From Off-The-Shelf to Market-Ready© New Age Enclosures is your Single Source Solution.
Let us quote modifying our Stock Enclosures to meet your end-use.
visit newageenclosures.com/services or call 855-4NA-ENCL today.
REV.
DRAWN BY
1
M BOYER
ECO No
R E V I S I O N
DESCRIPTION
PRELIMINARY RELEASE
DATE
APPROVED
11-Dec-08
D.C.
06-Jul-15
D.C.
REVISIONS 2-8.1 ARCHIVED ON REV 8.1
9.0
R CRUZ
03115
CHANGED O-RING COLOR FROM NATURAL TO BLUE
10.0
R CRUZ
02918
REMOVE CONFIG TABLE, UPDATE O-RING & NOTE 7
2018-Oct-31
2
LABEL RECESS AREA
RECOMMENDED LABEL SIZE
3.540" x 2.570"
4
7
6
NOTES:
UNLESS OTHERWISE SPECIFIED
1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM.
8
2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH.
EQUIVELANT TO MT-11020.
3. INTERIOR SURFACE TEXTURE TO BE: NONE.
9
4. ALL INSIDE RADII .010R. ALL OUTSIDE RADII .020R MAX,
UNLESS OTHERWISE SPECIFIED.
5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE
FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END
OF THE FEATURE UNLESS OTHERWISE SPECIFIED.
6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED.
3
7. MATERIAL / COLOR: ENCLOSURE IS STANDARD IN BLACK OR GRAY ASA PLASTIC. SLIGHT
COSMETIC SWIRLING, BLUSHING, AND/OR DISCOLORATION CAN OCCUR IN THIS ENCLOSURE
DUE TO UV INHIBITORS IN THE RESIN. CUSTOM MATERIALS AND COLORS ARE AVAILABLE
UPON REQUEST FOR QUOTE.
8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE
THE SOLE RESPONSIBILITY OF EACH OWNER.
5
9. STANDARD OR CUSTOM LABEL RECESSES ARE AVAILABLE UPON REQUEST FOR QUOTE.
10. ASSEMBLY SCREWS PROVIDED, PCB MOUNTING SCREWS ARE SOLD SEPERATELY.
1
11. OPERATING TEMPERATURE RANGE OF ENCLOSURE IS: -40°F to +180°F
SCALE 0.500
9
523322_ORING
523322 ORING
OR-156
SHORE A
1
8
PEM-INSERT_8-32
PEM THREADED INSERT - BRASS
STKB-832-20
OVERMOLDED
4
7
SCREW_HILO-NO4X250
#4 HiLo SCREW x .250"
ZINC PLATED
CUSTOMER SUPPLIED
4
6
523322_PCB
523322 PCB - REFERENCE
.062" THICK
CUSTOMER SUPPLIED
1
5
523322_WALL
523322 WALL PLATE - STANDARD
ASA
BLACK or GRAY
1
4
523322_COVER
523322 COVER - STANDARD
ASA
BLACK or GRAY
1
3
523322_BASE
523322 BASE - STANDARD
ASA
BLACK or GRAY
1
2
8-32_MACH_SCREW
8-32 MACHINE SCREW
8x32x.500
.50" LONG
4
1
SCREW_HILO-NO4X375
#4 HiLo SCREW x .375"
ZINC PLATED
.375" LONG
4
DESCRIPTION
MATERIAL
COLOR
QTY.
ITEM
FILE
NAME
BILL OF MATERIALS
12. THIS ENCLOSURE IS CONSTRUCTED FOR INDOOR OR OUTDOOR USE TO PROVIDE A DEGREE OF
PROTECTION TO THE EQUIPMENT INSIDE AGAINST THE INGRESS OF SOLID FOREIGN OBJECTS
(FALLING DIRT); AND TO PROVIDE A DEGREE OF PROTECTION WITH RESPECT TO HARMFUL EFFECTS
ON THE EQUIPMENT DUE TO THE INGRESS OF WATER (DRIPPING AND SPLASHING).
THIRD ANGLE PROJECTION
TOLERANCES: UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN U.S. INCHES.
DO NOT SCALE DRAWING
NEW AGE ENCLOSURES
X.XX = .015 X.XXXX = .001
X.XXX = .010
X.X° = 1°
NOTICE: THE INFORMATION AND DATA
CONTAINED HEREIN IS CONSIDERED
PROPRIETARY TO ALLTEC INTEGRATED
MFG INC & SHALL REMAIN THE EXCLUSIVE
PROPERTY OF ALLTEC INTEGRATED MFG INC
THE HOLDER WILL ASSUME CUSTODY AND
CONTROL THAT THIS DOCUMENT WILL
NOT BE COPIED, REPRODUCED, OR
DISCLOSED WITHOUT THE EXPRESS WRITTEN
CONSENT OF ALLTEC INTEGRATED MFG INC
POSSESSION OF THIS DOCUMENT DOES
NOT CONSTITUTE A GRANT TO
MANUFACTURE ANY ITEMS.
© 2018
Customer's Part No:
APPROVAL
BY
523322
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
2240 South Thornburg Street
ph. (805) 595-1310
STANDARD - OUTDOOR UTIL.
SXL-523322 ASSEMBLY
SIZE
11-Dec-08
Santa Maria, CA. 93455
fax (805) 595-1024
www.newageenclosures.com
A
DRAWING NAME
523322_R10_0
SHEET
1 OF 7
REV.DOC
10.0
6.310
5.217
OVERMOLDED
PEM INSERT
H
H
C
C
3.271
3.660
DETAIL D
SCALE 2.000
SEE DETAIL D
SEE DETAIL F
1.660 CLEAR
2.180
2.405
1° DRAFT
TYP.
SECTION C-C
SCALE 0.600
SECTION H-H
X.XXX = .010
X.X° = 1°
3.0°
NEW AGE ENCLOSURES
.180
DETAIL F
SCALE 1.500
.020
Customer's Part No:
APPROVAL
BY
523322
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXL-523322 ASSEMBLY
SIZE
11-Dec-08
fax (805) 595-1024
A
DRAWING NAME
523322_R10_0
SHEET
2 OF 7
REV.DOC
10.0
523322 COVER
4.879
3.789
.172 THRU
.624
R.300
G
2.933
LABEL RECESS
1.543
2.600
1.843
.458
G
R.025
SCALE 0.600
1° DRAFT
R.005
3.570
R.050
R.135
.600
.158
.180
.040 RECESS
.069
SECTION G-G
SEE DETAIL A
.088 +2°
DRAFT/SIDE
.115
(.445)
R .030
.080
SCALE 0.600
.060
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
.120
APPROVAL
BY
523322
DATE
CHECK
ENG.
DETAIL A
SCALE 3.000
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXL-523322 ASSEMBLY
SIZE
11-Dec-08
fax (805) 595-1024
A
DRAWING NAME
523322_R10_0
SHEET
3 OF 7
REV.DOC
10.0
523322 BASE
4.496
1° DRAFT TYP.
3.206
D
D
2.550
1.300
2.284
SCALE 0.600
.285
4.500
.065
R.135
1.610
.216 -1° DRAFT/SIDE
.125
.312
.060
SEE DETAIL B
.045 +1°
DRAFT/SIDE
SCALE 0.600
.065
SECTION D-D
.240
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
.325
.300
Customer's Part No:
.076
APPROVAL
BY
523322
DATE
CHECK
.125
ENG.
DETAIL B
SCALE 3.000
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXL-523322 ASSEMBLY
SIZE
11-Dec-08
fax (805) 595-1024
A
DRAWING NAME
523322_R10_0
SHEET
4 OF 7
REV.DOC
10.0
523322 WALL
5.700
X
Y
6.310
R.300
X
Y
3.660
SECTION X-X
3.209
.281
.050
.125
5.155
.281
SCALE 0.600
.375
SCALE 0.600
SECTION Y-Y
.225
.060
.090
SEE DETAIL E
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
523322
DATE
CHECK
DETAIL E
SCALE 1.332
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXL-523322 ASSEMBLY
SIZE
11-Dec-08
fax (805) 595-1024
A
DRAWING NAME
523322_R10_0
SHEET
5 OF 7
REV.DOC
10.0
523322 PCB - CUSTOMER SUPPLIED
2.425
1.895
1.603 2x
.000
1.603 2x
1.895
2.425
SIZES AND VERIFICATION OF ITS FIT ARE THE
SOLE RESPONSIBILITY OF THE OEM.
1.445
1.142 2x
.930
.000
.930
1.142 2x
1.445
R.150
.125 4x
SCALE 1.000
.062
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
523322
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXL-523322 ASSEMBLY
SIZE
11-Dec-08
fax (805) 595-1024
A
DRAWING NAME
523322_R10_0
SHEET
6 OF 7
REV.DOC
10.0
2nd OPERATION DETAILS
NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE
CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT.
ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES
CALL (805) 595-1310 FOR PRICING AND SCHEDULE.
THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031"
523322 COVER
SCALE 0.666
523322 BASE
SCALE 0.666
X.XXX = .010
X.X° = 1°
STEP NO
1
2
3
SXL-523322-XXX BASE
DESCRIPTION
CUTTER
T2 = .062" EM
T2 = .062" EM
T2 = .062" EM
ASA, BLACK
FIXTURE
216
216
216
ORIENTATION
NEW AGE ENCLOSURES
Customer's Part No:
PROGRAM
APPROVAL
BY
523322
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
SXL-523322 ASSEMBLY
SIZE
11-Dec-08
fax (805) 595-1024
A
DRAWING NAME
523322_R10_0
SHEET
7 OF 7
REV.DOC
10.0
很抱歉,暂时无法提供与“S3L-523322”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+153.314201+19.81312
