NOTES:
REV. DRAWN BY
UNLESS OTHERWISE SPECIFIED
APPROVED
24-Aug-05
D.C.
0208
UPDATE FORMAT AND RELEASE
15-May-08
D.C.
M BOYER
0610
FORMAT AND PCB SIZE
23-Feb-10
D.C.
M BOYER
0710
UPDATE FORMAT
26-Mar-10
M BOYER
2
M BOYER
3
3.1
2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH.
EQUIVELANT TO MT-11010.
3. INTERIOR SURFACE TEXTURE TO BE: NONE.
DATE
PRELIMINARY RELEASE
1
1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM.
R E V I S I O N
DESCRIPTION
ECO No
4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED.
5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT
THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES
AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE
6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE
UNLESS OTHERWISED SPECIFIED.
7. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED.
FOR THE PCB ARE SOLD SEPERATELY.
MOUNTING SCREWS
8. MATERIAL / COLOR:
ABS PLASTIC IS STANDARD IN BLACK OR WHITE.
CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE.
9. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND
VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF OEM.
10. STANDARD OR CUSTOM LABEL RECESSES ARE AVAILABLE UPON
REQUEST FOR QUOTE.
EXPLODED VIEW
SCALE
0.750
SCALE
0.750
TOLERANCES: UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN U.S. INCHES.
THIRD ANGLE PROJECTION
X.XX = .015 X.XXXX = .001
X.XXX = .010 X.X°
4
SCREW_NO_4X3-8
SHiLo #4 x 3/8"
STEEL
ZINK COATED
4
3
453212_COVER
453212 COVER - STANDARD
ABS
BLACK or WHITE
1
2
453212_BASE
453212 BASE - STANDARD
ABS
BLACK or WHITE
1
1
453212_PCB
453212 PCB - REFERENCE
CUSTOMER SUPPLIED
.062" THICK
1
DESCRIPTION
MATERIAL
COLOR
QTY.
ITEM
FILE
NAME
BILL OF MATERIALS
NOTICE: THE INFORMATION AND DATA
CONTAINED HEREIN IS CONSIDERED
PROPRIETARY TO ALLTEC INTEGRATED
MFG INC & SHALL REMAIN THE EXCLUSIVE
PROPERTY OF ALLTEC INTEGRATED MFG INC
THE HOLDER WILL ASSUME CUSTODY AND
CONTROL THAT THIS DOCUMENT WILL
NOT BE COPIED, REPRODUCED, OR
DISCLOSED WITHOUT THE EXPRESS WRITTEN
CONSENT OF ALLTEC INTEGRATED MFG INC
POSSESSION OF THIS DOCUMENT DOES
NOT CONSTITUTE A GRANT TO
MANUFACTURE ANY ITEMS.
© 2010
= 1°
NEW AGE ENCLOSURES
DO NOT SCALE DRAWING
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
STANDARD LARGE UTILITY
SXX-453212 ASSEMBLY
SIZE
24-Aug-05
San Luis Obispo, CA. 93401
fax (805) 595-1024
www.newageenclosures.com
453212
DRAWING NAME
A 453212_R3_1
SHEET
1 OF 6
REV.DOC
3.1
C
A
A
SCALE
1.000
C
.678 CLEAR
.250
SECTION A-A
.150
SECTION C-C
.250 CLEAR
X.XXX = .010 X.X°
= 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-453212 ASSEMBLY
SIZE
24-Aug-05
fax (805) 595-1024
453212
DRAWING NAME
A 453212_R3_1
SHEET
2 OF 6
REV.DOC
3.1
453212 COVER
.513
R.547
.250
R.156
6X
.090
A
.250
2.395
1.750
1.375
3.292
1.375
1.750
A
SCALE
.078
0.800
.343
1.200
1.200
1.250
1.250
.249
.593
THIS AREA AVAILABLE
FOR CUSTOM INSERT
SECTION A-A
X.XXX = .010 X.X°
= 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-453212 ASSEMBLY
SIZE
24-Aug-05
fax (805) 595-1024
453212
DRAWING NAME
A 453212_R3_1
SHEET
3 OF 6
REV.DOC
3.1
453212 BASE
AREA AVAILABLE FOR
CUSTOM TOOLING
2.366 X 3.336
(4X .25 )
.100
1.250
4X
.311
1.250
1.200
.465
.090
1.200
A
1.750
1.375
3.336
1.375
1.750
2.336
A
4X
.249
PCB MOPUNTING POSTS
USE #4 X .375
HILO SCREW
SCALE
(R .375 )
SECTION A-A
0.800
X.XXX = .010 X.X°
= 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-453212 ASSEMBLY
SIZE
24-Aug-05
fax (805) 595-1024
453212
DRAWING NAME
A 453212_R3_1
SHEET
4 OF 6
REV.DOC
3.1
453212 PCB
SIZES AND VERIFICATION OF IT'S FIT ARE THE
SOLE RESPONSIBILITY OF EACH OWNER.
2.950
2.090
.410
3.180
4.000
.062
2.750
4X R .156
2.500
4X
.125
THRU
SCALE
0.800
X.XXX = .010 X.X°
= 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-453212 ASSEMBLY
SIZE
24-Aug-05
fax (805) 595-1024
453212
DRAWING NAME
A 453212_R3_1
SHEET
5 OF 6
REV.DOC
3.1
2nd OPERATION DETAILS
NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE
CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT.
ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES
CALL (805) 595-1310 FOR PRICING AND SCHEDULE.
THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031"
453212 COVER
SCALE
0.800
SXX-453212-XXX COVER
STEP NO
1
2
3
STEP NO
4
5
6
DESCRIPTION
1
2
3
CUTTER
T2 = .062" EM
T2 = .062" EM
T2 = .062" EM
SXX-453212-XXX BASE
DESCRIPTION
4
5
6
CUTTER
T2 = .062" EM
T2 = .062" EM
T2 = .062" EM
453212 BASE
SCALE
0.800
ABS, BLACK
FIXTURE
_
_
_
ORIENTATION
_
_
_
ABS, BLACK
FIXTURE
_
_
_
ORIENTATION
_
_
_
PROGRAM
oXXXX
oXXXX
oXXXX
X.XXX = .010 X.X°
Customer's Part No:
PROGRAM
oXXXX
oXXXX
oXXXX
= 1°
NEW AGE ENCLOSURES
APPROVAL
BY
DATE
CHECK
ENG.
SCALE
DRAWN BY
M BOYER
4330 Santa Fe Road
ph. (805) 595-1310
SXX-453212 ASSEMBLY
SIZE
24-Aug-05
fax (805) 595-1024
453212
DRAWING NAME
A 453212_R3_1
SHEET
6 OF 6
REV.DOC
3.1
很抱歉,暂时无法提供与“S3A-453212”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+97.791911+12.23571
