S1A-453212
S1A-453212
    NEWAGE
    LARGE UTILITY
S1A-453212 数据手册
NOTES: REV. DRAWN BY UNLESS OTHERWISE SPECIFIED APPROVED 24-Aug-05 D.C. 0208 UPDATE FORMAT AND RELEASE 15-May-08 D.C. M BOYER 0610 FORMAT AND PCB SIZE 23-Feb-10 D.C. M BOYER 0710 UPDATE FORMAT 26-Mar-10 M BOYER 2 M BOYER 3 3.1 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVELANT TO MT-11010. 3. INTERIOR SURFACE TEXTURE TO BE: NONE. DATE PRELIMINARY RELEASE 1 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. R E V I S I O N DESCRIPTION ECO No 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. FOR THE PCB ARE SOLD SEPERATELY. MOUNTING SCREWS 8. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 9. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF OEM. 10. STANDARD OR CUSTOM LABEL RECESSES ARE AVAILABLE UPON REQUEST FOR QUOTE. EXPLODED VIEW SCALE 0.750 SCALE 0.750 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. THIRD ANGLE PROJECTION X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° 4 SCREW_NO_4X3-8 SHiLo #4 x 3/8" STEEL ZINK COATED 4 3 453212_COVER 453212 COVER - STANDARD ABS BLACK or WHITE 1 2 453212_BASE 453212 BASE - STANDARD ABS BLACK or WHITE 1 1 453212_PCB 453212 PCB - REFERENCE CUSTOMER SUPPLIED .062" THICK 1 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2010 = 1° NEW AGE ENCLOSURES DO NOT SCALE DRAWING Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD LARGE UTILITY SXX-453212 ASSEMBLY SIZE 24-Aug-05 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 453212 DRAWING NAME A 453212_R3_1 SHEET 1 OF 6 REV.DOC 3.1 C A A SCALE 1.000 C .678 CLEAR .250 SECTION A-A .150 SECTION C-C .250 CLEAR TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD LARGE UTILITY SXX-453212 ASSEMBLY SIZE 24-Aug-05 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 453212 DRAWING NAME A 453212_R3_1 SHEET 2 OF 6 REV.DOC 3.1 453212 COVER .513 R.547 .250 R.156 6X .090 A .250 2.395 1.750 1.375 3.292 1.375 1.750 A SCALE .078 0.800 .343 1.200 1.200 1.250 1.250 .249 .593 THIS AREA AVAILABLE FOR CUSTOM INSERT SECTION A-A TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD LARGE UTILITY SXX-453212 ASSEMBLY SIZE 24-Aug-05 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 453212 DRAWING NAME A 453212_R3_1 SHEET 3 OF 6 REV.DOC 3.1 453212 BASE AREA AVAILABLE FOR CUSTOM TOOLING 2.366 X 3.336 (4X .25 ) .100 1.250 4X .311 1.250 1.200 .465 .090 1.200 A 1.750 1.375 3.336 1.375 1.750 2.336 A 4X .249 PCB MOPUNTING POSTS USE #4 X .375 HILO SCREW SCALE (R .375 ) SECTION A-A 0.800 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD LARGE UTILITY SXX-453212 ASSEMBLY SIZE 24-Aug-05 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 453212 DRAWING NAME A 453212_R3_1 SHEET 4 OF 6 REV.DOC 3.1 453212 PCB PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF EACH OWNER. 2.950 2.090 .410 3.180 4.000 .062 2.750 4X R .156 2.500 4X .125 THRU SCALE 0.800 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD LARGE UTILITY SXX-453212 ASSEMBLY SIZE 24-Aug-05 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 453212 DRAWING NAME A 453212_R3_1 SHEET 5 OF 6 REV.DOC 3.1 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" 453212 COVER SCALE 0.800 SXX-453212-XXX COVER STEP NO 1 2 3 STEP NO 4 5 6 DESCRIPTION 1 2 3 CUTTER T2 = .062" EM T2 = .062" EM T2 = .062" EM SXX-453212-XXX BASE DESCRIPTION 4 5 6 CUTTER T2 = .062" EM T2 = .062" EM T2 = .062" EM 453212 BASE SCALE 0.800 - ABS, BLACK FIXTURE _ _ _ - ORIENTATION _ _ _ ABS, BLACK FIXTURE _ _ _ ORIENTATION _ _ _ PROGRAM oXXXX oXXXX oXXXX TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° Customer's Part No: PROGRAM oXXXX oXXXX oXXXX = 1° NEW AGE ENCLOSURES APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD LARGE UTILITY SXX-453212 ASSEMBLY SIZE 24-Aug-05 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 453212 DRAWING NAME A 453212_R3_1 SHEET 6 OF 6 REV.DOC 3.1
S1A-453212 价格&库存
很抱歉,暂时无法提供与“S1A-453212”相匹配的价格&库存,您可以联系我们找货
