S3A-362408
S3A-362408
    NEWAGE
    ROUTER BAR
S3A-362408 数据手册
From Off-The-Shelf to Market-Ready© New Age Enclosures is your Single Source Solution. Let us quote modifiying our Stock Enclosures to meet your end-use. visit newageenclosures.com/services or call 855-4NA-ENCL today. NOTES: UNLESS OTHERWISE SPECIFIED REV. DRAWN BY 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVALENT TO MT-11010. 3. INTERIOR SURFACE TEXTURE TO BE: NONE. 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. R E V I S I O N DESCRIPTION DATE APPROVED PRELIMINARY RELEASE 2016-Oct-04 D.C. R CRUZ UPDATE NOTE 2, ENCLOSURE NAME, & PCB SHAPE 2016-Oct-06 D.C. C R CRUZ ADD RIBS ON BASE, REVISE PCB SHAPE AND ADD NOTE 2016-Dec-07 D.C. 1.0 M BOYER RELEASED TO MFG PER CUSTOMER 2017-Feb-15 A M BOYER B ECO No DR XXX 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. ALTERNATE RESINS HAVE DIFFERENT SHRINK RATES, AND WILL EFFECT DIMENSIONS. 3 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH CUSTOMER. 9. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. 10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 11. ALLOWABLE FLASH: 0.015 MAX. 12. ALL EJECTOR PIN MARKS TO BE WITHIN 0.015" OF FLUSH, PROTRUDING OR BELOW FLUSH. 4 13. TRIM GATE WITHIN 0.030" OF FLUSH. 2 1 362408 EXPLODED VIEW SCALE 1.000 SCALE 0.750 THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° 4 362408_PCB_062 362408 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 3 362408_COVER 362408 COVER - STANDARD ABS BLACK or WHITE 1 2 362408_BASE 362408 BASE - STANDARD ABS BLACK or WHITE 1 1 SCREW_HILO-NO4X375 #4 HiLo x .375" SCREW ZINK PLATED 3/8" LONG 4 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2016 Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - ROUTER BAR SXX-362408-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2016-Oct-04 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 362408 A DRAWING NAME 362408_R1_0 SHEET 1 OF 6 REV.DOC 1.0 3.600 [91,44] 362408 ASSEMBLY A .495 CLEAR [12,57] .020 [0,51] 2.400 [60,96] .062 PCB [1,57] A .073 CLEAR [1,85] DETAIL A SCALE 2.000 R.300 [7,62] SCALE 1.000 3.0° DRAFT TYP. .565 [14,35] .800 [20,32] .215 [5,46] .020 [0,51] 2.269 [57,62] 1.600 [40,64] SECTION A-A R.175 [4,45] SEE DETAIL A 1.745 [44,33] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - ROUTER BAR SXX-362408-XXX DATE CHECK ENG. 2.800 [71,12] SCALE AS NOTED DRAWN BY M BOYER SIZE 2016-Oct-04 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 362408 A DRAWING NAME 362408_R1_0 SHEET 2 OF 6 REV.DOC 1.0 1.800 [45,72] .000 [0] 1.800 [45,72] C 362408 COVER 1.200 [30,48] .060 [1,52] .000 [0] .015 [0,38] .090 [2,29] .060 [1,52] .045 [1,14] DETAIL B SCALE 2.000 1.200 [30,48] SCALE 1.000 R.300 [7,62] 3.0° DRAFT C .625 [15,88] 5.0° .060 [1,52] .000 [0] 3.511 -5° [89,18] DRAFT/SIDE SECTION C-C 8X .185 [4,7] SEE DETAIL B 2.311 -5° [58,7] DRAFT/SIDE 2X .800 [20,32] 8X .035 +1° [0,89] .000 [0] .187 OD [4,75] .072 ID [1,83] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. 2X .800 [20,32] X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: 2X 1.400 [35,56] .000 [0] 2X 1.400 [35,56] APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - ROUTER BAR SXX-362408-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2016-Oct-04 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 362408 A DRAWING NAME 362408_R1_0 SHEET 3 OF 6 REV.DOC 1.0 1.800 [45,72] .000 [0] 1.800 [45,72] 362408 BASE B 5.0° .022 [0,56] 1.200 [30,48] .040 [1,02] .073 [1,85] .230 + 5°DRAFT/SIDE [5,84] DETAIL D SCALE 3.000 .000 [0] .115 + 1°DRAFT/SIDE [2,92] SCALE 1.000 1.200 [30,48] B 2.310 +5° [58,68] DRAFT/SIDE .215 [5,46] SEE DETAIL D .080 THICK [2,03] R.300 [7,62] R.175 [4,45] 3.0° DRAFT .020 [0,51] R.100 [2,54] SECTION B-B .873 [22,17] .010 RECESS [0,25] 2X .800 [20,32] LABEL RECESS .01 .000 [0] 2X .800 [20,32] .873 [22,17] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: 2X 1.400 [35,56] 1.134 [28,81] .000 [0] 1.134 [28,81] 2X 1.400 [35,56] APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - ROUTER BAR SXX-362408-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2016-Oct-04 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 362408 A DRAWING NAME 362408_R1_0 SHEET 4 OF 6 REV.DOC 1.0 .200 CHAMFER 4x [5,08] .200 CHAMFER 4x [5,08] 1.676 [42,56] 1.675 [42,55] 2X 1.400 [35,56] 2X 1.400 [35,56] (2.800 ) [71,12] (2.800 ) [71,12] .000 [0] 3.351 [85,12] 3.350 [85,09] .120 [3,05] 2X 1.400 [35,56] 2X 1.400 [35,56] SCALE 1.000 .000 [0] 4X 4X .195 [4,95] 1.676 [42,56] 1.075 [27,31] 2X .800 [20,32] .000 [0] 1.075 [27,31] 2X .800 [20,32] - CUSTOMER SUPPLIED PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF THE CUSTOMER. 1.076 [27,32] 2X .800 [20,32] .000 [0] 2X .800 [20,32] 1.076 [27,32] 362408 PCB 1mm OR .062" (1.600 ) [40,64] 1.675 [42,55] 2.151 [54,64] .325 [8,26] KEEP OUT ZONES (1.600 ) [40,64] 4X .325 [8,26] KEEP OUT ZONES 4X 2.150 [54,61] SCALE 1.000 .062 [1,57] .039 [1] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL NOTE: ENCLOSURE WILL ACOMMODATE EITHER A 1mm (.039") PCB OR A .062"PCB, NOT BOTH. BOARDS SHOWN ARE MAXIMUM ENVELOPE DIMENSIONS THIS ENCLOSURE CAN HOUSE. BOARD SIZE AND SHAPE ARE UP TO THE DESIGNER'S DESGRETION AS LONG AS IT'S KEPT WITHIN ENVELOPE DIMENSIONS SHOWN AND PCB MOUNTING HOLE PATTERN IS MAINTAINED. BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - ROUTER BAR SXX-362408-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2016-Oct-04 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 362408 A DRAWING NAME 362408_R1_0 SHEET 5 OF 6 REV.DOC 1.0 362408 - 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" 362408 COVER SCALE 1.000 362408 BASE SCALE 1.000 SXX-362408-XXX COVER STEP NO DESCRIPTION CUTTER 1-C-C1 2-C-C2 - T2 = .062" EM T2 = .062" EM STEP NO DESCRIPTION 3-C-P1 PAD PRINT SXX-362408-XXX INK COLOR - FIXTURE ABS, BLACK ORIENTATION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. PROGRAM - COVER - X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL ABS, BLACK CLICHE DESCRIPTION BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - ROUTER BAR SXX-362408-XXX DATE CHECK ENG. CLICHE No. CLXXXX R1 SCALE AS NOTED DRAWN BY M BOYER SIZE 2016-Oct-04 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 362408 A DRAWING NAME 362408_R1_0 SHEET 6 OF 6 REV.DOC 1.0
S3A-362408 价格&库存
很抱歉,暂时无法提供与“S3A-362408”相匹配的价格&库存,您可以联系我们找货
