R E V I S I O N
NOTES: UNLESS OTHERWISE SPECIFIED
REV.
1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM.
2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH.
EQUIVELANT TO MT-11020.
3. INTERIOR SURFACE TEXTURE TO BE: NONE.
DRAWN BY
ECO No
A-J
M BOYER
1.0
M BOYER
N/A
1.1
M BOYER
04515
DESCRIPTION
DATE
APPROVED
DEVELOPMENT
2009-Aug-24
D.C.
UPDATE TO AS-BUILT AND RELEASE
2010-Mar-29
D.C.
REVISE ASSEMBLY SCREW LENGTH
2015-Sep-14
4. ALL INSIDE RADII .010R. ALL OUTSIDE RADII .020R MAX,
UNLESS OTHERWISE SPECIFIED.
5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT
THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES
AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE
2
6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE
UNLESS OTHERWISED SPECIFIED.
7
7. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. MOUNTING SCREWS
FOR THE PCB ARE SOLD SEPERATELY.
4
8. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE.
CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE.
5
9. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND
VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF OEM.
8
10. STANDARD OR CUSTOM LABEL RECESSES ARE AVAILABLE UPON
REQUEST FOR QUOTE.
434313 ENCLOSURE SHOWN WITH 2 PCB SIZE
OPTIONS. THIS ENCLOSURE DOES NOT
SUPPORT TWO PCB BOARDS AT ONCE.
1
3
S434313
S434313
S434313
S434313
S434313
S434313
#4 HiLo
S434313
S434313(x) CONFIGURATIONS
-S
-SW
-F
COVER
COVER w/ OPENING
BASE
BASE w/ OPENING
WALL BASE
WALL BASE w/ OPENING
SCREW .500"
FACEPLATE
1
1
1
1
4
4
1
-FW
-FP
1
6
1
4
EXPLODED VIEW
SCALE 0.666
1
4
1
8
434313_FACEPLATE
434313 FACEPLATE - STANDARD
6061 ALUMINUM
SOLD SEPERATELY
1
7
NO_4_375_SCREW
No4 HiLo x .375" - PCB
#4 HiLo x 3/8"
SOLD SEPERATELY
4
6
NO_4_500_SCREW
No4 HiLo x .500" - ASSEMBLY
#4 HiLo x 1/2"
INCLUDED
4
5
434313_PCB-4X4
434313 PCB - REFERENCE
.062" THICK
CUSTOMER SUPPLIED
1
4
434313_PCB-4X3
.062" THICK
CUSTOMER SUPPLIED
1
3
434313_WALL-BASE
434313 WALL - STANDARD
ABS
BLACK or WHITE
1
2
434313_COVER
434313 COVER - STANDARD
ABS
BLACK or WHITE
1
1
434313_BASE
434313 BASE - STANDARD
ABS
BLACK or WHITE
1
DESCRIPTION
MATERIAL
COLOR
QTY.
ITEM
FILE
NAME
BILL OF MATERIALS
THIRD ANGLE PROJECTION
TOLERANCES: UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN U.S. INCHES.
X.XX = .015 X.XXXX = .001
X.XXX = .010
X.X° = 1°
DO NOT SCALE DRAWING
NOTICE: THE INFORMATION AND DATA
CONTAINED HEREIN IS CONSIDERED
PROPRIETARY TO ALLTEC INTEGRATED
MFG INC & SHALL REMAIN THE EXCLUSIVE
PROPERTY OF ALLTEC INTEGRATED MFG INC
THE HOLDER WILL ASSUME CUSTODY AND
CONTROL THAT THIS DOCUMENT WILL
NOT BE COPIED, REPRODUCED, OR
DISCLOSED WITHOUT THE EXPRESS WRITTEN
CONSENT OF ALLTEC INTEGRATED MFG INC
POSSESSION OF THIS DOCUMENT DOES
NOT CONSTITUTE A GRANT TO
MANUFACTURE ANY ITEMS.
© 2010
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
STANDARD - SQUARE UTIL.
SXX-434313X-XXX
SIZE
2009-Aug-24
San Luis Obispo, CA. 93401
fax (805) 595-1024
www.newageenclosures.com
434313
DRAWING NAME
A 434313X_R1_1
SHEET
1 OF 8
REV.DOC
1.1
4.284
3.0°
4.284
3.500 SQ.
RECESS .015
SCALE 0.500
.900
X
THIS ENCLOSURE CAN BE MOLDED
WITH OR WITHOUT THE FACEPLATE
OPENING. ASK YOUR SALES REP FOR DETAILS.
26.4°
X
DETAIL A
SCALE 1.000
SECTION X-X
SCALE 1.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
SEE DETAIL A
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-434313X-XXX
SIZE
2009-Aug-24
fax (805) 595-1024
434313
DRAWING NAME
A 434313X_R1_1
SHEET
2 OF 8
REV.DOC
1.1
434313 COVER
4.284
3.500
X
3.600
R.199
.020
R.060
Y
4.284
Y
3.500
2.400
P
SCALE 0.500
P
SECTION X-X
X
.092
.900
SECTION P-P
.250 4x
.980
.110 WALL THICKNESS
.010
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
SECTION Y-Y
ENG.
SCALE
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-434313X-XXX
SIZE
2009-Aug-24
fax (805) 595-1024
434313
DRAWING NAME
A 434313X_R1_1
SHEET
3 OF 8
REV.DOC
1.1
2.142
1.450 2x
1.800 2x
.000
1.450 2x
4.284
1.800 2x
2.142
434313 BASE
2.010
H
2.142
1.800 2x
1.200 2x
Y
4.284
2.010
Y
RECESS .01
G
G
.000
2.025
1.200 2x
1.800 2x
.052
SECTION H-H
2.142
SCALE 0.500
.385 x .02
4 PLACES
H
.110
R.150
.052 slot
1.500
.281
.092
.250
3.0°
.390
.150
3.700
.203 +1° DRAFT/SIDE
.060
.246
SECTION G-G
.110 WALL THICKNESS
.010
SECTION Y-Y
4.057
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-434313X-XXX
SIZE
2009-Aug-24
fax (805) 595-1024
434313
DRAWING NAME
A 434313X_R1_1
SHEET
4 OF 8
REV.DOC
1.1
434313 WALL
5.080
2.010
5.0°
G
.246
R.050
Y
Y
.125
4.355
2.010
RECESS
x .010
.250
SECTION G-G
.092
SCALE 0.500
G
.140
4.650
29.7°
3.700
.390
SECTION Y-Y
.080
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-434313X-XXX
SIZE
2009-Aug-24
fax (805) 595-1024
434313
DRAWING NAME
A 434313X_R1_1
SHEET
5 OF 8
REV.DOC
1.1
434313 FACE PLATE
3.800
3.700
AVAILABLE
.268 FROM CENTERLINE TO
TOP OF ASSEMBLED PCB BOARD
(REFERENCE)
.835
.935
AVAILABLE
(.200)
.030 x 45° TYP.
434313 FACEPLATE
SCALE 1.000
.048
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-434313X-XXX
SIZE
2009-Aug-24
fax (805) 595-1024
434313
DRAWING NAME
A 434313X_R1_1
SHEET
6 OF 8
REV.DOC
1.1
434313 PCB - CUSTOMER SUPPLIED
SIZES AND VERIFICATION OF IT'S FIT ARE THE
SOLE RESPONSIBILITY OF THE OEM.
SEE SHEET 4 FOR POST CLEARANCE DETAILS.
ENCLOSURE DESIGNED TO ACCOMODATE ONE OF THE TWO
PCB CONFIGURATIONS SHOWN BELOW (NOT BOTH AT THE SAME TIME).
4.000
3.300
3.600
2.900
4.000
2.400
4.000
3.600
.125 4x
ALLOWANCES MUST BE MADE
FOR THE EXTRA PCB POSTS IN
ENCLOSURE OR POSTS SHOULD
BE CLIPPED BY CUSTOMER.
.064
4x4 PCB
SCALE 0.500
FRONT FACE
(FACEPLATE SIDE)
FRONT FACE
(FACEPLATE SIDE
4x3 PCB
SCALE 0.500
.125 4x
.064
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-434313X-XXX
SIZE
2009-Aug-24
fax (805) 595-1024
434313
DRAWING NAME
A 434313X_R1_1
SHEET
7 OF 8
REV.DOC
1.1
2nd OPERATION DETAILS
NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE
CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT.
ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES
CALL (805) 595-1310 FOR PRICING AND SCHEDULE.
THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031"
434313 COVER
SCALE 0.500
SXX-434313-XXX COVER
434313 BASE
SCALE 0.500
ABS, BLACK
STEP NO
DESCRIPTION
CUTTER
FIXTURE
ORIENTATION
PROGRAM
1-C-C1
2-C-C2
3-C-C3
T2 = .062" EM
T2 = .062" EM
T2 = .062" EM
207
207
207
o1000
o1000
o1000
SXX-434313-XXX BASE
ABS, BLACK
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
STEP NO
DESCRIPTION
CUTTER
FIXTURE
ORIENTATION
PROGRAM
1-B-C1
2-B-C2
3-B-C3
T2 = .062" EM
T2 = .062" EM
T2 = .062" EM
234
234
234
o1000
o1000
o1000
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-434313X-XXX
SIZE
2009-Aug-24
fax (805) 595-1024
434313
DRAWING NAME
A 434313X_R1_1
SHEET
8 OF 8
REV.DOC
1.1
很抱歉,暂时无法提供与“S1A-434313SW”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+88.991961+11.47278
