NOTES:
R E V I S I O N
UNLESS OTHERWISE SPECIFIED
REV.
1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM.
DRAWN BY
ECO No
DESCRIPTION
DATE
APPROVED
2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH.
EQUIVALENT TO MT-11010.
1
M BOYER
RELEASE
27-Jun-09
D.C.
3
M BOYER
3109
CONSOLIDATE ALL 442710 CONFIG INTO ONE DOCUMENT 05-Sep-09
D.C.
3. INTERIOR SURFACE TEXTURE:
4
M BOYER
3809
INCREASE HATCH RELIEF TOLERANCE
27-Oct-09
D.C.
4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED.
4.1
M BOYER
0710
UPDATE FORMAT
26-Mar-10
D.C.
5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT
THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES
AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE
FEATURE UNLESS OTHERWISE SPECIFIED.
4.2
M BOYER
0712
UPDATE CONFIG AND REMOVE LCD CONFIG
28-Feb-12
D.C.
4.3
R CRUZ
1114
REMOVE LCD CONFIG & UPDATE NOTES
19-Mar-14
D.C.
4.4
R CRUZ
3314
REVISE CONFIGURATION TABLE
18-Jun-14
D.C.
4.5
R CRUZ
03615
ADD LABEL RECESS DIMENSIONS ON COVER
06-Aug-15
NONE.
6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS
OTHERWISED SPECIFIED.
7. MATERIAL / COLOR:
ABS PLASTIC IS STANDARD IN BLACK OR WHITE.
CUSTOM MATERIALS AND COLORS MAY BE AVAILABLE UPON REQUEST
FOR QUOTE.
8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND
VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF
EACH CUSTOMER.
4
9. CUSTOM LABEL RECESSES MAY BE AVAILABLE UPON REQUEST FOR QUOTE.
8
10. ASSEMBLY SCREWS PROVIDED. BATTERY CONTACTS SOLD SEPERATELY.
PCB SCREWS ARE CUSTOMER SUPPLIED.
7
11. ANY SPECIFIC DIMENSIONS NOT PROVIDED HERE CAN BE OBTAINED FROM
OUR SOLID MODELS (.STEP), AVAILABLE AT OUR WEBSITE. MODIFIED
CUSTOMER MODELS ARE AVAILABLE UPON REQUEST.
442710(x) CONFIGURATIONS
-Blank
442710 COVER
1
442710 BATTERY BASE
1
442710 WALL PLATE
442710 HATCH
1
442710 HATCH (Modified)
#4 HiLo SCREW 1.00"
#4 HiLo SCREW .750"
2
#4 HiLo SCREW .500"
2
SINGLE AA CLIP
2*
DOUBLE AA CLIP
1*
* = SOLD SEPERATELY
-K
1
1
1
2
-WP*
1
1
1
2
2*
1*
1
1
5
3
1
10
11
SCALE 0.500
11
NO_4_750_SCREW
HiLo4 x 3/4"
S-HiLo x 3/4"
ZINC PLATED
1
10
NO_4_500_SCREW
HiLo4 x 1/2"
S-HiLo x 1/2"
ZINC PLATED
1
9
NO_4_1000_SCREW
HiLo4 x 1"
S-HiLo x 1.0"
ZINC PLATED
2
8
SM_CLIP
PartNo: 209
SINGLE AA
NICKEL PLATED
2
7
LG_CLIP
PartNo:210
DOUBLE AA
NICKEL PLATED
1
6
442710-WALL
442710 WALL - STANDARD
ABS
BLACK or WHITE
1
5
442710-HATCH
442710 HATCH - STANDARD
ABS
BLACK or WHITE
1
4
442710-COVER
442710 COVER - STANDARD
ABS
BLACK or WHITE
1
3
442710-BASE
442710 BASE - STANDARD
ABS
BLACK or WHITE
1
2
442710-PCB
REFERENCE ONLY
CUSTOMER SUPPLIED
.062" THICK
1
1
AA_BATTERY
REFERENCE ONLY
CUSTOMER SUPPLIED
2
DESCRIPTION
MATERIAL
COLOR
QTY.
ITEM
FILE
NAME
BILL OF MATERIALS
9
6
SCALE 0.625
THIRD ANGLE PROJECTION
TOLERANCES: UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN U.S. INCHES.
DO NOT SCALE DRAWING
NEW AGE ENCLOSURES
X.XX = .015 X.XXXX = .001
X.XXX = .010
X.X° = 1°
NOTICE: THE INFORMATION AND DATA
CONTAINED HEREIN IS CONSIDERED
PROPRIETARY TO ALLTEC INTEGRATED
MFG INC & SHALL REMAIN THE EXCLUSIVE
PROPERTY OF ALLTEC INTEGRATED MFG INC
THE HOLDER WILL ASSUME CUSTODY AND
CONTROL THAT THIS DOCUMENT WILL
NOT BE COPIED, REPRODUCED, OR
DISCLOSED WITHOUT THE EXPRESS WRITTEN
CONSENT OF ALLTEC INTEGRATED MFG INC
POSSESSION OF THIS DOCUMENT DOES
NOT CONSTITUTE A GRANT TO
MANUFACTURE ANY ITEMS.
© 2017
Customer's Part No:
APPROVAL
BY
442710X
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
2240 South Thornburg Street
ph. (805) 595-1310
MED HANDHELD - STANDARD
SXX-442710X-XXXX
SIZE
2009-Jun-27
Santa Maria, CA. 93455
fax (805) 595-1024
www.newageenclosures.com
A
DRAWING NAME
442710X_R4_5
SHEET
1 OF 10
REV.DOC
4.5
3.100
1.165
.160
2.750
-A-
5.350
-A-
-A-
4.850
4.460
SCALE 0.800
R8.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
442710X
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXX-442710X-XXXX
SIZE
2009-Jun-27
fax (805) 595-1024
A
DRAWING NAME
442710X_R4_5
SHEET
2 OF 10
REV.DOC
4.5
.062 PCB
.224
.530
X
1.014
-A-
P
-A-
-A-
-A-
.223 CLEAR
.062 PCB
.529 CLEAR
SECTION X-X
SECTION P-P
P
X
SCALE 0.800
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
442710X
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXX-442710X-XXXX
SIZE
2009-Jun-27
fax (805) 595-1024
A
DRAWING NAME
442710X_R4_5
SHEET
3 OF 10
REV.DOC
4.5
442710 COVER
2.750
.494
C
2.103
.100
-A-
-A-
-A-
B
-A-
-A-
B
4.460
3.822
R.030
SECTION C-C
.025
C
SCALE 0.800
SECTION B-B
2.0° DRAFT
TYP.
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
442710X
DATE
CHECK
SPECIFIC GEOMETRIC DATA CAN BE OBTAINED FROM THE CAD MODEL AND DOWNLOADED VIA
OUR WESITE. ALTERNATE FORMS OF CAD INFORMATION ARE AVAILABLE UPON REQUEST.
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXX-442710X-XXXX
SIZE
2009-Jun-27
fax (805) 595-1024
A
DRAWING NAME
442710X_R4_5
SHEET
4 OF 10
REV.DOC
4.5
442710 BASE
.797
.493
2.749
.100
1.770
A
C
.020
1.865
4.459
1.168
SECTION C-C
SECTION A-A
SCALE 0.800
2.248
C
A
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
442710X
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXX-442710X-XXXX
SIZE
2009-Jun-27
fax (805) 595-1024
A
DRAWING NAME
442710X_R4_5
SHEET
5 OF 10
REV.DOC
4.5
442710 HATCH
2.733
.273
.281
A
.043
.100
1.937
SECTION A-A
SCALE 1.000
A
.156
2nd OPERATION:
CLEARANCE FOR ATTACHMENT
OF WALL PLATE (S-442710W-K)
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
442710X
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXX-442710X-XXXX
SIZE
2009-Jun-27
fax (805) 595-1024
A
DRAWING NAME
442710X_R4_5
SHEET
6 OF 10
REV.DOC
4.5
442710 WALL PLATE
3.100
2.713
.076
.330
X
F
.150
5.350 4.430
SECTION F-F
SECTION X-X
4.850
SCALE 0.800
F
R8.000
X
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
442710X
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXX-442710X-XXXX
SIZE
2009-Jun-27
fax (805) 595-1024
A
DRAWING NAME
442710X_R4_5
SHEET
7 OF 10
REV.DOC
4.5
S442710 PCB - CUSTOMER SUPPLIED
1.032
1.150
.000
.550
1.150
1.000
SIZES AND VERIFICATION OF ITS FIT ARE THE
SOLE RESPONSIBILITY OF THE OEM.
.062
1.250
1.125
.990
.910
1.050
.000
.180 THRU
.910
.990
1.125
1.050
.472
.822
1.250
.280 KEEP OUT ZONE
SCALE 1.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
442710X
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXX-442710X-XXXX
SIZE
2009-Jun-27
fax (805) 595-1024
A
DRAWING NAME
442710X_R4_5
SHEET
8 OF 10
REV.DOC
4.5
SUGGESTED LABEL SIZE
(w/ .01" minimum gap per side)
CUSTOMER SUPPLIED
R.020 TYP.
3.802
R7.19
2.083
SCALE 1.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
442710X
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXX-442710X-XXXX
SIZE
2009-Jun-27
fax (805) 595-1024
A
DRAWING NAME
442710X_R4_5
SHEET
9 OF 10
REV.DOC
4.5
2nd OPERATION DETAILS
(R93.166)
(1.375)
.000
(1.375)
New Age Enclosures DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE
CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT.
ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY New Age Enclosures
CALL (805) 595-1310 FOR PRICING AND SCHEDULE.
THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031"
-A-
(1.914)
(1.367)
.900
.000
(1.367)
+.020
-.020
(2.230)
-A-
(R233.825)
(.968)
.000
.000
.664
+.020
-.020
(.968)
442710K HATCH
SCALE 0.800
+.020
.156
-.010
(1.914)
(2.230)
STEP NO
1-H-C1
SXX-442710K-XXX
DESCRIPTION
.156 ASSEMBLY HOLE
CUTTER
HATCH
T2 = .062" EM
SXX-442710-XXX
FIXTURE
113
COVER
ABS, BLACK
442710 COVER
SCALE 0.800
ORIENTATION
PROGRAM
USE ENCLOSURE ASSEMBLY
o4977
ABS, BLACK
DESCRIPTION
CUTTER
FIXTURE
ORIENTATION
PROGRAM
2-C-C1
T2 = .062" EM
333
CENTER BLOCK - RAD. RIGHT
BASE
STEP NO
DESCRIPTION
CUTTER
3-B-C1
T2 = .062" EM
ABS, BLACK
X.XXX = .010
X.X° = 1°
STEP NO
SXX-442710-XXX
(R7.515)
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
442710X
DATE
CHECK
FIXTURE
ORIENTATION
PROGRAM
113
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXX-442710X-XXXX
SIZE
2009-Jun-27
fax (805) 595-1024
A
DRAWING NAME
442710X_R4_5
SHEET
10 OF 10
REV.DOC
4.5
很抱歉,暂时无法提供与“S3A-442710-K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+135.791281+17.56151
- 5+116.047775+15.00814
- 10+108.4772610+14.02906
- 25+99.2104225+12.83061
- 50+92.7291950+11.99241
- 100+86.67011100+11.20881
- 250+81.53042250+10.54410
