S3A-382410S
S3A-382410S
    NEWAGE
    9 VOLT HANDHELD, STANDARD
S3A-382410S 数据手册
NOTES: UNLESS OTHERWISE SPECIFIED REV. DRAWN BY 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVELANT TO MT-11020 UNLESS OTHERWISE SPECIFIED. A-G M BOYER 1.0 M BOYER 3. INTERIOR SURFACE TEXTURE: NONE. 2.0 M BOYER 4. ALL INSIDE RADII .010R. ALL OUTSIDE RADII .020R MAX, UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. ECO No DESCRIPTION R E V I S I O N DATE APPROVED PRELIMINARY DESIGN 21-Jul-09 D.C. N/A RELEASED 02-Jun-10 D.C. 2410 EXTEND INSIDE WALL ON BATTERY BASE 01-Jul-10 D.C. 2.1 M BOYER 5310 UPDATE BATTERY CLIP PART NO. 13-Dec-10 D.C. 3.0 M BOYER 5314 REMOVE WALL BASE OPTION 23-Jan-15 D.C. 4.0 M BOYER 04315 REVISE PCB POST HOLE DIA. 2015-Sep-03 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS MAY BE AVAILABLE UPON REQUEST FOR QUOTE. 4 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF EACH OEM. 6 9. CUSTOM LABEL RECESSES MAY BE AVAILABLE UPON REQUEST FOR QUOTE. 3 10. ASSEMBLY HARDWARE PROVIDED. 1 8 S382410(x) CONFIGURATIONS -S -B S382410 COVER 1 1 S382410 BASE 1 S382410 BATTERY BASE 1 S382410 HATCH 1 S382410 SHORT PCB 1* S382410 LONG PCB 1* #4 HiLo SCREW .750" 2 2 #4 HiLo SCREW .375" 9 VOLT CLIP 1** TWO ALTERNATE BASES AND PCB CONFIGURATIONS SHOWN. SEE CONFIG TABLE OR ASK SALES REPRESENTIVE FOR INFORMATION 7 2 9 * = REFERENCE ONLY ** = SOLD SEPERATELY 5 9 NO_4_750_SCREW NO4 HILO .750 S-HiLo x 3/4" ZINC PLATED 2 8 BATTERY-9V 9 VOLT BATTERY REFERENCE ONLY CUSTOMER SUPPLIED 1 7 S382410-PCB-SHORT S382410 PCB .062" THICK CUSTOMER SUPPLIED 1 6 S382410-PCB-LONG S382410 PCB .062" THICK CUSTOMER SUPPLIED 1 5 S382410-HATCH S382410 HATCH - STANDARD ABS BLACK or WHITE 1 4 S382410-COVER S382410 COVER - STANDARD ABS BLACK or WHITE 1 3 S382410-BASE_NOBATT S382410 BASE - STANDARD ABS BLACK or WHITE 1 2 S382410-BASE S382410 BATTERY BASE - STANDARD ABS BLACK or WHITE 1 1 BATTERY-CONTACT-9V ACC-9VCLIP-233M 9V CLIP 6" LEAD BLACK 1 DESCRIPTION MATERIAL COLOR QTY. # FILE NAME BILL OF MATERIALS EXPLODED VIEW SCALE 0.800 THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° DO NOT SCALE DRAWING NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2010 NEW AGE ENCLOSURES 4330 Santa Fe Road ph. (805) 595-1310 APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER STANDARD - 9V HANDHELD SXX-382410X-XXX SIZE 21-Jul-09 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com Customer's Part No: 382410 DRAWING NAME A 382410_R4_0 SHEET 1 OF 8 REV.DOC 4.0 3.320 1.050 X 2.100 FACE 3.0° 3.280 2.410 X .062 1.920 1.880 (.020) R.040 SCALE 0.700 SECTION P-P R.020 .790 FACE 3.800 .388 CLEAR .062 (.420 FACE) (.370 FACE) SCALE 0.700 SECTION X-X .420 CLEAR TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES 4330 Santa Fe Road ph. (805) 595-1310 APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER STANDARD - 9V HANDHELD SXX-382410X-XXX SIZE 21-Jul-09 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com Customer's Part No: 382410 DRAWING NAME A 382410_R4_0 SHEET 2 OF 8 REV.DOC 4.0 382410 COVER 3.0° 3.799 .340 3.320 U U 2.099 1.920 R.050 2.409 SCALE 0.700 Ra.100 RECESS TEXTURE MT-11010 OR EQUIV. .010 .090 .470 .015 .260 2x .000 SECTION U-U .040 .192 2x SCALE 0.700 .925 .000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES .925 APPROVAL BY DATE CHECK ENG. .084 ID 4330 Santa Fe Road ph. (805) 595-1310 SCALE DRAWN BY M BOYER STANDARD - 9V HANDHELD SXX-382410X-XXX SIZE 21-Jul-09 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com Customer's Part No: 382410 DRAWING NAME A 382410_R4_0 SHEET 3 OF 8 REV.DOC 4.0 382410 BATTERY BASE .038 .160 .060 .330 .062 SEE DETAIL A .620 DETAIL A SCALE 3.000 .025 1.600 TEXTURE MT-11010 OR EQUIV. .218 2x 3.0° H .090 THICKNESS .203 RECESS .01" 1.810 .500 J J SCALE 0.700 RECESS TEXTURE MT-11010 OR EQUIV. R.100 .080 SECTION H-H H .125 .420 .218 SECTION J-J .042 .260 2x .120 .000 .063 +1° DRAFT/SIDE 1.253 .188 2x .925 SCALE 0.700 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. .000 1.995 X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES 4330 Santa Fe Road ph. (805) 595-1310 APPROVAL .925 BY DATE CHECK ENG. SCALE DRAWN BY M BOYER STANDARD - 9V HANDHELD SXX-382410X-XXX SIZE 21-Jul-09 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com Customer's Part No: 382410 DRAWING NAME A 382410_R4_0 SHEET 4 OF 8 REV.DOC 4.0 382410 BASE .038 .060 .330 .560 TEXTURE MT-11010 OR EQUIV. .620 3.799 2.409 SCALE 0.700 RECESS TEXTURE MT-11010 OR EQUIV. .000 SECTION J-J .260 2x .090 THICKNESS .120 .187 2x .925 SCALE 0.700 .000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES .925 4330 Santa Fe Road ph. (805) 595-1310 APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER STANDARD - 9V HANDHELD SXX-382410X-XXX SIZE 21-Jul-09 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com Customer's Part No: 382410 DRAWING NAME A 382410_R4_0 SHEET 5 OF 8 REV.DOC 4.0 382410 BATTERY HATCH .263 2.151 .026 .450 .064 R.048 .051 1.461 T T .010 .029 SCALE 1.000 SECTION X-X .150 .019 .058 .080 SECTION T-T .046 SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES 4330 Santa Fe Road ph. (805) 595-1310 APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER STANDARD - 9V HANDHELD SXX-382410X-XXX SIZE 21-Jul-09 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com Customer's Part No: 382410 DRAWING NAME A 382410_R4_0 SHEET 6 OF 8 REV.DOC 4.0 P382410 PCB - CUSTOMER SUPPLIED 1.075 .000 1.075 1.075 .000 1.075 PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. 1.075 1.755 PROPOSED PCB FOR S382410B (with battery hatch) PROPOSED PCB FOR S382410S & S382410W (no battery hatch and wall mount configurations) .000 .197 2x .197 2x 4.0 .000 4.0 .940 2x .260 2x 1.075 .925 .925 SCALE 1.000 .062 THICK 1.755 .925 .925 SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES 4330 Santa Fe Road ph. (805) 595-1310 APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER STANDARD - 9V HANDHELD SXX-382410X-XXX SIZE 21-Jul-09 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com Customer's Part No: 382410 DRAWING NAME A 382410_R4_0 SHEET 7 OF 8 REV.DOC 4.0 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" S382410 BATTERY BASE SCALE 0.700 S382410 COVER SCALE 0.700 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° SXX-382410X-XXX COVER - NEW AGE ENCLOSURES ABS, BLACK 4330 Santa Fe Road ph. (805) 595-1310 STEP NO DESCRIPTION CUTTER FIXTURE ORIENTATION PROGRAM 1-C-C1 2-C-C2 3-C-C3 - T2 = .062" EM T2 = .062" EM T2 = .062" EM 231 231 231 - - APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER STANDARD - 9V HANDHELD SXX-382410X-XXX SIZE 21-Jul-09 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com Customer's Part No: 382410 DRAWING NAME A 382410_R4_0 SHEET 8 OF 8 REV.DOC 4.0
S3A-382410S 价格&库存
很抱歉,暂时无法提供与“S3A-382410S”相匹配的价格&库存,您可以联系我们找货
