NOTES:
UNLESS OTHERWISE SPECIFIED
REV. DRAWN BY
1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM.
2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH.
EQUIVELANT TO MT-11020 UNLESS OTHERWISE SPECIFIED.
A-G
M BOYER
1.0
M BOYER
3. INTERIOR SURFACE TEXTURE: NONE.
2.0
M BOYER
4. ALL INSIDE RADII .010R. ALL OUTSIDE RADII .020R MAX,
5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT
THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES
AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE
FEATURE UNLESS OTHERWISE SPECIFIED.
ECO No
DESCRIPTION
R E V I S I O N
DATE
APPROVED
PRELIMINARY DESIGN
21-Jul-09
D.C.
N/A
RELEASED
02-Jun-10
D.C.
2410
EXTEND INSIDE WALL ON BATTERY BASE
01-Jul-10
D.C.
2.1
M BOYER
5310
UPDATE BATTERY CLIP PART NO.
13-Dec-10
D.C.
3.0
M BOYER
5314
REMOVE WALL BASE OPTION
23-Jan-15
D.C.
4.0
M BOYER
04315
REVISE PCB POST HOLE DIA.
2015-Sep-03
6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS
OTHERWISED SPECIFIED.
7. MATERIAL / COLOR:
ABS PLASTIC IS STANDARD IN BLACK OR WHITE.
CUSTOM MATERIALS AND COLORS MAY BE AVAILABLE UPON REQUEST
FOR QUOTE.
4
8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND
VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF
EACH OEM.
6
9. CUSTOM LABEL RECESSES MAY BE AVAILABLE UPON REQUEST FOR
QUOTE.
3
10. ASSEMBLY HARDWARE PROVIDED.
1
8
S382410(x) CONFIGURATIONS
-S
-B
S382410 COVER
1
1
S382410 BASE
1
S382410 BATTERY BASE
1
S382410 HATCH
1
S382410 SHORT PCB
1*
S382410 LONG PCB
1*
#4 HiLo SCREW .750"
2
2
#4 HiLo SCREW .375"
9 VOLT CLIP
1**
TWO ALTERNATE BASES AND PCB
CONFIGURATIONS SHOWN.
SEE CONFIG TABLE OR ASK SALES
REPRESENTIVE FOR INFORMATION
7
2
9
* = REFERENCE ONLY
** = SOLD SEPERATELY
5
9
NO_4_750_SCREW
NO4 HILO .750
S-HiLo x 3/4"
ZINC PLATED
2
8
BATTERY-9V
9 VOLT BATTERY
REFERENCE ONLY
CUSTOMER SUPPLIED
1
7
S382410-PCB-SHORT
S382410 PCB
.062" THICK
CUSTOMER SUPPLIED
1
6
S382410-PCB-LONG
S382410 PCB
.062" THICK
CUSTOMER SUPPLIED
1
5
S382410-HATCH
S382410 HATCH - STANDARD
ABS
BLACK or WHITE
1
4
S382410-COVER
S382410 COVER - STANDARD
ABS
BLACK or WHITE
1
3
S382410-BASE_NOBATT
S382410 BASE - STANDARD
ABS
BLACK or WHITE
1
2
S382410-BASE
S382410 BATTERY BASE - STANDARD
ABS
BLACK or WHITE
1
1
BATTERY-CONTACT-9V
ACC-9VCLIP-233M
9V CLIP 6" LEAD
BLACK
1
DESCRIPTION
MATERIAL
COLOR
QTY.
FILE
NAME
BILL OF MATERIALS
EXPLODED VIEW
SCALE 0.800
THIRD ANGLE PROJECTION
TOLERANCES: UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN U.S. INCHES.
X.XX = .015 X.XXXX = .001
X.XXX = .010
X.X° = 1°
DO NOT SCALE DRAWING
NOTICE: THE INFORMATION AND DATA
CONTAINED HEREIN IS CONSIDERED
PROPRIETARY TO ALLTEC INTEGRATED
MFG INC & SHALL REMAIN THE EXCLUSIVE
PROPERTY OF ALLTEC INTEGRATED MFG INC
THE HOLDER WILL ASSUME CUSTODY AND
CONTROL THAT THIS DOCUMENT WILL
NOT BE COPIED, REPRODUCED, OR
DISCLOSED WITHOUT THE EXPRESS WRITTEN
CONSENT OF ALLTEC INTEGRATED MFG INC
POSSESSION OF THIS DOCUMENT DOES
NOT CONSTITUTE A GRANT TO
MANUFACTURE ANY ITEMS.
© 2010
NEW AGE ENCLOSURES
4330 Santa Fe Road
ph. (805) 595-1310
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
STANDARD - 9V HANDHELD
SXX-382410X-XXX
SIZE
21-Jul-09
San Luis Obispo, CA. 93401
fax (805) 595-1024
www.newageenclosures.com
Customer's Part No: 382410
DRAWING NAME
A 382410_R4_0
SHEET
1 OF 8
REV.DOC
4.0
3.320
1.050
X
2.100 FACE
3.0°
3.280
2.410
X
.062
1.920
1.880
(.020)
R.040
SCALE 0.700
SECTION P-P
R.020
.790 FACE
3.800
.388 CLEAR
.062
(.420 FACE)
(.370 FACE)
SCALE 0.700
SECTION X-X
.420 CLEAR
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
4330 Santa Fe Road
ph. (805) 595-1310
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
SXX-382410X-XXX
SIZE
21-Jul-09
fax (805) 595-1024
DRAWING NAME
A 382410_R4_0
SHEET
2 OF 8
REV.DOC
4.0
382410 COVER
3.0°
3.799
.340
3.320
U
U
2.099
1.920
R.050
2.409
SCALE 0.700
Ra.100
RECESS TEXTURE MT-11010 OR EQUIV.
.010
.090
.470
.015
.260 2x
.000
SECTION U-U
.040
.192 2x
SCALE 0.700
.925
.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
.925
APPROVAL
BY
DATE
CHECK
ENG.
.084 ID
4330 Santa Fe Road
ph. (805) 595-1310
SCALE
DRAWN BY
M BOYER
SXX-382410X-XXX
SIZE
21-Jul-09
fax (805) 595-1024
DRAWING NAME
A 382410_R4_0
SHEET
3 OF 8
REV.DOC
4.0
382410 BATTERY BASE
.038
.160
.060
.330
.062
SEE DETAIL A
.620
DETAIL A
SCALE 3.000
.025
1.600
TEXTURE MT-11010
OR EQUIV.
.218 2x
3.0°
H
.090 THICKNESS
.203
RECESS
.01"
1.810
.500
J
J
SCALE 0.700
R.100
.080
SECTION H-H
H
.125
.420
.218
SECTION J-J
.042
.260 2x
.120
.000
.063 +1° DRAFT/SIDE
1.253
.188 2x
.925
SCALE 0.700
.000
1.995
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
4330 Santa Fe Road
ph. (805) 595-1310
APPROVAL
.925
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
SXX-382410X-XXX
SIZE
21-Jul-09
fax (805) 595-1024
DRAWING NAME
A 382410_R4_0
SHEET
4 OF 8
REV.DOC
4.0
382410 BASE
.038
.060
.330
.560
TEXTURE MT-11010
OR EQUIV.
.620
3.799
2.409
SCALE 0.700
.000
SECTION J-J
.260 2x
.090 THICKNESS
.120
.187 2x
.925
SCALE 0.700
.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
.925
4330 Santa Fe Road
ph. (805) 595-1310
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
SXX-382410X-XXX
SIZE
21-Jul-09
fax (805) 595-1024
DRAWING NAME
A 382410_R4_0
SHEET
5 OF 8
REV.DOC
4.0
382410 BATTERY HATCH
.263
2.151
.026
.450
.064
R.048
.051
1.461
T
T
.010
.029
SCALE 1.000
SECTION X-X
.150
.019
.058
.080
SECTION T-T
.046
SCALE 1.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
4330 Santa Fe Road
ph. (805) 595-1310
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
SXX-382410X-XXX
SIZE
21-Jul-09
fax (805) 595-1024
DRAWING NAME
A 382410_R4_0
SHEET
6 OF 8
REV.DOC
4.0
P382410 PCB - CUSTOMER SUPPLIED
1.075
.000
1.075
1.075
.000
1.075
SIZES AND VERIFICATION OF IT'S FIT ARE THE
SOLE RESPONSIBILITY OF THE OEM.
1.075
1.755
PROPOSED
PCB
FOR S382410B
(with battery hatch)
PROPOSED
PCB
FOR S382410S & S382410W
(no battery hatch and
wall mount configurations)
.000
.197 2x
.197 2x
4.0
.000
4.0
.940 2x
.260 2x
1.075
.925
.925
SCALE 1.000
.062 THICK
1.755
.925
.925
SCALE 1.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
4330 Santa Fe Road
ph. (805) 595-1310
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
SXX-382410X-XXX
SIZE
21-Jul-09
fax (805) 595-1024
DRAWING NAME
A 382410_R4_0
SHEET
7 OF 8
REV.DOC
4.0
2nd OPERATION DETAILS
NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE
CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT.
ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES
CALL (805) 595-1310 FOR PRICING AND SCHEDULE.
THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031"
SCALE 0.700
S382410 COVER
SCALE 0.700
X.XXX = .010
X.X° = 1°
SXX-382410X-XXX COVER
NEW AGE ENCLOSURES
ABS, BLACK
4330 Santa Fe Road
ph. (805) 595-1310
STEP NO
DESCRIPTION
CUTTER
FIXTURE
ORIENTATION
PROGRAM
1-C-C1
2-C-C2
3-C-C3
T2 = .062" EM
T2 = .062" EM
T2 = .062" EM
231
231
231
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
SXX-382410X-XXX
SIZE
21-Jul-09
fax (805) 595-1024
DRAWING NAME
A 382410_R4_0
SHEET
8 OF 8
REV.DOC
4.0
很抱歉,暂时无法提供与“S3A-382410B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+78.820551+10.24642
- 5+67.371845+8.75812
- 10+62.9679110+8.18563
- 25+57.5874225+7.48618
- 50+53.8249450+6.99707
- 100+50.30959100+6.54009
- 250+46.01089250+5.98127
- 500+44.26217500+5.75394
