S1A-361413-K
S1A-361413-K
    NEWAGE
    COMPACT AA - KIT
S1A-361413-K 数据手册
R E V I S I O N NOTES: UNLESS OTHERWISE SPECIFIED 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. REV. DRAWN BY DATE APPR. A M BOYER PRELIMINARY RELEASE 2014-May-02 D.C. B M BOYER REDUCE HEIGHT OF HATCH LIP 2014-May-16 D.C. C M BOYER INCREASE HEIGHT OF COVER .102 2014-Oct-07 D.C. D M BOYER ADD .039" BOARD OPTION 2014-Oct-21 D.C. E M BOYER CLOSE UP BEAUTY RING AND ADD DRAWING DETAILS 2014-Dec-01 D.C. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH, EQUIVELANT TO MT-11010. APPEARANCE AND DEPTH OF TEXTURE VARIES OVER TIME DUE TO WEAR. 3. INTERIOR SURFACE TEXTURE TO BE: AS MOLDED. 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. ECO No DESCRIPTION 1.0 R CRUZ 0469 UPDATE TO AS-BUILT AND RELEASE 2015-Sep-03 D.C. 2.0 M BOYER 02016 INCLUDE WALL CRADLE 2016-Mar-21 D.C. 3.0 R CRUZ 05416 UPDATE NOTES 2 AND 3 2016-Dec-20 D.C. 4.0 M BOYER 01417 INCREASE LEAD-IN ON HATCH LATCH 2017-May-11 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 2 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH OWNER. 9. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. 5 10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 11. ALLOWABLE FLASH: 0.005 MAX. SHOWN WITH BOTH PCB CHOOSE ONE 12. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH, PROTRUDING OR BELOW FLUSH. 6 13. TRIM GATE WITHIN 0.015" OF FLUSH. 1 9 10 361413(x) CONFIGURATIONS -[BLANK] 361413 COVER 1 361413 BASE 1 361413 BASE w/ WALL NOTCHES 361413 BATTERY HATCH 1 361413 WALL CRADLE #4 HiLo SCREW .375" 4 -K 1 1 1 1 4 11 -W 7 3 1 12 AA-SINGL-CONTACT-POS ACC-AAPOS-5223 SPRING STEEL SOLD SEPARATELY 1 11 AA-SINGL-CONTACT-NEG ACC-AANEG-5201 SPRING STEEL SOLD SEPARATELY 1 10 AA-DBL-CONTACT ACC-AADBL-5212 SPRING STEEL SOLD SEPARATELY 1 9 SCREW_HILO-NO4X375 #4 HiLo x .375" SCREW ZINK PLATED INCLUDED 4 8 SCREW-DRYWALLX750 DRYWALL SCREW REFERENCE ONLY CUSTOMER SUPPLIED 2 7 BATTERY_AA "AA" SIZE BATTERY REFERENCE CUSTOMER SUPPLIED 2 6 361413-PCB_039 361413 .039" PCB - REFERENCE 1 MM THICK CUSTOMER SUPPLIED 1 5 361413-PCB_062 361413 .062" PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 4 361413-WALL 361413 WALL CRADLE - STANDARD ABS BLACK or WHITE 1 3 361413-HATCH 361413 HATCH - STANDARD ABS BLACK or WHITE 1 2 361413-COVER 361413 COVER - STANDARD ABS BLACK or WHITE 1 1 361413-BASE 361413 BASE - STANDARD ABS BLACK or WHITE 1 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME 12 BILL OF MATERIALS 361413 EXPLODED VIEW SCALE 0.750 THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES 4 8 X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2017 Customer's Part No: APPROVAL BY 361413 2240 South Thornburg Street ph. (805) 595-1310 COMPACT AA - STANDARD SXX-361413X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2014-May-02 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 361413_R4_0 SHEET 1 OF 8 REV.DOC 4.0 361413 ASSEMBLY .350 CLEAR .867 (.020) 1.317 .430 .555 1.440 SECTION D-D D 3.600 R.200 SCALE 1.000 D SECTION P-P TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 361413 2240 South Thornburg Street ph. (805) 595-1310 COMPACT AA - STANDARD SXX-361413X-XXX DATE CHECK ENG. 3.0° R.200 SCALE AS NOTED DRAWN BY M BOYER SIZE 2014-May-02 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 361413_R4_0 SHEET 2 OF 8 REV.DOC 4.0 361413 COVER .035 CHAMFER .070 NOMINAL THICKNESS .070 CHAMFER x 45° BOTH ENDS .880 3.0° L .150 .040 .100 CENTER THICKNESS 3.600 2.760 3.531 W W .050 .082 .035 CHAMFER x 43.5° BOTH ENDS R.200 L .219 SECTION L-L SCALE 1.000 .495 .034 1.371 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. 1.440 X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° .065 DETAIL A SCALE 4.000 SECTION W-W SEE DETAIL A NEW AGE ENCLOSURES Customer's Part No: APPROVAL 5.0° BY 361413 2240 South Thornburg Street ph. (805) 595-1310 COMPACT AA - STANDARD SXX-361413X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2014-May-02 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 361413_R4_0 SHEET 3 OF 8 REV.DOC 4.0 .006 .033 DETAIL E SCALE 3.000 .867 .190 .022 .239 SEE DETAIL D R.200 X SEE DETAIL G P P SEE DETAIL E .065 3.600 SCALE 1.000 .000 .700 .625 DETAIL G SCALE 2.000 .017 361413 BASE 1.440 WALL MOUNTING HOLES NOT PRESENT UNLESS WALL CRADLE IS ORDERED. SECTION X-X .880 2.026 2.760 SECTION P-P X .409 .045 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 361413 2240 South Thornburg Street ph. (805) 595-1310 COMPACT AA - STANDARD SXX-361413X-XXX DATE CHECK ENG. .467 DETAIL D SCALE 2.000 SCALE AS NOTED DRAWN BY M BOYER SIZE 2014-May-02 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 361413_R4_0 SHEET 4 OF 8 REV.DOC 4.0 361413 HATCH .332 .010 SEE DETAIL F .015 DETAIL F SCALE 6.000 SEE DETAIL B X BEAUTY RING .338 .400 .035 Y .050 Y .150 R.050 SCALE 1.000 X .048 SEE DETAIL C SECTION X-X 1.386 .141 .020 .070 5.0° R.200 .370 .100 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° .0670 .090 NEW AGE ENCLOSURES .070 Customer's Part No: APPROVAL BY 361413 2240 South Thornburg Street ph. (805) 595-1310 COMPACT AA - STANDARD SXX-361413X-XXX DATE CHECK DETAIL B SCALE 2.000 SECTION Y-Y .055 DETAIL C SCALE 3.000 ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2014-May-02 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 361413_R4_0 SHEET 5 OF 8 REV.DOC 4.0 361413 PCB - CUSTOMER SUPPLIED PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. .630 .290 2x .440 2x .000 .440 2x .290 2x .630 1.260 .039 .062 1.710 1.380 2x .062 1.091 2x .200 .650 2x .055 3.420 .000 .030 R.125 .650 2x .194 4x .244 4x 1.0910 2x 1.380 2x 1.710 SCALE 1.000 .050 CHAMFER x 45° 4x SCALE 1.000 .320 x 4 PLACES KEEP OUT ZONES .320 x 4 PLACES KEEP OUT ZONES TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES THIS ENCLOSURE CAN ACCOMODATE EITHER PCB THICKNESS Customer's Part No: APPROVAL BY 361413 2240 South Thornburg Street ph. (805) 595-1310 COMPACT AA - STANDARD SXX-361413X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2014-May-02 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 361413_R4_0 SHEET 6 OF 8 REV.DOC 4.0 361413 - 2nd OPERATION DETAILS - 1 of 2 NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" 1.398 X .627 .625 STEP 2 3.851 2.500 361413 BASE W/ WALL NOTCHES SCALE 1.000 .627 STEP 1 .70 (.242) .27 SECTION X-X X .625 .085 361413 WALL CRADLE SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES SXX-361413K-XXX BASE STEP NO DESCRIPTION CUTTER 1-C-C1 2-C-C2 WALL NOTCHES WALL NOTCHES T2 = .062" EM T2 = .062" EM - ABS, BLACK Customer's Part No: APPROVAL FIXTURE ORIENTATION PROGRAM 332 332 SINGLE SINGLE o1401 o1401 BY 361413 2240 South Thornburg Street ph. (805) 595-1310 COMPACT AA - STANDARD SXX-361413X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2014-May-02 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 361413_R4_0 SHEET 7 OF 8 REV.DOC 4.0 361413 - 2nd OPERATION DETAILS - 2 OF 2 NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES SXX-361413-XXX COVER - ABS, BLACK Customer's Part No: APPROVAL STEP NO DESCRIPTION CUTTER FIXTURE ORIENTATION PROGRAM 1-C-C1 2-C-C2 - T2 = .062" EM T2 = .062" EM 349 349 SINGLE - - BY 361413 2240 South Thornburg Street ph. (805) 595-1310 COMPACT AA - STANDARD SXX-361413X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2014-May-02 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 361413_R4_0 SHEET 8 OF 8 REV.DOC 4.0
S1A-361413-K 价格&库存
很抱歉,暂时无法提供与“S1A-361413-K”相匹配的价格&库存,您可以联系我们找货
