NOTES:
R E V I S I O N
UNLESS OTHERWISE SPECIFIED
REV.
DRAWN BY
DATE
APPROVED
2. EXTERIOR SURFACE TEXTURE TO BE EQUIVELANT
TO MT-11020.
A
M BOYER
PRELIMINARY RELEASE
24-Dec-10
D.C.
B
M BOYER
REVISE PER MEETING 01-Mar-11
02-Mar-11
D.C.
C
M BOYER
CHANGE TITLE FROM "4AA SQUARE"
03-Mar-11
D.C.
3. ALL INSIDE RADII .010R. ALL OUTSIDE RADII .020R MAX,
UNLESS OTHERWISE SPECIFIED.
D
M BOYER
REMOVE 9V OPTION, INCLUDE Wii BATTERY
06-May-11
D.C.
E
M BOYER
ADD BATTERY RIBS AND AND UPDATE ASSEMBLY HOLES
11-Jul-11
D.C.
1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM.
4. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT
THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES
AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE
5. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE
UNLESS OTHERWISED SPECIFIED.
ECO No
DESCRIPTION
F
M BOYER
UPDATE DRAWING FORMAT - NO DIM CHANGES
04-Dec-12
D.C.
G
M BOYER
UPDATE KEEP OUT ZONES
18-Mar-13
D.C.
H
M BOYER
INCLUDE BATTERY SEQUENCE NUMBERS
02-Apr-13
D.C.
1.0
R CRUZ
UPDATE TO AS BUILT & RELEASE
06-Aug-13
6. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED.
7. MATERIAL / COLOR:
ABS PLASTIC IS STANDARD IN BLACK OR WHITE.
CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE.
8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND
VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF OEM.
9. STANDARD OR CUSTOM LABEL RECESSES ARE AVAILABLE UPON
REQUEST FOR QUOTE.
3
5
2
1
7
THIS ENCLOSURE CAN ACCOMODATE
4 "AA" BATTERIES IN
PARALLEL OR SERIES.
ALTERNATE BATTERY: "Wii FIT"
LI-ION RECHARGEABLE BATTERY PACK
(4.8 Volt)
SCALE 0.750
10
SINGLE COIL SPRING BATTERY CONTACT
ACC-AANEG-5201
OPTIONAL
4
9
SINGLE BUTTON BATTERY CONTACT
ACC-AAPOS-5223
OPTIONAL
1
8
ACC-AAPOS-5223
OPTIONAL
4
7
AA BATTERY
CUSTOMER SUPPLIED
REFERENCE ONLY
4
6
404017 Wii HATCH - RECHARGEABLE
CUSTOMER SUPPLIED
REFERENCE ONLY
1
5
404017 PCB - .062" THICK
CUSTOMER SUPPLIED
REFERENCE ONLY
1
4
404017 HATCH - STANDARD
ABS
BLACK or WHITE
1
3
404017 COVER - STANDARD
ABS
BLACK or WHITE
1
2
404017 BASE - STANDARD
ABS
BLACK or WHITE
1
1
#6 HiLo x .500" SCREW
ZINK PLATED
INCLUDED
4
ITEM
DESCRIPTION
MATERIAL
COLOR
QTY.
BILL OF MATERIALS
4
6
EXPLODED VIEW
SCALE 0.500
THIRD ANGLE PROJECTION
TOLERANCES: UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN U.S. INCHES.
X.XX = .015 X.XXXX = .001
X.XXX = .010
X.X° = 1°
DO NOT SCALE DRAWING
NOTICE: THE INFORMATION AND DATA
CONTAINED HEREIN IS CONSIDERED
PROPRIETARY TO ALLTEC INTEGRATED
MFG INC & SHALL REMAIN THE EXCLUSIVE
PROPERTY OF ALLTEC INTEGRATED MFG INC
THE HOLDER WILL ASSUME CUSTODY AND
CONTROL THAT THIS DOCUMENT WILL
NOT BE COPIED, REPRODUCED, OR
DISCLOSED WITHOUT THE EXPRESS WRITTEN
CONSENT OF ALLTEC INTEGRATED MFG INC
POSSESSION OF THIS DOCUMENT DOES
NOT CONSTITUTE A GRANT TO
MANUFACTURE ANY ITEMS.
© 2012
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
STANDARD - 4AA PALM-HELD
SXX-404017-XXX
SIZE
24-Dec-10
San Luis Obispo, CA. 93401
fax (805) 595-1024
www.newageenclosures.com
404017
DRAWING NAME
A 404017_R1_0
SHEET
1 OF 7
REV.DOC
1.0
404017 ASSEMBLY
1.598
SEE DETAIL E
4.000
.883
.020 STANDOFFS
.685
Y
4.000
SECTION Y-Y
SCALE 0.500
3.15
3.05
Y
SEE DETAIL D
TOP OF PCB
.601 CLEARANCE
SECTION P-P
(.013)
DETAIL D
SCALE 2.500
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
DETAIL E
SCALE 1.000
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-404017-XXX
SIZE
24-Dec-10
fax (805) 595-1024
404017
DRAWING NAME
A 404017_R1_0
SHEET
2 OF 7
REV.DOC
1.0
2.000
.000
2.000
.685
4.000 SQ.
1.575 2x
.770
1.575 2x
404017 COVER
R.500
2.000
1.525 2x
Y
Y
.000
P
P
1.525 2x
2.000
SCALE 0.700
R.362
SEE DETAIL A
3.724 SQ.
(.080)
.070
.085
.035 +1°
DRAFT/SIDE
.040
.110
.245
.015
.375 +3°
DRAFT/SIDE
.084
SECTION P-P
.110
.059
1.5°
DETAIL B
SCALE 3.000
DETAIL A
SCALE 1.400
X.XXX = .010
X.X° = 1°
SECTION Y-Y
SEE DETAIL B
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-404017-XXX
SIZE
24-Dec-10
fax (805) 595-1024
404017
DRAWING NAME
A 404017_R1_0
SHEET
3 OF 7
REV.DOC
1.0
404017 BASE
2.000
1.575 2x
.066
1.342
.110
R.183
B
.000
K
2.000
3.076
SEE DETAIL F
1.575 2x
ARE PROVIDED FOR
DRAWING REFERENCE ONLY
NOT MOLD ENGRAVED
2.000
1.525 2x
.260
.700
.167
2.616
.000
1.525 2x
SCALE 0.700
K
B
2.000
SEE DETAIL C
SECTION K-K
SECTION B-B
BATTERY ORIENTATION
NOT SPECIFIED.
.465
.020
.010
.003
.055
.058
.245 +2°
DRAFT/SIDE
.135
.025
.369 +2°
DRAFT/SIDE
.125
.863
DETAIL F
SCALE 4.000
.238
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
DETAIL C
SCALE 2.000
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-404017-XXX
SIZE
24-Dec-10
fax (805) 595-1024
404017
DRAWING NAME
A 404017_R1_0
SHEET
4 OF 7
REV.DOC
1.0
404017 HATCH
.085
3.051
.165
.104
.030
2.606
.324
.350
.466
1.540
R.203
SCALE 0.700
.085
.104
.039
R.200
.465
+.003
-.001
.059
.080
SECTION Y-Y
4.0°
.040
.063
DETAIL H
SCALE 3.000
.070
DETAIL G
SCALE 3.000
SEE DETAIL G
SEE DETAIL H
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-404017-XXX
SIZE
24-Dec-10
fax (805) 595-1024
404017
DRAWING NAME
A 404017_R1_0
SHEET
5 OF 7
REV.DOC
1.0
404017 PCB - CUSTOMER SUPPLIED
SIZES AND VERIFICATION OF IT'S FIT ARE THE
SOLE RESPONSIBILITY OF THE OEM.
1.8375
1.498
1.575 2x
1.198
.798 2x
.193 2x
.000
.413 2x
1.018 2x
1.575 2x
1.418
1.8375
(3.675)
.062
+.002
-.002
1.8375
1.525 2x
1.169
1.085 4x
.400
USE TWO CONTACT LOCATIONS
FOR Wii FIT BATTERY
.000
(3.6750)
.400
KEEP OUT ZONE
.380 KEEP OUT 4x
1.085 4x
1.169
1.525 2x
SIDE TOWARD
BATTERY COMPARTMENT
1.8375
SCALE 0.700
R.350
.242 4x
.032
.160 8x
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-404017-XXX
SIZE
24-Dec-10
fax (805) 595-1024
404017
DRAWING NAME
A 404017_R1_0
SHEET
6 OF 7
REV.DOC
1.0
404017 - 2nd OPERATION DETAILS
.000
1.575
NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE
CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT.
ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES
CALL (805) 595-1310 FOR PRICING AND SCHEDULE.
THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031"
1.525
.000
SCALE 1.000
SECTION X-X
X.XXX = .010
X.X° = 1°
STEP
2
3
4
SXX-404017-XXX
DESCRIPTION
CUTTER
COVER
T2 = .062" EM
FIXTURE
ABS, BLACK
ORIENTATION
NEW AGE ENCLOSURES
Customer's Part No:
PROGRAM
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-404017-XXX
SIZE
24-Dec-10
fax (805) 595-1024
404017
DRAWING NAME
A 404017_R1_0
SHEET
7 OF 7
REV.DOC
1.0
很抱歉,暂时无法提供与“S3A-404017”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+105.585771+13.72114
