NOTES:
UNLESS OTHERWISE SPECIFIED
REV. DRAWN BY
1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM.
DATE
APPROVED
PRELIMINARY RELEASE
16-Mar-2009
D.C.
2109
UPDATE MODEL, ADD DRAFT AND FORMAT
18-Apr-2009
D.C.
M BOYER
4309
ADD SURFACE CALLOUT AND MODIFY HATCH
14-Dec-2009
D.C.
3.1
M BOYER
0710
UPDATE FORMAT
20-Mar-2010
D.C.
4.0
M BOYER
1210
ADD CORING IN REAR
04-May-2010
D.C.
4.1
M BOYER
2810
UPDATE VIEWS AND 2ND-OP PAGE
28-Jul-2010
D.C.
1
M BOYER
2
M BOYER
3
4. ALL INSIDE RADII .010R. ALL OUTSIDE RADII .020R MAX,
UNLESS OTHERWISE SPECIFIED.
5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT
THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES
AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE
FEATURE UNLESS OTHERWISE SPECIFIED.
2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH.
EQUIVALENT TO MT-11020.
3. INTERIOR SURFACE TEXTURE TO BE: NONE
6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS
OTHERWISED SPECIFIED.
7. MATERIAL / COLOR:
ABS PLASTIC IS STANDARD IN BLACK OR WHITE.
CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE.
8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND
VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF
EACH CUSTOMER.
9. ASSEMBLY HARDWARE PROVIDED.
R E V I S I O N
DESCRIPTION
ECO No
5.0
R CRUZ
7713
ADD "TALL" CONFIGURATION
01-Nov-2013
D.C.
6.0
R CRUZ
2214
INCLUDE WALL CRADLE OPTION
19-May-2014
D.C.
7.0
M BOYER
0814
CHANGE TEXTURE CALLOUT
21-May-2014
D.C.
7.1
R CRUZ
0361
UPDATE WALL CRADLE DIMENSIONS TO AS BUILT
18-Jun-2014
D.C.
8.0
M BOYER
5214
REMOVE TALL CONFIG AND INCLUDE PCB NOTCH
15-Dec-2014
BATTERY CONTACTS SOLD SEPERATELY
10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED
BY THE SOLID MODEL FILE.
251510(x) CONFIGURATIONS
-Blank
-K
251510 COVER
1
1
251510 BASE
1
251510 MACHINED BASE
1
251510 HATCH
1
1
251510 WALL CRADLE
1
#2 HiLo SCREW .375"
4
4
5
2
-WP
4
8
1
1
10
STANDARD 251510
SCALE 0.750
9
3
6
10
AAA-SINGL-CONTACT-POS
ACC-AAAPOS-5226
SPRING STEEL
SOLD SEPERATELY
1
9
AAA-SINGL-CONTACT-NEG
ACC-AAANEG-5204
SPRING STEEL
SOLD SEPERATELY
1
8
AAA-DBL-CONTACT
ACC-AAADBL-5214L
SPRING STEEL
SOLD SEPERATELY
1
7
251510_WALL-CRADLE
251510 WALL CRADLE - STANDARD
ABS
BLACK or WHITE
1
6
251510_HATCH
251510 HATCH - STANDARD
ABS
BLACK or WHITE
1
5
251510_COVER
251510 COVER - STANDARD
ABS
BLACK or WHITE
1
4
251510_BASE
251510 BASE - STANDARD
ABS
BLACK or WHITE
1
3
NO_2_HI-LO_SCREW
No2 HI-LO x .375"
STEEL
3/8" LONG
4
2
251510_PCB
REFERENCE ONLY
CUSTOMER SUPPLIED
.062" THICK
1
1
AAA-BATTERY
REFERENCE ONLY
CUSTOMER SUPPLIED
"AAA" SIZE
2
DESCRIPTION
MATERIAL
COLOR
QTY.
ITEM
FILE
NAME
BILL OF MATERIALS
7
EXPLODED VIEW 251510K
SCALE 0.600
THIRD ANGLE PROJECTION
TOLERANCES: UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN U.S. INCHES.
DO NOT SCALE DRAWING
NEW AGE ENCLOSURES
X.XX = .015 X.XXXX = .001
X.XXX = .010
X.X° = 1°
NOTICE: THE INFORMATION AND DATA
CONTAINED HEREIN IS CONSIDERED
PROPRIETARY TO ALLTEC INTEGRATED
MFG INC & SHALL REMAIN THE EXCLUSIVE
PROPERTY OF ALLTEC INTEGRATED MFG INC
THE HOLDER WILL ASSUME CUSTODY AND
CONTROL THAT THIS DOCUMENT WILL
NOT BE COPIED, REPRODUCED, OR
DISCLOSED WITHOUT THE EXPRESS WRITTEN
CONSENT OF ALLTEC INTEGRATED MFG INC
POSSESSION OF THIS DOCUMENT DOES
NOT CONSTITUTE A GRANT TO
MANUFACTURE ANY ITEMS.
© 2014
Customer's Part No:
APPROVAL
BY
4330 Santa Fe Road
ph. (805) 595-1310
STANDARD - MINI AAA
SXX-251510X ASSEMBLY
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
16-Mar-2009
San Luis Obispo, CA. 93401
fax (805) 595-1024
www.newageenclosures.com
251510
A
DRAWING NAME
251510_R8_0
SHEET
1 OF 8
REV.DOC
8.0
.080
SECTION C-C
P
SEE DETAIL A
R.165
F
1.599
SEE DETAIL B
C
2.559
C
SCALE 1.000
P
F
SECTION F-F
SECTION P-P
.925
.268
PCB CAPTURED
1.070
DETAIL B
SCALE 2.000
SECTION Y-Y
DETAIL A
SCALE 2.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
NOTE: BATTERY CONTACT
TABS CAN BE PUSHED
THROUGH THE PCB AND
SOLDERED TO THE SURFACE
OR THE TAB CAN BE BENT
BACK AT 90° AND WIRED.
APPROVAL
BY
4330 Santa Fe Road
ph. (805) 595-1310
STANDARD - MINI AAA
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
16-Mar-2009
fax (805) 595-1024
251510
A
DRAWING NAME
251510_R8_0
SHEET
2 OF 8
REV.DOC
8.0
S251510 - COVER
.025
SECTION F-F
.525
1.599
1.250
.515
D
(.178)
.267
F
F
2.559
SCALE 1.000
2.000
251510 STANDARD
SECTION D-D
D
.062
.188
.925
R.165
3.0°
X.XXX = .010
X.X° = 1°
.025
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
4330 Santa Fe Road
ph. (805) 595-1310
STANDARD - MINI AAA
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
16-Mar-2009
fax (805) 595-1024
251510
A
DRAWING NAME
251510_R8_0
SHEET
3 OF 8
REV.DOC
8.0
.150
S251510 - BASE
.250
.045
.525
.870
.093
J
2.000
INSIDE
LABEL
AREA
1.885
1.250
.090
.960
E
E
SECTION J-J
SCALE 1.000
.250
J
.175
3.0°
.250
R.207
.057
.150
SECTION E-E
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
4330 Santa Fe Road
ph. (805) 595-1310
STANDARD - MINI AAA
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
16-Mar-2009
fax (805) 595-1024
251510
A
DRAWING NAME
251510_R8_0
SHEET
4 OF 8
REV.DOC
8.0
1.452
S251510 - WALL CRADLE
.360
.190
SECTION Y-Y
1.000
.695
.170
2.756
1.700
2.0°
SCALE 1.000
.374
.180
SECTION X-X
2nd OPERATION REQUIRED
ON 251510 BASE
TO ACCEPT CRADLE TABS
.360
SECTION Y-Y
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
4330 Santa Fe Road
ph. (805) 595-1310
STANDARD - MINI AAA
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
16-Mar-2009
fax (805) 595-1024
251510
A
DRAWING NAME
251510_R8_0
SHEET
5 OF 8
REV.DOC
8.0
1.160
1.075 x2
1.000 x2
.800
.000
.800
.830 x2
1.000 x2
1.160
S251510 - PCB
.690
.625 x2
.225 x2
.000
.125
.225 x2
.030
R.078
.625 x2
.690
SCALE 2.000
.015
R.125
.063
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
NOTE
1. BATTERY CONNECTION POINTS SHOWN AT BOTH ENDS
TO ALLOW ALTERNATE ASSEMBLY OPTION.
APPROVAL
BY
4330 Santa Fe Road
ph. (805) 595-1310
STANDARD - MINI AAA
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
16-Mar-2009
fax (805) 595-1024
251510
A
DRAWING NAME
251510_R8_0
SHEET
6 OF 8
REV.DOC
8.0
2nd OPERATION DETAILS (PAGE 1 OF 2)
NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE
CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT.
ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES
CALL (805) 595-1310 FOR PRICING AND SCHEDULE.
THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031"
.353
NOTCHES FOR
WALL CRADLE
.094 4x
.303 4x
.348
.000
.348
251510 BASE
SCALE 1.000
STEP 1
STEP 2
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
STEP NO
1-B-C1
2-B-C2
SXX-251510X-XXX BASE
DESCRIPTION
CRADLE NOTCHES
CRADLE NOTCHES
CUTTER
T2 = .062" EM
T2 = .062" EM
ABS, BLACK
FIXTURE
190
190
ORIENTATION
SINGLE
SINGLE
Customer's Part No:
APPROVAL
PROGRAM
BY
4330 Santa Fe Road
ph. (805) 595-1310
STANDARD - MINI AAA
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
16-Mar-2009
fax (805) 595-1024
251510
A
DRAWING NAME
251510_R8_0
SHEET
7 OF 8
REV.DOC
8.0
2nd OPERATION DETAILS (PAGE 2 OF 2)
251510 COVER
SCALE 1.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
STEP NO
1-C-C1
2-C-C2
SXX-251510X-XXX COVER
DESCRIPTION
CUTTER
T2 = .062" EM
T2 = .062" EM
ABS, BLACK
FIXTURE
190
190
ORIENTATION
Customer's Part No:
APPROVAL
PROGRAM
BY
4330 Santa Fe Road
ph. (805) 595-1310
STANDARD - MINI AAA
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
16-Mar-2009
fax (805) 595-1024
251510
A
DRAWING NAME
251510_R8_0
SHEET
8 OF 8
REV.DOC
8.0
很抱歉,暂时无法提供与“S3A-251510-K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5+89.041695+11.57514
