S1A-442710-K
S1A-442710-K
    NEWAGE
    MEDIUM HANDHELD - KIT
S1A-442710-K 数据手册
NOTES: R E V I S I O N UNLESS OTHERWISE SPECIFIED REV. 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. DRAWN BY ECO No DESCRIPTION DATE APPROVED 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVALENT TO MT-11010. 1 M BOYER --- RELEASE 27-Jun-09 D.C. 3 M BOYER 3109 CONSOLIDATE ALL 442710 CONFIG INTO ONE DOCUMENT 05-Sep-09 D.C. 3. INTERIOR SURFACE TEXTURE: 4 M BOYER 3809 INCREASE HATCH RELIEF TOLERANCE 27-Oct-09 D.C. 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. 4.1 M BOYER 0710 UPDATE FORMAT 26-Mar-10 D.C. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 4.2 M BOYER 0712 UPDATE CONFIG AND REMOVE LCD CONFIG 28-Feb-12 D.C. 4.3 R CRUZ 1114 REMOVE LCD CONFIG & UPDATE NOTES 19-Mar-14 D.C. 4.4 R CRUZ 3314 REVISE CONFIGURATION TABLE 18-Jun-14 D.C. 4.5 R CRUZ 03615 ADD LABEL RECESS DIMENSIONS ON COVER 06-Aug-15 NONE. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS MAY BE AVAILABLE UPON REQUEST FOR QUOTE. 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH CUSTOMER. 4 9. CUSTOM LABEL RECESSES MAY BE AVAILABLE UPON REQUEST FOR QUOTE. 8 10. ASSEMBLY SCREWS PROVIDED. BATTERY CONTACTS SOLD SEPERATELY. PCB SCREWS ARE CUSTOMER SUPPLIED. 7 11. ANY SPECIFIC DIMENSIONS NOT PROVIDED HERE CAN BE OBTAINED FROM OUR SOLID MODELS (.STEP), AVAILABLE AT OUR WEBSITE. MODIFIED CUSTOMER MODELS ARE AVAILABLE UPON REQUEST. 442710(x) CONFIGURATIONS -Blank 442710 COVER 1 442710 BATTERY BASE 1 442710 WALL PLATE 442710 HATCH 1 442710 HATCH (Modified) #4 HiLo SCREW 1.00" #4 HiLo SCREW .750" 2 #4 HiLo SCREW .500" 2 SINGLE AA CLIP 2* DOUBLE AA CLIP 1* * = SOLD SEPERATELY -K 1 1 1 2 -WP* 1 1 1 2 2* 1* 1 1 5 3 1 10 11 SCALE 0.500 11 NO_4_750_SCREW HiLo4 x 3/4" S-HiLo x 3/4" ZINC PLATED 1 10 NO_4_500_SCREW HiLo4 x 1/2" S-HiLo x 1/2" ZINC PLATED 1 9 NO_4_1000_SCREW HiLo4 x 1" S-HiLo x 1.0" ZINC PLATED 2 8 SM_CLIP PartNo: 209 SINGLE AA NICKEL PLATED 2 7 LG_CLIP PartNo:210 DOUBLE AA NICKEL PLATED 1 6 442710-WALL 442710 WALL - STANDARD ABS BLACK or WHITE 1 5 442710-HATCH 442710 HATCH - STANDARD ABS BLACK or WHITE 1 4 442710-COVER 442710 COVER - STANDARD ABS BLACK or WHITE 1 3 442710-BASE 442710 BASE - STANDARD ABS BLACK or WHITE 1 2 442710-PCB REFERENCE ONLY CUSTOMER SUPPLIED .062" THICK 1 1 AA_BATTERY REFERENCE ONLY CUSTOMER SUPPLIED - 2 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS 9 6 SCALE 0.625 THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2017 Customer's Part No: APPROVAL BY 442710X DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 MED HANDHELD - STANDARD SXX-442710X-XXXX SIZE 2009-Jun-27 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 442710X_R4_5 SHEET 1 OF 10 REV.DOC 4.5 3.100 1.165 .160 2.750 -A- 5.350 -A- -A- 4.850 4.460 SCALE 0.800 R8.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 442710X DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 MED HANDHELD - STANDARD SXX-442710X-XXXX SIZE 2009-Jun-27 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 442710X_R4_5 SHEET 2 OF 10 REV.DOC 4.5 .062 PCB .224 .530 X 1.014 -A- P -A- -A- -A- .223 CLEAR .062 PCB .529 CLEAR SECTION X-X SECTION P-P P X SCALE 0.800 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 442710X DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 MED HANDHELD - STANDARD SXX-442710X-XXXX SIZE 2009-Jun-27 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 442710X_R4_5 SHEET 3 OF 10 REV.DOC 4.5 442710 COVER 2.750 .494 C 2.103 .100 -A- -A- -A- B -A- -A- B 4.460 3.822 R.030 SECTION C-C .025 C SCALE 0.800 SECTION B-B 2.0° DRAFT TYP. TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 442710X DATE CHECK SPECIFIC GEOMETRIC DATA CAN BE OBTAINED FROM THE CAD MODEL AND DOWNLOADED VIA OUR WESITE. ALTERNATE FORMS OF CAD INFORMATION ARE AVAILABLE UPON REQUEST. ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 MED HANDHELD - STANDARD SXX-442710X-XXXX SIZE 2009-Jun-27 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 442710X_R4_5 SHEET 4 OF 10 REV.DOC 4.5 442710 BASE .797 .493 2.749 .100 1.770 A C .020 1.865 4.459 1.168 SECTION C-C SECTION A-A SCALE 0.800 2.248 C A TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 442710X DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 MED HANDHELD - STANDARD SXX-442710X-XXXX SIZE 2009-Jun-27 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 442710X_R4_5 SHEET 5 OF 10 REV.DOC 4.5 442710 HATCH 2.733 .273 .281 A .043 .100 1.937 SECTION A-A SCALE 1.000 A .156 2nd OPERATION: CLEARANCE FOR ATTACHMENT OF WALL PLATE (S-442710W-K) TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 442710X DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 MED HANDHELD - STANDARD SXX-442710X-XXXX SIZE 2009-Jun-27 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 442710X_R4_5 SHEET 6 OF 10 REV.DOC 4.5 442710 WALL PLATE 3.100 2.713 .076 .330 X F .150 5.350 4.430 SECTION F-F SECTION X-X 4.850 SCALE 0.800 F R8.000 X TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 442710X DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 MED HANDHELD - STANDARD SXX-442710X-XXXX SIZE 2009-Jun-27 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 442710X_R4_5 SHEET 7 OF 10 REV.DOC 4.5 S442710 PCB - CUSTOMER SUPPLIED 1.032 1.150 .000 .550 1.150 1.000 PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. .062 1.250 1.125 .990 .910 1.050 .000 .180 THRU .910 .990 1.125 1.050 .472 .822 1.250 .280 KEEP OUT ZONE SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 442710X DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 MED HANDHELD - STANDARD SXX-442710X-XXXX SIZE 2009-Jun-27 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 442710X_R4_5 SHEET 8 OF 10 REV.DOC 4.5 SUGGESTED LABEL SIZE (w/ .01" minimum gap per side) CUSTOMER SUPPLIED R.020 TYP. 3.802 R7.19 2.083 SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 442710X DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 MED HANDHELD - STANDARD SXX-442710X-XXXX SIZE 2009-Jun-27 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 442710X_R4_5 SHEET 9 OF 10 REV.DOC 4.5 2nd OPERATION DETAILS (R93.166) (1.375) .000 (1.375) New Age Enclosures DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY New Age Enclosures CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" -A- (1.914) (1.367) .900 .000 (1.367) +.020 -.020 (2.230) -A- (R233.825) (.968) .000 .000 .664 +.020 -.020 (.968) 442710K HATCH SCALE 0.800 +.020 .156 -.010 (1.914) (2.230) STEP NO 1-H-C1 SXX-442710K-XXX DESCRIPTION .156 ASSEMBLY HOLE CUTTER HATCH T2 = .062" EM SXX-442710-XXX - FIXTURE 113 COVER - ABS, BLACK 442710 COVER SCALE 0.800 ORIENTATION PROGRAM USE ENCLOSURE ASSEMBLY o4977 ABS, BLACK DESCRIPTION CUTTER FIXTURE ORIENTATION PROGRAM 2-C-C1 - T2 = .062" EM 333 CENTER BLOCK - RAD. RIGHT - BASE STEP NO DESCRIPTION CUTTER 3-B-C1 - T2 = .062" EM - ABS, BLACK TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° STEP NO SXX-442710-XXX (R7.515) NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 442710X DATE CHECK FIXTURE ORIENTATION PROGRAM 113 CENTER BLOCK - RAD. RIGHT - ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 MED HANDHELD - STANDARD SXX-442710X-XXXX SIZE 2009-Jun-27 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 442710X_R4_5 SHEET 10 OF 10 REV.DOC 4.5
S1A-442710-K 价格&库存
很抱歉,暂时无法提供与“S1A-442710-K”相匹配的价格&库存,您可以联系我们找货
