIL C SCALE 2.000 .125 +2° DRAFT/SIDE .471 3.0° R.175 SECTION B-B 2.300 .080 SEE DETAIL C 2.300 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 353515 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - MEDIUM HUB SXX-353515-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY R CRUZ SIZE 2015-May-18 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 353515_R1_0 SHEET 4 OF 6 REV.DOC 1.0 353515 PCB - CUSTOMER SUPPLIED 1.579 1.150 .000 1.150 1.579 PCB SIZES/SHAPE ARE RECOMMENDATIONS ONLY. ALTERNATE PCB DESIGNS ARE COMPATIBLE BUT MUST FIT INSIDE ENVELOPE DIMENSIONS AND MAINTAIN MOUNTING HOLE LOCATION AND SIZE. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF THE CUSTOMER. 1.579 1.150 (2.300) S.Q. .000 1.150 1.579 45.0° x .586 (4PL) SCALE 1.000 .125 4x .325 KEEP OUT ZONE 4x .062 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 353515 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - MEDIUM HUB SXX-353515-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY R CRUZ SIZE 2015-May-18 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 353515_R1_0 SHEET 5 OF 6 REV.DOC 1.0 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" 353515 COVER SCALE 1.000 353515 BASE SCALE 1.000 Sxx-353515-xxx COVER STEP NO DESCRIPTION CUTTER 1-C-C1 2-C-C2 - T2 = .062" EM T2 = .062" EM STEP NO DESCRIPTION 3-C-P1 PAD PRINT Sxx-353515-xxx INK COLOR BLACK - FIXTURE ORIENTATION PROGRAM - o1000 o1000 - COVER - TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. ABS, BLACK ABS, BLACK X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 353515 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - MEDIUM HUB SXX-353515-XXX DATE CHECK ENG. CLICHE DESCRIPTION CLICHE No. - CLXXXX R1 SCALE AS NOTED DRAWN BY R CRUZ SIZE 2015-May-18 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 353515_R1_0 SHEET 6 OF 6 REV.DOC 1.0
S1A-353515 价格&库存
很抱歉,暂时无法提供与“S1A-353515”相匹配的价格&库存,您可以联系我们找货
